I have a GLFW program that grabs frames from a camera (using gstreamer and appsink), draws an overlay, then outputs the texture to the encoder for recording. I was using GLReadTexturePixels() for the copy to a GSTBuffer, but the copying was too slow.
I have now looked at several examples from Jetson Multimedia API and other examples from this forum, but I am still having issues passing my textures to Gstreamer.
My pipeline for testing:
pipelineString = FormatText("appsrc name=video%d is-live=true do-timestamp=true ! video/x-raw(memory:NVMM), format=RGBA, width=1920, height=1080, framerate=30/1 ! queue ! nvvidconv flip-method=6 ! video/x-raw(memory:NVMM),format=NV12 ! queue ! nvoverlaysink sync=false display-id=1", 0 );
GstElement *pipeline = gst_parse_launch (pipelineString, &error);
if (error != NULL) {
printf ("Something went wrong with overlay %d initialization: %s\n", Cam, error->message);
return NULL;
AppsrcPipe[Cam].src = gst_bin_get_by_name(GST_BIN ( AppsrcPipe[Cam].pipeline), FormatText("video%d", Cam==3?4:Cam));
gst_app_src_set_stream_type(AppsrcPipe[Cam].src, GST_APP_STREAM_TYPE_STREAM);
gst_element_set_state(AppsrcPipe[Cam].pipeline, GST_STATE_PLAYING);
And my Function to push the buffers to appsrc:
void pushBuffer(int cam){
int err;
void* pdata;
if(cam>0){return;}
if(AppsrcPipe[cam].src!=NULL){
if(!GLFWContext){
GLFWContext=glfwGetCurrentContext();
MyeglDisplay=glfwGetEGLDisplay();
if(MyeglDisplay==EGL_NO_DISPLAY){
printf("failed to get EGL display\n");
GstBuffer *buffer;
GstFlowReturn ret;
GstMapInfo map = {0};
int dmabuf_fd = 0;
gpointer data = NULL, user_data = NULL;
NvBufferParams par;
GstMemoryFlags flags = (GstMemoryFlags)0;
NvBufferCreate(&dmabuf_fd, 1920, 1080, NvBufferLayout_BlockLinear, NvBufferColorFormat_ABGR32);
EGLImageKHR temp = NvEGLImageFromFd(MyeglDisplay ,dmabuf_fd);
glBindTexture(GL_TEXTURE_2D, _texture_id);
glFinish();
glEGLImageTargetTexture2DOES(GL_TEXTURE_2D, temp);
NvDestroyEGLImage(MyeglDisplay, temp);
while((err=glGetError())!=GL_NO_ERROR){
switch(err){
case GL_INVALID_OPERATION :
printf("Got GL error GL_INVALID_OPERATION: %03X \n", err);
break;
default:
printf("Got GL error : %03X\n", err);
user_data = g_malloc(sizeof(int));
//printf ("NvBufferCreate %d", dmabuf_fd);
*(int *)user_data = dmabuf_fd;
NvBufferGetParams (dmabuf_fd, &par);
data = g_malloc(par.nv_buffer_size);
buffer = gst_buffer_new_wrapped_full(flags,data,par.nv_buffer_size, 0, par.nv_buffer_size,user_data, notify_to_destroy);
gst_buffer_map (buffer, &map, GST_MAP_WRITE);
memcpy(map.data, par.nv_buffer , par.nv_buffer_size);
gst_buffer_unmap(buffer, &map);
int flow;
g_signal_emit_by_name(AppsrcPipe[cam].src, "push-buffer", buffer, &flow);
gst_buffer_unref(buffer);
if(flow !=0){
printf("flow = %d from camera %d\n", flow, cam);
The issue I am having is that the full image is often not making it to gstreamer. Most frames are only partial (see attached image)
