What is the optimal loop blocking factor (Tile Size or Block Size) decided by pgcc when performing loop tiling or loop blocking. Does pgcc use any internal heuristics for deciding the optimal block or tile size or is it hardcoded to some default value (51 in the case of gcc version 4.6, defined in params.def)
