• Hardware Platform (Jetson / GPU) T1000
• DeepStream Version 5.2
• TensorRT Version 8.4
• NVIDIA GPU Driver Version (valid for GPU only) 550
• Issue Type( questions, new requirements, bugs) bugs
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) gst with optical flow
Is T1000 a valid Turing GPU ? When I test my gst pipeline, it yields errors about the optical flow. After I remove the element of optical flow, everything works.
Then when we check T1000, it seems a turning generation of Turing. I wonder whether it is something that I am doing wrong or T1000 just has no support on optical flow?
0:00:14.369173334 26 0x25ddf60 WARN nvof gstnvof.cpp:871:gst_ds_optical_flow_transform_ip:<XXXX> Failed to create OpticalFlow context
0:00:14.369217441 26 0x25ddf60 WARN nvinfer gstnvinfer.cpp:2300:gst_nvinfer_output_loop:<XXXX> error: Internal data stream error.
0:00:14.369224729 26 0x25ddf60 WARN nvinfer gstnvinfer.cpp:2300:gst_nvinfer_output_loop:<XXXXX> error: streaming stopped, reason error (-5)
Error: A batch of multiple frames received from the same source.
Set sync-inputs property of streammux to TRUE.
