Openvx/Visionworks graph input from GPU memory Buffer
Hi Jeffli,
Thank you for your answer,
Will it works though ? The original layer that does the problematic correllation is a conv2d in pytorch, and a simple conv in the onnx conversion which should be supported by tensorrt according to Support Matrix :: NVIDIA Deep Learning TensorRT Documentation
Before engaging costly and risky developpement I would like to be sure that the custom layer will act better than the original one. Why is the operation not supported when applying convolution using a dynamic kernel ?
If you want to reproduce the problem you can find here the head of the onnx that I am trying to convert using trtexec.
rpn_head_2.onnx (28.6 MB)
The exact command line used to do so is:
trtexec --onnx=<…>/rpn_head_2.onnx --saveEngine=<…>/rpn_head_2.engine --shapes=input_1:3x1x256x7x7,input_2:3x1x256x31x31 --verbose
I tried with part of the model and the full model for the same results, tensorrt converter fails while counting 0 weight for this kernel (which partially make sense since the weight comes from the second input)
By the way this issue is almost identical to the problem mentionned here:
but does not have a solution yet. The cross-convolution layer is in the core of the network and can not be efficiently replaced.
