OpenGL Tessellation
I’m having a hard time getting OpenGL Tessellation to work. I have been struggling with it for about a month now. I’ve looked at a lot of example code and what I am doing doesn’t seem that different to what they are doing in their code. I was wondering if anyone could be a second pair of eyes and maybe point out why it isn’t working.
My scene is only rendering a black screen.
My shaders are as follows:
Vertex Shader
#version 150
in vec3 vertexPosition;
in vec3 vertexNormal;
in vec2 textureCoords;
in float textureIndex;
out VertexData
vec4 VertexPositions;
vec3 VertexNormals;
vec2 TextureCoords;
float TextureIndexs;
} vertex;
void main()
vertex.VertexPositions = vec4(vertexPosition, 1.0);
vertex.VertexNormals = vertexNormal;
vertex.TextureCoords = textureCoords;
vertex.TextureIndexs = textureIndex;
Tessellation Control Shader
#version 400
layout(vertices = 3) out;
in vec4 iVertexPositions;
in vec3 iVertexNormals;
in vec2 iTextureCoords;
in float iTextureIndexs;
out vec4 oVertexPositions;
out vec3 oVertexNormals;
out vec2 oTextureCoords;
out float oTextureIndexs;
void main()
float inLevel = 2;
float outLevel = 2;
gl_out[gl_InvocationID].gl_Position = gl_in[gl_InvocationID].gl_Position;
oVertexPositions[gl_InvocationID] = iVertexPositions[gl_InvocationID];
oVertexNormals[gl_InvocationID] = iVertexNormals[gl_InvocationID];
oTextureCoords[gl_InvocationID] = iTextureCoords[gl_InvocationID];
if (gl_InvocationID == 0)
	gl_TessLevelOuter[0] = outLevel;
	gl_TessLevelOuter[1] = outLevel;
	gl_TessLevelOuter[2] = outLevel;
	gl_TessLevelOuter[3] = outLevel;
	gl_TessLevelInner[0] = inLevel;
	gl_TessLevelInner[1] = inLevel;
Tessellation Eval Shader
#version 400
layout(triangles, equal_spacing, ccw) in;
uniform mat4 uMVPMatrix;
out VertexData
vec3 VertexNormals;
vec2 TextureCoords;
} vOut;
void main()
vec4 p0 = gl_TessCoord.x * iVertexPositions[0];
vec4 p1 = gl_TessCoord.y * iVertexPositions[1];
vec4 p2 = gl_TessCoord.z * iVertexPositions[2];
vec4 newCoord = normalize(p0 + p1 + p2);
vec3 normal = cross(vec3(p0 - newCoord), vec3(p1 - newCoord));
vOut.VertexPositions = newCoord;
vOut.VertexNormals =  normal;
vOut.TextureCoords = vec2(gl_TessCoord.xy);
vOut.TextureIndexs = iTextureIndexs[0];
gl_Position = newCoord;
Geometry Shader
#version 400
layout(triangles) in;
layout(triangle_strip, max_vertices = 3) out;
in VertexData
vec3 VertexNormals;
vec2 TextureCoords;
} vertex;
uniform vec3 LightNorm;
uniform vec4 LightIntensReflect;
uniform vec4 AmbientLight;
uniform vec4 VertColors;
uniform vec3 VertSpecularHighlight;
uniform vec3 CameraLocation;
uniform bool UseLighting;
uniform bool UseTexture;
uniform bool UseTextureArray;
uniform mat4 DepthBiasMVP;
uniform mat3 uNMatrix;
uniform bool UseWaveGeometry;
uniform float GameTime;
out vec4 SpecularColor;
out vec4 LightShade;
out vec4 ShadowCoord;
out vec4 vColor;
out vec3 tCoord;
float rand(vec2 n)
return 0.5 + 0.5 * fract(sin(dot(n.xy, vec2(12.9898, 78.233)))* 43758.5453);
