openSUSE 11 driver install problem
Running as root at bootlevel 3:
sh NVIDIA-Linux-x86_64-180.06-pkg2.run
The Nvidia installer complains that it cannot find: /lib/modules/2.6.25.5-1.1-default/build/include/linux/kernel.h and suggests I use the --kernel-source-path option. So I find the only occurance of kernel.h is in /usr/include/linux. Tried the command:
sh NVIDIA-Linux-x86_64-180.06-pkg2.run --kernel-source-path=/usr/include/linux
and get the same message as without the option. Looked through Nvidia driver install information and can’t find anything. Not sure if this is an OS problem, Nvidia problem or skippy problem.
skippy
You need to install the kernel source RPM that ships with OpenSUSE-11.0.
Thanks, skippy
