Hi guys, I have a simple PBR renderer that runs at about 1000 FPS on an RTX 3060 (driver version: 591.86), at 1080p, rendering the Intel Sponza Scene using OpenGL, Vulkan, or Direct3D 11. However, when I try to use texture views in OpenGL, my FPS drops to about 350. It’s a huge difference, even slower than the Vulkan rendering with turned-on ray-traced shadows. It’s strange because the texture view doesn’t really do anything; it doesn’t change the texture format, type, mip levels, or array layers. For the current use case, I could just use the original texture, since the texture view doesn’t do anything. But if I’d like to use a different format, type, etc. I’d need a texture view. On my GTX 1050M, the FPS drop is not as dramatic, but still significant. Could you take a look at what’s going on?
Related topics
| OpenGL Performance Issue on Windows 10 since Driver 355.60 | 0 | 1847 | August 22, 2016 | |
| Better performance in OpenGL with old drivers. | 0 | 1011 | May 27, 2014 | |
| Vulkan extremely slow compared to opengl | 4 | 378 | November 4, 2025 | |
| glReadPixels Win7 GTX690 | 2 | 1444 | April 3, 2014 | |
| GL_OVR_Multiview performance on RTX3000 | 0 | 792 | July 21, 2021 | |
| OpenGL Performance Problem Mapping to Pbo Decreases Performance | 0 | 1521 | January 10, 2008 | |
| GL_OVR_Multiview performance | 11 | 1471 | October 18, 2021 | |
| Performance Issue: Use both CUDA for Deep Learning and OpenGL for Rendering | 12 | 1753 | June 22, 2019 | |
| Performance Regression after upgrade from Ubuntu Lucid to Trusty | 2 | 1189 | October 25, 2014 | |
| Poor OpenGL rendering : software mode ? | 6 | 4089 | December 21, 2012 |
