Optics
Yesterday’s webinar revealed some solutions that work with jetson nano:
I understand that lenses above rather need custom arducam raspberri v2 board with M12 mount rather than the default raspberry v2 board.
External Media
The default raspberry V2 camera board uses the stock lens which is M7.
If you want to use M12 or CS/C mount lens you need the following 8MP IMX219 camera board.
https://www.uctronics.com/index.php/catalogsearch/result/?q=jetson
https://www.uctronics.com/index.php/catalogsearch/result/?q=0550
There are also lens kits, especially the low distrotions lenses.
and standard wide range lens kit:
probably any lenses from here lens
work with any board from here Search results for: 'jetson'
Yes, the lenses in the lens kit are carefully selected and tested for IMX219, you can find the user guide from the listing.
The lens kit user guid is here
and single lenses?
will every single lense work with any board from the url
OR there are some single lenses that will not work with some of these boards?
I can see single lenses list at lens
are they all compatible with the jetson nano boards listed via the url above?
Yes, they are. But should be carefully selected from application to application in terms of the FOV, optical format and etc.
