openmp orphaned-style programming model
I am considering using PGI Accelerator for improving my code performance. I wonder if it is possible to use an openmp orphaned-directive style. From the post:
https://forums.developer.nvidia.com/t/pgi-accelerator-programming-concepts-questions/132001/1
I guess that the reflected directice should help.
In particular, I would like to move data only at the beginning of the whole computation and to move back them at the end. To achieve this I should have:
  1. the main program opens data region and performs loops (or similar parts) using acc regions.
  2. the main program also contains subroutine calls. If I understand well,
    subroutine must have explicit interface (I would use modules for that) and reflected directives for dummy arguments. Is it possible to acc regions inside subroutines in this way? (using 11.0)
  3. What about variables inside subroutines which are not passed trough actual-dummy arguments?
    3.a) automatic variables: may I use “device resident” directive for that variables (to avoid the cpu creation)?
    3.b) device variables in modules: can I use them? how?
thank you for help!
Francesco
Hi Francesco,
  1. the main program also contains subroutine calls. If I understand well,
The only caveat to using reflected is if you have multiple levels of subroutine calls, each level must use the reflected directive.
  1. What about variables inside subroutines which are not passed trough actual-dummy arguments?
If the variables are module allocatable arrays, then you can use the ‘mirrored’ directive. When you allocate a ‘mirrored’ array, the array is allocated both on the host and the device. You then manage the data movement using the ‘update host’ and ‘update device’ directives.
Yes, however “device resident” and the other new directives are still in development so wont be available until later this year.
Use the ‘mirrored’ directive.
Hope this helps,
Mat
thank you for the fast and useful reply. According to what you told me,
I am considering to use the mirror directive for module variables.
In particular, if a have arrays in the module and
scalar variables in the same module, I would write something like that:
module storage
   integer, parameter :: N=1000
   real, dimension(:,:), allocatable :: A,B,C
   real k_scalar
   real startTime,endTime
end module storage
subroutine matadd_sub()
   use storage  ; implicit none  ; integer i,j,k
!$acc region
!$acc do
   do i=1,N  ; do j=1,N  ; do k=1,N
      k_scalar = A(i,j) + B(i,j)
      C(i,j) = k_scalar
   enddo     ; enddo     ; enddo
!$acc end region
end subroutine matadd_sub
subroutine matmul_sub()
!$acc region
!$acc do
      C(i,j) = 3+C(i,j)
!$acc end region
end subroutine matmul_sub
program matadd
   allocate(A(N,N),B(N,N),C(N,N))
   A = 1.  ; B = 2.  ; C = 0.
!$acc data region mirror(A,B,C,N)
!$acc update device(A,B)
   call matadd_sub()
   call matmul_sub()
!$acc update host(C)
!$acc end data region
   print*,"C: ",C(6,3)
!   print*,"k:  ",k
end program matadd
  1. My problem is that I did not understand how to control when data
    are updated to device or host.
    When opening data region data seem to be automatically updated to device,
    even without specifying update device(A,B), is it? or maybe it happens
    in acc region opening. Second, also deleting the update host statement
    the code is ok.
More specifically, I would need to update to host ONLY some data and at a
CHOSEN time without closing the data region because I need to send them
using MPI subroutines.
  1. May I use static arrays or scalar variables in modules and mirror
    them avoiding, if needed, the host updating (so they work as local variables)?
I am using PGI 10.8 for now.
thank you very much for any help!
Francesco
Hi Francesco,
You’ll need to update your compiler since ‘mirrored’ was added in the 11.0 compilers.
    the code is ok.
When you use mirrored, it is not part of a data region clause, rather it’s applied to the variable at the point it’s declared in the module. I’ve corrected the code (see below).
An update may occur any time while running from host code (i.e. any time outside of a compute region). It does not need to occur within a data region.
No, mirrored only works with allocatables.
Note that I also modified the directives a bit to help with performance.
Hope this helps.,
Mat
% cat test.f90
module storage
!$acc mirror(A,B,C)
end module storage
!contains
   use storage; implicit none  ; integer i,j,k
   real k_scalar
!$acc region
   do i=1,N  ; do j=1,N
!$acc do seq
 do k=1,N
      C(i,j) = k_scalar
!$acc end region
!$acc region
!$acc do seq
do k=1,N
      C(i,j) = 3+C(i,j)
!$acc end region
program matadd
   call matadd_sub()
   call matmul_sub()
   print*,"C: ",C(6,3)
!   print*,"k:  ",k
end program matadd
% pgf90 -ta=nvidia,time -Minfo -V11.1 -fast test.f90 -o test_gpu.out
matadd_sub:
     13, Generating compute capability 1.0 binary
         Generating compute capability 1.3 binary
         Generating compute capability 2.0 binary
     14, Loop is parallelizable
     16, Loop carried reuse of 'c' prevents parallelization
         Accelerator kernel generated
         14, !$acc do parallel, vector(16) ! blockidx%y threadidx%y
             !$acc do parallel, vector(16) ! blockidx%x threadidx%x
             Using register for 'c'
             Using register for 'a'
             Using register for 'b'
         16, !$acc do seq
             CC 1.0 : 17 registers; 48 shared, 12 constant, 0 local memory bytes; 33% occupancy
             CC 1.3 : 17 registers; 48 shared, 12 constant, 0 local memory bytes; 75% occupancy
             CC 2.0 : 27 registers; 8 shared, 56 constant, 0 local memory bytes; 66% occupancy
matmul_sub:
     25, Generating compute capability 1.0 binary
     26, Loop is parallelizable
     28, Complex loop carried dependence of 'c' prevents parallelization
         Loop carried dependence of 'c' prevents parallelization
         Loop carried backward dependence of 'c' prevents vectorization
         26, !$acc do parallel, vector(16) ! blockidx%y threadidx%y
         28, !$acc do seq
             CC 1.0 : 10 registers; 32 shared, 12 constant, 0 local memory bytes; 100% occupancy
             CC 1.3 : 10 registers; 32 shared, 12 constant, 0 local memory bytes; 100% occupancy
             CC 2.0 : 14 registers; 8 shared, 40 constant, 0 local memory bytes; 100% occupancy
matadd:
     38, Memory set idiom, array assignment replaced by call to pgf90_mset4
         Memory zero idiom, array assignment replaced by call to pgf90_mzero4
     39, Generating !$acc update device(b(:,:))
         Generating !$acc update device(a(:,:))
     42, Generating !$acc update host(c(:,:))
% test_gpu.out
 C:     3003.000
Accelerator Kernel Timing data
/tmp/qa/test.f90
  matmul_sub
    25: region entered 1 time
        time(us): total=7684
                  kernels=7573 data=0
        28: kernel launched 1 times
            grid: [63x63]  block: [16x16]
            time(us): total=7573 max=7573 min=7573 avg=7573
/tmp/qa/test.f90
  matadd_sub
    13: region entered 1 time
        time(us): total=416
                  kernels=285 data=0
        16: kernel launched 1 times
            time(us): total=285 max=285 min=285 avg=285
/tmp/qa/test.f90
  matadd
    35: region entered 1 time
        time(us): total=137905 init=121907 region=15998
                  data=2827
        w/o init: total=15998 max=15998 min=15998 avg=15998
