I’m trying OpenStack Icehouse ML2 w/ SR-IOV (VLAN) on CentOS7 and ConnectX-3 cards (40gE):
(1) Mellanox-Neutron-Icehouse-Redhat-Ethernet - OpenStack Mellanox-Neutron-Icehouse-Redhat-Ethernet - OpenStack
(2) Nova-neutron-sriov - OpenStack Nova-neutron-sriov - OpenStack
(3) Mellanox OFED Driver Installation and Configuration for SR-IOV https://community.mellanox.com/s/article/mellanox-ofed-driver-installation-and-configuration-for-sr-iov
After setting SR-IOV w/ ConnectX-3 while following (3), I also verified that vlan is working among systems.
I installed OpenStack Icehouse using packstack on single node (all-in-one).
And then, I modified all the configurations for SR-IOV while following (1), except /etc/neutron/dhcp_agent.ini.
I fixed the interface_driver from BridgeInterfaceDriver to OVSInterfaceDriver in /etc/neutron/dhcp_agent.ini.
Even though VM can get the DHCP IP, host and VM can’t ping each other.
[root@gpu6 ~(keystone_admin)]# cat /etc/modprobe.d/mlx4_core.conf
options mlx4_core port_type_array=2,2 num_vfs=16 probe_vf=0 enable_64b_cqe_eqe=0 log_num_mgm_entry_size=-1
[root@gpu6 ~(keystone_admin)]# neutron net-list
| id | name | subnets |
| 1c555886-f026-4727-a2e6-99913e383bf2 | net40g | afdeec0e-6b9f-421a-9a5b-421a77c283d8 192.168.2.0/24 |
[root@gpu6 ~(keystone_admin)]# neutron subnet-list
| id | name | cidr | allocation_pools |
| afdeec0e-6b9f-421a-9a5b-421a77c283d8 | demo-subnet | 192.168.2.0/24 | {“start”: “192.168.2.2”, “end”: “192.168.2.254”} |
[root@gpu6 ~(keystone_admin)]# neutron port-list
| id | name | mac_address | fixed_ips |
| 385600c0-fafa-4e15-b0b4-83f780e26daf | | fa:16:3e:ce:2b:5f | {“subnet_id”: “afdeec0e-6b9f-421a-9a5b-421a77c283d8”, “ip_address”: “192.168.2.2”} |
| 9a291386-c020-4cfd-9e11-bc98fa418566 | | fa:16:3e:90:d8:bc | {“subnet_id”: “afdeec0e-6b9f-421a-9a5b-421a77c283d8”, “ip_address”: “192.168.2.1”} |
| e0f81bbb-2da3-4ba0-9bba-3f90a79fd9a7 | sriov_port | fa:16:3e:8b:83:76 | {“subnet_id”: “afdeec0e-6b9f-421a-9a5b-421a77c283d8”, “ip_address”: “192.168.2.7”} |
[root@gpu6 ~(keystone_admin)]# ip netns
qdhcp-1c555886-f026-4727-a2e6-99913e383bf2
qrouter-4d297bce-3888-4036-9b63-e61028f9ff8f
[root@gpu6 ~(keystone_admin)]# ip netns exec qdhcp-1c555886-f026-4727-a2e6-99913e383bf2 ping -c1 192.168.2.2
PING 192.168.2.2 (192.168.2.2) 56(84) bytes of data.
64 bytes from 192.168.2.2: icmp_seq=1 ttl=64 time=0.027 ms
— 192.168.2.2 ping statistics —
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 0.027/0.027/0.027/0.000 ms
[root@gpu6 ~(keystone_admin)]# ip netns exec qdhcp-1c555886-f026-4727-a2e6-99913e383bf2 ping -c1 192.168.2.1
PING 192.168.2.1 (192.168.2.1) 56(84) bytes of data.
64 bytes from 192.168.2.1: icmp_seq=1 ttl=64 time=0.495 ms
— 192.168.2.1 ping statistics —
rtt min/avg/max/mdev = 0.495/0.495/0.495/0.000 ms
[root@gpu6 ~(keystone_admin)]# ip netns exec qdhcp-1c555886-f026-4727-a2e6-99913e383bf2 ping -c1 192.168.2.7
PING 192.168.2.7 (192.168.2.7) 56(84) bytes of data.
^C
— 192.168.2.7 ping statistics —
1 packets transmitted, 0 received, 100% packet loss, time 0ms
VM also can’t ping 192.168.2.1 or 192.168.2.2, except own IP, 192.168.2.7.
VM’s lspci result is as follows:
00:04.0 Network controller [0280]: Mellanox Technologies MT27500 Family [ConnectX-3 Virtual Function] [15b3:1004]
00:05.0 Network controller [0280]: Mellanox Technologies MT27500 Family [ConnectX-3 Virtual Function] [15b3:1004]
[root@gpu6 ~(keystone_admin)]# ovs-vsctl show
af9350bf-af96-4fac-adf5-0cd665e1215e
Bridge br-int
fail_mode: secure
Port “qr-9a291386-c0”
tag: 1
Interface “qr-9a291386-c0”
type: internal
Port int-br-ex
Interface int-br-ex
Port “int-br-ens4”
Interface “int-br-ens4”
Port “tap385600c0-fa”
tag: 1
Interface “tap385600c0-fa”
type: internal
Port br-int
Interface br-int
type: internal
Bridge “br-ens4”
Port “br-ens4”
Interface “br-ens4”
type: internal
Port “ens4”
Interface “ens4”
Port “phy-br-ens4”
Interface “phy-br-ens4”
ovs_version: “2.1.3”
[root@gpu6 ~(keystone_admin)]# ovs-ofctl show br-int
OFPT_FEATURES_REPLY (xid=0x2): dpid:0000029b05424542
n_tables:254, n_buffers:256
capabilities: FLOW_STATS TABLE_STATS PORT_STATS QUEUE_STATS ARP_MATCH_IP
actions: OUTPUT SET_VLAN_VID SET_VLAN_PCP STRIP_VLAN SET_DL_SRC SET_DL_DST SET_NW_SRC SET_NW_DST SET_NW_TOS SET_TP_SRC SET_TP_DST ENQUEUE
25(tap385600c0-fa): addr:00:00:00:00:00:00
config: PORT_DOWN
state: LINK_DOWN
speed: 0 Mbps now, 0 Mbps max
26(qr-9a291386-c0): addr:00:00:00:00:00:00
config: PORT_DOWN
state: LINK_DOWN
29(int-br-ex): addr:ee:06:9e:4b:9e:62
config: 0
state: 0
current: 10GB-FD COPPER
speed: 10000 Mbps now, 0 Mbps max
30(int-br-ens4): addr:6e:aa:42:99:af:d2
config: 0
state: 0
LOCAL(br-int): addr:02:9b:05:42:45:42
config: 0
state: 0
OFPT_GET_CONFIG_REPLY (xid=0x4): frags=normal miss_send_len=0
[root@gpu6 ~(keystone_admin)]# ovs-ofctl show br-ens4
OFPT_FEATURES_REPLY (xid=0x2): dpid:000024be05820470
1(ens4): addr:24:be:05:82:04:70
config: 0
state: 0
current: AUTO_NEG
advertised: AUTO_NEG AUTO_PAUSE
supported: FIBER AUTO_NEG AUTO_PAUSE AUTO_PAUSE_ASYM
11(phy-br-ens4): addr:b6:07:55:f6:42:7c
config: 0
state: 0
LOCAL(br-ens4): addr:24:be:05:82:04:70
config: 0
state: 0
Could you please let me know what I shol check for this problem?
