Hello everyone,
I’m using Jetpack 5.0.2
/ L4T R 35.1
and I’m building OPTEE
(OS , Client , Samples and Test ) from sources Linux_for_Tegra/source/public/nvidia-jetson-optee-source.tbz2
I’m using GCC version 12.2.0 . When running the xtest
(OPTEE test suite), I noticed the CPU hangs for a moment then system reboot
Kindly see the logs below:
��[ 368.162281] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 368.162499] rcu: 0-...0: (2 GPs behind) idle=78e/1/0x4000000000000000 softirq=1712/1713 fqs=2626
[ 368.162791] (detected by 3, t=5252 jiffies, g=1997, q=22)
[ 368.162968] Task dump for CPU 0:
[ 368.163076] task:xtest state:R running task stack: 0 pid: 754 ppid: 741 flags:0x00000202
[ 368.163381] Call trace:
[ 368.163475] __switch_to+0xc8/0x120
[ 368.163602] __alloc_pages_nodemask+0x140/0xe40
[ 368.163770] pool_op_alloc+0x44/0x180
[ 368.163887] 0xffff24b3462c6000
[ 368.163980] 0x1bc5d5a502009ead
Any idea about the cause of the CPU hanging ?
Any help would be appreciated.
Best regards,
Ilies
Need take time to check it.
Will update it once get response.
Hey @ShaneCCC
Thanks for your reply. Much appreciated
Please take your time and let me know if you need additional information.
Hello @ShaneCCC
Any updates about this issue ?
@ilies.chergui
Sorry, we are investigating it.
kayccc
October 12, 2022, 2:44am
#9
The updated toolchain has been posted in Jetson downloads page, please help to get it a try. Thanks
Could you please share the link ? if I’m not mistaken, it is still Bootlin Toolchain gcc 9.3 . It is not updated FYI.
As I mentioned in this topic help is needed for toolchain which is using gcc-12.x.y
and bintutils 2.39
Did you apply any patches to the OPTEE sources ? if so, please share the pachtes and I can try them
Thanks for you help
DaneLLL
October 13, 2022, 2:06am
#12
Hello @DaneLLL @kayccc @ShaneCCC
I think that you didn’t understand my request here.
I tried the toolchain you provide and it works fine. My issue is related to new toolchain and this is a blocker for us (OE4T community ) to moving forward.
My PR is still pending because of the issue I shared with you in this topic.
Could you please try with this toolchain ?
Any help from your side would much appreciated
Ilies
DaneLLL
October 24, 2022, 1:31am
#16
Are you able to use the toolchain we provide? It is the version we use and would suggest forum users use the same version.
Hello @DaneLLL
I was able to try the toolchain you provide and it works fine.
FYI, we have fixed the issue in our meta-tegra layer. Many thanks to @madisox
Please close this topic.
Ilies
system
Closed
November 16, 2022, 4:23am
#19
