I don’t have anymore the exact script I did to test this last month, but it was basically the example from the doc VPI - Vision Programming Interface: Pyramidal LK Optical Flow . The only add is the reset of the tracker at the end of the loop.
### tried to update the tracker with fresh features, but they are quickly lost
curFeatures, scores = frame.harriscorners(strength=0.1, sensitivity=0.01)
optflow = vpi.OpticalFlowPyrLK(frame, curFeatures, 4)
The script shown in my previous post illustrates exactly that and should work (just add the import and camera initialization and it will run)
However I’m facing an issue. As my camera is moving, I need to constantly provide new features to track. But I wasn’t able to do that:
- trying to pass new features to
optflow(frame ,newFeatures)
only overwritenewFeatures
with results- trying to reset at each frame the tracking by creating each time a new
make the tracking lose almost all features in few seconds with no apparent reason (with a static camera), in addition to divide by 10 the performances…I can’t find why. Is there a better way to do this? Or do you understand why the tracking is lost without reason?
with vpi.Backend.CUDA: optflow = None while 1: image = camera.getImage() frame = vpi.asimage(image, vpi.Format.BGR8).convert(vpi.Format.U8) if optflow is None: curFeatures, scores = frame.harriscorners(strength=0.1, sensitivity=0.01) optflow = vpi.OpticalFlowPyrLK(frame, curFeatures, 4) else: prevFeatures = curFeatures curFeatures, status = optflow(frame) # ,newFeatures) # seem to use newFeatures as result container print("% tracker lost:", status.cpu().nonzero()[0].shape[0]/(curFeatures.size+1)) ### tried to update the tracker with fresh features, but they are quickly lost curFeatures, scores = frame.harriscorners(strength=0.1, sensitivity=0.01) optflow = vpi.OpticalFlowPyrLK(frame, curFeatures, 4)
derived from vpi example: VPI - Vision Programming Interface: Pyramidal LK Optical Flow
Notes:
- I removed the feature filtering present in the example, as it was harming the performances without benefice
- removing context switches from the loop (ex:
) greatly improve performancesDo you have any îdea of what I am doing wrong? Or how to get a continuous tracking with a moving camera using this implementation?
Thank you for your help
edit : I just did a test with opencv
calcOpticalFlowPyrLK
withgoodFeaturesToTrack
using the same strategy (resetting markers each frame), and it works great. Also, to my surprise, I reached similar performances than the cuda vpi implementation while I’m pretty sure it runs on CPU. I may stick with the raw opencv approach if we can’t find the issue with my vpi test