void setUpValues(int index)
vec4 vertPosit = vertex[index].VertexPositions;
if(UseTexture)
tCoord = vec3(vertex[index].TextureCoords.st, vertex[index].TextureIndexs);
else
tCoord = vec3(0.0);
if(UseLighting)
	ShadowCoord = DepthBiasMVP * vertPosit;
	vec3 tnorm = normalize(uNMatrix * vertex[index].VertexNormals);
	LightShade = LightIntensReflect * max(dot(LightNorm, tnorm), 0.0);
	SpecularColor = vec4(1.0);
	vColor = LightShade * VertColors + (AmbientLight * VertColors);
else
	ShadowCoord = vec4(0.0);
	LightShade = vec4(1.0);
	vColor = VertColors;
if(UseWaveGeometry)
	vertPosit.y = vertPosit.y + (GameTime + ((cos(vertPosit.x)) * GameTime) - ((sin(vertPosit.x))*GameTime)*2.2);
gl_Position = uMVPMatrix * vertPosit;
void main()
for(int i = 0; i < 3; i++)
setUpValues(i);
EmitVertex();
EndPrimitive();
Fragment Shader
#version 150
#extension GL_EXT_gpu_shader4: enable
#extension GL_EXT_texture_array: enable
uniform sampler2DShadow ShadowMap;
uniform sampler2D TextureData;
uniform sampler2DArray TextureArrayData;
uniform bool UseAlpha;
uniform float ColorAlpha;
in vec4 SpecularColor;
in vec4 vColor;
in vec4 LightShade;
in vec4 ShadowCoord;
in vec3 tCoord;
out vec4 FragColor;
void main()
vec4 color = vec4(1.0);
float Shadow = 1.0;
if(UseTexture)
if(UseTextureArray)
color = texture2DArray(TextureArrayData, tCoord.stp);
else
color = texture2D(TextureData, tCoord.st);
	if(UseAlpha)
		color = vec4(color.r, color.g, color.b, ColorAlpha);
	if(UseLighting)
		if(ShadowCoord.w > 0.0)
			Shadow = textureProj(ShadowMap, ShadowCoord);
		FragColor = ((LightShade * color) * Shadow + (color * AmbientLight)) * SpecularColor;
	else
		FragColor = color;
else
	if(UseLighting)
	if(UseAlpha)
		color = vec4(vColor.r, vColor.g, vColor.b, ColorAlpha);
	FragColor = color * Shadow * SpecularColor;
Thank you for your time,
Marty
I’ve cleaned up my shaders to simplify the code. Right now there is just the tessellation code.
Vertex Shader
#version 400
#extension GL_ARB_tessellation_shader: enable
#extension GL_ARB_separate_shader_objects: enable
layout(location = 0) in vec3 vertexPosition;
void main()
gl_Position = vec4(vertexPosition, 1.0);
#version 400
void main()
float inLevel = 2;
float outLevel = 2;
#version 400
void main()
vec4 p0 = gl_TessCoord.x * gl_in[0].gl_Position;
vec4 p1 = gl_TessCoord.y * gl_in[1].gl_Position;
vec4 p2 = gl_TessCoord.z * gl_in[2].gl_Position;
Geometry Shader
#version 400
layout(location = 3) out vec4 vColor;
float rand(vec2 n)
vec4 vertPosit = gl_in[index].gl_Position;
if(UseWaveGeometry)
float cval = int(vertPosit.x) % 2 + int(vertPosit.y)%2;
vColor = vec4(cval, cval, cval, 1.0);
void main()
setUpValues(i);
EmitVertex();
EndPrimitive();
Fragment Shader
#version 400
layout(location = 3) in vec4 vColor;
layout(location = 0) out vec4 FragColor;
void main()
vec4 color = vec4(vColor.r, vColor.g, vColor.b, ColorAlpha);
FragColor = color;
I figured out my issue. The problem is when I called glDrawArrays I was passing in GL_TRIANGLES instead of GL_PATCHES
