I’m working on an opengl renderer on ubuntu14.04, which receives opengl commands from a guest VM and apply them in host system. Each renderer process provides rendering service for one guest VM.
I manage to get 8 guest VMs run simutaneously and everything seems ok.
As the number goes to 9, it generates a glxMakeCurrent failure, which is weird, glGetError returns 0.
Now I get 4 nVidia GRID K2 installed. When the number reaches 12, all the renderers seem to be abnormal. I made some time count, sometimes the glxMakeCurrent call costs 2-3 seconds. Nvidia-smi runs really slow too, but it shows GPU-Util is less than 10%.
My goal is making at least 50 guest VMs running and the road seems to be really tough…
Any helps or suggestions would be greatly appreciated.
Here’s nvidia-smi output
Tue Aug 16 18:27:22 2016
| NVIDIA-SMI 352.79 Driver Version: 352.79 |
| 0 GRID K2 Off | 0000:04:00.0 Off | Off |
| N/A 39C P0 46W / 117W | 364MiB / 4095MiB | 5% Default |
| 1 GRID K2 Off | 0000:05:00.0 Off | Off |
| N/A 40C P0 44W / 117W | 1322MiB / 4095MiB | 4% Default |
| 2 GRID K2 Off | 0000:83:00.0 Off | Off |
| N/A 44C P0 43W / 117W | 851MiB / 4095MiB | 1% Default |
| 3 GRID K2 Off | 0000:84:00.0 Off | Off |
| N/A 42C P0 41W / 117W | 495MiB / 4095MiB | 0% Default |
| 4 GRID K2 Off | 0000:89:00.0 Off | Off |
| N/A 28C P8 17W / 117W | 323MiB / 4095MiB | 0% Default |
| 5 GRID K2 Off | 0000:8A:00.0 Off | Off |
| N/A 42C P0 43W / 117W | 1332MiB / 4095MiB | 5% Default |
| 6 GRID K2 Off | 0000:8D:00.0 Off | Off |
| N/A 37C P0 47W / 117W | 1310MiB / 4095MiB | 6% Default |
| 7 GRID K2 Off | 0000:8E:00.0 Off | Off |
| N/A 48C P0 44W / 117W | 1108MiB / 4095MiB | 4% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1722 G /usr/local/Xorg/bin/Xorg 215MiB |
| 0 14677 G ...opengl_render/host/renderer/opengl_render 54MiB |
| 0 29131 G ...opengl_render/host/renderer/opengl_render 53MiB |
| 0 36103 G ...opengl_render/host/renderer/opengl_render 26MiB |
| 0 36622 G ...opengl_render/host/renderer/opengl_render 18MiB |
| 1 1728 G /usr/local/Xorg/bin/Xorg 650MiB |
| 1 11851 C+G ...opengl_render/host/renderer/opengl_render 187MiB |
| 1 16170 C+G ...opengl_render/host/renderer/opengl_render 143MiB |
| 1 20994 C+G ...opengl_render/host/renderer/opengl_render 281MiB |
| 2 1735 G /usr/local/Xorg/bin/Xorg 583MiB |
| 2 2540 C+G ...opengl_render/host/renderer/opengl_render 138MiB |
| 2 14782 G ...opengl_render/host/renderer/opengl_render 36MiB |
| 2 27951 G ...opengl_render/host/renderer/opengl_render 55MiB |
| 3 1741 G /usr/local/Xorg/bin/Xorg 301MiB |
| 3 21122 G ...opengl_render/host/renderer/opengl_render 57MiB |
| 3 21559 G ...opengl_render/host/renderer/opengl_render 38MiB |
| 3 39115 G ...opengl_render/host/renderer/opengl_render 38MiB |
| 3 40164 G ...opengl_render/host/renderer/opengl_render 36MiB |
| 4 1747 G /usr/local/Xorg/bin/Xorg 170MiB |
| 4 17735 G ...opengl_render/host/renderer/opengl_render 55MiB |
| 4 18751 G ...opengl_render/host/renderer/opengl_render 38MiB |
| 4 21581 G ...opengl_render/host/renderer/opengl_render 36MiB |
| 5 1752 G /usr/local/Xorg/bin/Xorg 599MiB |
| 5 2128 C+G ...opengl_render/host/renderer/opengl_render 243MiB |
| 5 19257 C+G ...opengl_render/host/renderer/opengl_render 201MiB |
| 5 26109 C+G ...opengl_render/host/renderer/opengl_render 267MiB |
| 6 1757 G /usr/local/Xorg/bin/Xorg 647MiB |
| 6 11064 C+G ...opengl_render/host/renderer/opengl_render 203MiB |
| 6 11355 C+G ...opengl_render/host/renderer/opengl_render 167MiB |
| 6 12225 C+G ...opengl_render/host/renderer/opengl_render 262MiB |
| 7 1762 G /usr/local/Xorg/bin/Xorg 551MiB |
| 7 12998 C+G ...opengl_render/host/renderer/opengl_render 216MiB |
| 7 14793 G ...opengl_render/host/renderer/opengl_render 36MiB |
| 7 35355 C+G ...opengl_render/host/renderer/opengl_render 282MiB |
