Optee on startup
hi
i made a trusted application base on op-tee with the name of test_app and it work fine when i test it by sudo test_app in terminal .
i just want to run this application on startup before GUI coming up
i cant make a service to run in startup because it is accessible by third party users and they can modify services and delete it .
i want to do something that nobody couldn’t delete it from boot sequence without system failure .
can you help me about it ?
hello rabanimisagh,
could you please try adding a service within /etc/systemd/system?
