this is a repost of a bug I recently reported for flang:
It affects PGI 17.10 in the same way as flang, therefore I also report it here.
Test case:
program omp_bug
integer, parameter :: cnt = 100
integer, pointer :: bnd(:,:)
integer, pointer :: chamber(:)
integer :: i, c
allocate(bnd(1:2,cnt))
do i = 1, cnt
bnd(1:2, i) = (/ i, i+1 /)
end do
allocate(chamber(1:cnt+1), source=0)
!$omp parallel do private(i)
do i = 1,cnt
chamber(bnd(1:2,i)) = 1
end do
!$omp end parallel do
do i = 1, cnt+1
c = chamber(i)
if (c <= 0) then
print *, i, c
call abort()
end if
end do
end
Compiling this with ‘flang -mp’ and executing with OMP_NUM_THREADS>1 yields errors like:
39 0
Aborted (core dumped)
The first number varies, the second is always zero, so apparently something goes wrong in the loop that sets the chamber array.
It runs through error-free with OMP_NUM_THREADS=1 or when making one of the POINTERs an ALLOCATABLE. Moreover it runs fine with gfortran and ifort (also multi-threaded).
We have replicated the behavior of your program, and we have logged this
as TPR 25053. Your submission to github was a little different, enough
to give this a unique TPR number.
Huh, really? I actually meant to repost the exact same code, just to make sure that this bug also makes it into the PGI bug database. (I have no insight on how you guys manage the development of the flang and PGI compilers, and wanted to be on the safe side here.)
I fully agree that for my simple reduced example above, using ALLOCATABLEs would be more reasonable than POINTERs. Nevertheless one can of course construct other examples where the use of POINTERs makes more sense.
In any case, PGI’s behavior here is clearly a bug that needs to be fixed.
