# Opensm run failed
**URL:** <https://forums.developer.nvidia.com/t/opensm-run-failed/342228>\
**Category:** Mellanox OFED\
**Created:** [August 15, 2025, 6:01pm UTC](https://forums.developer.nvidia.com/t/opensm-run-failed/342228 "2025-08-15T18:01:47Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![glen.yoon1](https://developer.download.nvidia.com/images/forums/profile-default-devtalk-84.png) [@glen.yoon1](https://forums.developer.nvidia.com/u/glen.yoon1)\
**Post date:** [August 15, 2025, 6:01pm UTC](https://forums.developer.nvidia.com/t/opensm-run-failed/342228/1 "2025-08-15T18:01:48Z")
</div>
OS : ubuntu 24.04.1 (6.14.0-27-generic)
OpenSM : 5.23.00.MLNX20250423.ac516692
HCA : 900-9X81E-00EX-STO
I’m trying to enable two HCA back-to-back connection, each HCA is installed into a separated server.
ibstat shows the below
Host#0
CA ‘mlx5\_0’
CA type: MT4131
Number of ports: 1
Firmware version: 40.45.1200
Hardware version: 0
Node GUID: 0x5000e60300a4f6cc
System image GUID: 0x5000e60300a4f6cc
Port 1:
**State: Initializing**
Physical state: LinkUp
Rate: 400
Base lid: 65535
LMC: 0
SM lid: 0
Capability mask: 0xa751ec48
Port GUID: 0x5000e60300a4f6cc
Link layer: InfiniBand
Host#1
CA ‘mlx5\_0’
CA type: MT4131
Number of ports: 1
Hardware version: 0
Node GUID: 0x5000e60300b9f66a
System image GUID: 0x5000e60300b9f66a
Port 1:
Rate: 400
Base lid: 65535
LMC: 0
SM lid: 0
Port GUID: 0x5000e60300b9f66a
It shows link state stuck in Initializing and when I run opensm from one of host, opensm failed with error below.
OpenSM 5.23.00.MLNX20250423.ac516692
Using default GUID 0x5000e60300a4f6cc
Entering DISCOVERING state
Error from osm\_opensm\_bind (0x2A)
Perhaps another instance of OpenSM is already running
Exiting SM
I have searched this forum and googling but I couldn’t find any solution for me.
Does anyone have similar issue or solution?
**Author:** ![ycarmeli](https://developer.download.nvidia.com/images/forums/profile-default-devtalk-84.png) [@ycarmeli](https://forums.developer.nvidia.com/u/ycarmeli)\
**Post date:** [August 18, 2025, 8:11am UTC](https://forums.developer.nvidia.com/t/opensm-run-failed/342228/2 "2025-08-18T08:11:39Z")
</div>
> [@glen.yoon1](#):
> Host#1
Hi ,
let’s try on host Host#0
1. killall opensm \>\> stop SM service
2. opensm -B \>\> start SM service , do you get an error?
3. does it fix the issue? if not ?
4. systemctl status opensmd.service \>\> if active ? stop it.
5. sminfo \>\> does the SM running , does it show who is running it? Lid & Guid ?
6. If still doesn’t work , try enabke the SM on Host#1 , does the SM works or is it the same issue?
**Post date:** [August 18, 2025, 4:24pm UTC](https://forums.developer.nvidia.com/t/opensm-run-failed/342228/3 "2025-08-18T16:24:14Z")
</div>
**2. opensm -B \>\> start SM service , do you get an error?**
I got error below in /var/log/opensm.log
Aug 18 09:23:34 154404 [234DE740] 0x03 → OpenSM 5.23.00.MLNX20250423.ac516692
Aug 18 09:23:34 154485 [234DE740] 0x80 → OpenSM 5.23.00.MLNX20250423.ac516692
Aug 18 09:23:34 156855 [234DE740] 0x02 → osm\_vendor\_init: 1000 pending umads specified
Aug 18 09:23:34 156944 [234DE740] 0x02 → osm\_vendor\_init: 1000 pending umads specified
Aug 18 09:23:34 157004 [234DE740] 0x02 → osm\_vendor\_init: 1000 pending umads specified
Using default GUID 0x5000e60300b9f66a
Aug 18 09:23:34 173338 [234DE740] 0x02 → osm\_tenant\_mgr\_init: tenant mgr is disabled
Aug 18 09:23:34 173479 [234DE740] 0x02 → osm\_issu\_mgr\_init: issu\_mgr is initialized
Aug 18 09:23:34 173509 [234DE740] 0x80 → Entering DISCOVERING state
Aug 18 09:23:34 173837 [234DE740] 0x02 → osm\_vendor\_rebind: Mgmt class 0x81 binding to port GUID 0x5000e60300b9f66a
Aug 18 09:23:34 191363 [234DE740] 0x01 → osm\_vendor\_rebind: ERR 5424: Unable to open port 0x5000e60300b9f66a
Aug 18 09:23:34 191374 [234DE740] 0x01 → osm\_sm\_mad\_ctrl\_bind: ERR 3118: Vendor specific bind failed
Aug 18 09:23:34 191385 [234DE740] 0x01 → osm\_sm\_bind: ERR 2E10: SM MAD Controller bind failed (IB\_ERROR) for port guid 0x5000e60300b9f66a, port index 0
Aug 18 09:23:34 193236 [234DE740] 0x02 → osm\_tenant\_mgr\_destroy: osm\_tenant\_mgr\_destroy complete
Aug 18 09:23:34 193250 [234DE740] 0x02 → osm\_issu\_mgr\_destroy: osm\_issu\_mgr\_destroy complete
Exiting SM
**4. systemctl status opensmd.service \>\> if active ? stop it.**
\u25cb opensmd.service - OpenSM
Loaded: loaded (/usr/lib/systemd/system/opensmd.service; disabled; preset: enabled)
Active: inactive (dead)
**5. sminfo \>\> does the SM running , does it show who is running it? Lid & Guid ?**
ibwarn: [13873] get\_smi\_gsi\_pair: Can’t open UMAD port (No such device) ((null):0)
ibwarn: [13873] mad\_rpc\_open\_port2: can’t open UMAD port ((null):0)
sminfo: iberror: failed: Failed to open ‘(null)’ port ‘0’
Tried to both host and it still doesn’t work.
Thanks,
Glen
**Post date:** [August 20, 2025, 6:23am UTC](https://forums.developer.nvidia.com/t/opensm-run-failed/342228/4 "2025-08-20T06:23:54Z")
</div>
> [@glen.yoon1](#):
> 5.23
Hi, Try to reinstall OFED on one of the hosts and see if that resolves the issue. [Linux InfiniBand Drivers](https://network.nvidia.com/products/infiniband-drivers/linux/mlnx_ofed/)
