I’ve got a 960M running on Arch Linux.
Currently I use bumblebee to launch all my games, however I do not feel like this is an optimal solution as
So far the only alternative I’ve found has been nvidia-xrun, which I use on a free tty to launchy a new x server, so everything runs on the dGPU.(I think this uses the PRIME sync feature which is stickied)
I really dislike this as this doesn’t integrate well with the GNOME DE. (A more optimal solution would be for instance to get a menu option in GDM for running the x server on dGPU).
Any suggestions on how to optimise the setup?
Thank you,
Will
