Optimal Model Deployment, but priotize on max concurrency
Curious what people been deploying based on different scale of Sparks. For example 1 spark for quality it is good to serve Q3.8FN. However for max concurrency serving multuple people, qwen3.8 27b nvfp4 might be better, as I have much larger KV pool
I only have 2 sparks, model choice between Qwen3.8FN, DeepSeekV4 Flash Vision Exp, and GLM5.3Flash. Among the 3 Qwen3.8FN gives me most KV tool it seems.
What is every one using?
Deepseek v4 Flash 0731 will give you about 1.3M token KV Cache. It’s what we use on one production setup at work. Now if you have 4 nodes and run Deepseek v4.1 Flash 1017, then you can have nearly 10M KV cache.
Really? 10M KV pool? Is this with eugr’s vLLM receipt or some of the newer inferencing system like TensorFold?
Knapcio
