I bought a dell g7 with 1060GTX mobile and optimus technologies. Three months later I caught up on reading and see that optimus is not very well supported on linux. So at manufacturer suggestion I st it up for prime switching. On the 410.6 driver I was getting around 20,000fps on glx gears.
https://photos.google.com/photo/AF1QipOJwP-ln4l7ovYrtEkruhILTbP7gehxYMUKPDc
Today I just upgraded to 410.73 and my results are:
daryl@G7:~> inxi -G
Graphics:
Device-1: Intel driver: i915 v: kernel
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] driver: nvidia v: 410.73
Display: x11 server: X.Org 1.20.2 driver: modesetting FAILED: nvidia
resolution: 1920x1080~60Hz
OpenGL: renderer: llvmpipe (LLVM 6.0 256 bits) v: 3.3 Mesa 18.1.7
daryl@G7:~> glxgears
10782 frames in 5.0 seconds = 2156.336 FPS
11517 frames in 5.0 seconds = 2303.386 FPS
XIO: fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
after 87670 requests (87668 known processed) with 0 events remaining.
daryl@G7:~>
Is there anything I can provide that may explain the near 10x loss in performance?
Saw this in /var/log/Xorg.0.log:
19.937] (II) Module fb: vendor="X.Org Foundation"
[ 19.937] compiled for 1.20.2, module version = 1.0.0
[ 19.937] ABI class: X.Org ANSI C Emulation, version 0.4
[ 19.950] (==) modeset(G0): Backing store enabled
[ 19.950] (==) modeset(G0): Silken mouse enabled
[ 19.989] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[ 19.990] (==) modeset(G0): DPMS enabled
[ 19.990] (WW) modeset(G0): Option "AllowEmptyInitialConfiguration" is not used
[ 19.990] (WW) modeset(G0): Option "UseDisplayDevice" is not used
[ 19.991] (II) modeset(G0): [DRI2] Setup complete
[ 19.991] (II) modeset(G0): [DRI2] DRI driver: i965
[ 19.991] (II) modeset(G0): [DRI2] VDPAU driver: i965
[ 19.992] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[ 19.992] (II) NVIDIA: access.
[ 19.998] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 19.998] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 19.998] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 19.998] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 19.998] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 19.998] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 19.998] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 19.998] (II) NVIDIA(0): Config Options in the README.
[ 20.011] (II) NVIDIA(0): Setting mode "NULL"
[ 20.014] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 20.014] (==) NVIDIA(0): Backing store enabled
[ 20.014] (==) NVIDIA(0): Silken mouse enabled
[ 20.014] (==) NVIDIA(0): DPMS enabled
[ 20.014] (II) Loading sub module "dri2"
[ 20.014] (II) LoadModule: "dri2"
[ 20.014] (II) Module "dri2" already built-in
[ 20.014] (II) NVIDIA(0): [DRI2] Setup complete
[ 20.014] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 20.014] (II) Initializing extension Generic Event Extension
[ 20.014] (II) Initializing extension SHAPE
[ 20.014] (II) Initializing extension MIT-SHM
[ 20.014] (II) Initializing extension XInputExtension
[ 20.015] (II) Initializing extension XTEST
[ 20.015] (II) Initializing extension BIG-REQUESTS
[ 20.015] (II) Initializing extension SYNC
[ 20.015] (II) Initializing extension XKEYBOARD
[ 20.015] (II) Initializing extension XC-MISC
[ 20.015] (II) Initializing extension SECURITY
[ 20.016] (II) Initializing extension XFIXES
[ 20.016] (II) Initializing extension RENDER
[ 20.016] (II) Initializing extension RANDR
[ 20.016] (II) Initializing extension COMPOSITE
[ 20.016] (II) Initializing extension DAMAGE
[ 20.016] (II) Initializing extension MIT-SCREEN-SAVER
[ 20.017] (II) Initializing extension DOUBLE-BUFFER
[ 20.017] (II) Initializing extension RECORD
[ 20.017] (II) Initializing extension DPMS
[ 20.017] (II) Initializing extension Present
[ 20.017] (II) Initializing extension DRI3
[ 20.017] (II) Initializing extension X-Resource
[ 20.017] (II) Initializing extension XVideo
[ 20.018] (II) Initializing extension XVideo-MotionCompensation
[ 20.018] (II) Initializing extension GLX
[ 20.018] (II) AIGLX: Screen 0 is not DRI2 capable
[ 20.344] (II) IGLX: Loaded and initialized swrast
[ 20.344] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 20.344] (II) Initializing extension XFree86-VidModeExtension
[ 20.345] (II) Initializing extension XFree86-DGA
[ 20.345] (II) Initializing extension XFree86-DRI
[ 20.345] (II) Initializing extension DRI2
[ 20.346] (II) Initializing extension NV-GLX
[ 20.347] (II) Initializing extension NV-CONTROL
[ 20.465] (II) modeset(G0): Damage tracking initialized
[ 20.530] randr: falling back to unsynchronized pixmap sharing
[ 22.434] (II) config/udev: Adding input device Power Button (/dev/input/event6)
[ 22.434] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 22.434] (**) Power Button: Applying InputClass "system-keyboard"
[ 22.434] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 22.434] (II) LoadModule: "libinput"
[ 22.434] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[ 22.439] (II) Module libinput: vendor="X.Org Foundation"
[ 22.439] compiled for 1.20.2, module version = 0.28.1
[ 22.439] Module class: X.Org XInput Driver
[ 22.439] ABI class: X.Org XInput driver, version 24.1
Link to yast hardware report:
https://drive.google.com/open?id=1UWASv5ajKUldPsZCbU2tDVVq3NEKZykQ
