Here is some toy example with 32 threads per x. (I fixed your kernel in this code, you were missing synchronization before and after accessing shared memory. Your code also did not use pointer x, but always read from the base value x_head).
M = 128, 256000 vectors
Timings on my machine with Titan Xp:
Timing 1 thread per x: 0.00134403s (8000 blocks, 32 threads each)
Timing 32 threads per x: 0.000329215s (480 blocks, 128 threads each)
//nvcc -arch=sm_61 -lineinfo -g -O3 -std=c++17
#include <cassert>
#include <chrono>
#include <iostream>
#include <cooperative_groups.h>
#include <cooperative_groups/reduce.h>
#include <thrust/fill.h>
#include <thrust/execution_policy.h>
namespace cg = cooperative_groups;
__global__
void printkernel(float* C1, float* C2){
for(int i = 0; i < 10; i++){
printf("%f ", C1[i]);
printf("\n");
printf("%f ", C2[i]);
printf("\n");
template<int M>
__device__
float f(const float* x){
float result = 0;
for(int i = 0; i < M; i++){
result += expf(sin(x[i]));
return result;
template<int M, class Group>
__device__
float f(Group group, const float* x){
float result = 0;
for(int i = group.thread_rank(); i < M; i += group.size()){
result = cg::reduce(group, result, cg::plus<float>{});
return result;
template<int M>
__global__
void kernel1(const float* x_head, float* output){
__shared__ float x_cache[32][M];
constexpr auto WORK_PER_THREAD = (M + 31) / 32;
for (int i = 0;i<32;i++)
const float* x = x_head + M * (blockIdx.x * blockDim.x + i);
for(int j = 0;j<WORK_PER_THREAD;j++)
x_cache[i][j * 32 + threadIdx.x] = x[j * 32 + threadIdx.x];
__syncthreads();
float y = f<M>(&x_cache[threadIdx.x][0]);
output[blockIdx.x * blockDim.x + threadIdx.x] = y;
template<int M, int blocksize, int groupsize>
__global__
void kernel4(const float* x_head, float* output, int numX){
constexpr int numGroupsPerBlock = blocksize / groupsize;
auto group = cg::tiled_partition<groupsize>(cg::this_thread_block());
const int numGroupsInGrid = (blockDim.x * gridDim.x) / groupsize;
const int groupIdInGrid = (threadIdx.x + blockIdx.x * blockDim.x) / groupsize;
//only need 1 x array smem per group
__shared__ float x_cache[numGroupsPerBlock][M];
//each group processes processes 1 x / each block processes numGroupsPerBlock x
for(int xIndex = groupIdInGrid; xIndex < numX; xIndex += numGroupsInGrid){
//load x vector of group to smem
const float* x = x_head + M * xIndex;
for(int j = group.thread_rank(); j < M; j += group.size()){
x_cache[group.meta_group_rank()][j] = x[j];
//wait for shared memory
group.sync();
//process x vector with group
float y = f<M>(group, &x_cache[group.meta_group_rank()][0]);
if(group.thread_rank() == 0){
output[xIndex] = y;
//wait untill shared memory can be reused
group.sync();
int main(){
constexpr size_t numColumns = 128;
size_t numRows = 256000;
float* A = nullptr;
float* C1 = nullptr;
float* C2 = nullptr;
cudaMalloc(&A, sizeof(float) * numColumns * numRows);
cudaMalloc(&C1, sizeof(float) * numRows);
cudaMalloc(&C2, sizeof(float) * numRows);
thrust::fill(
thrust::device,
A,
A + numColumns * numRows,
0.01f
int deviceId = 0;
int numSMs = 0;
cudaGetDevice(&deviceId);
cudaDeviceGetAttribute(&numSMs, cudaDevAttrMultiProcessorCount, deviceId);
//32 threads per block. 1 thread per x
dim3 block1(32);
dim3 grid1((numRows + 31) / 32);
auto t1 = std::chrono::system_clock::now();
kernel1<numColumns><<<grid1, block1>>>(A, C1);
cudaDeviceSynchronize();
auto t2 = std::chrono::system_clock::now();
std::cout << "Timing 1 thread per x: " << std::chrono::duration<double>(t2 - t1).count() << "s\n";
//128 threads per block, 1 group per x
constexpr int blocksize4 = 128;
constexpr int groupsize4 = 32;
constexpr int xPerBlock4 = blocksize4 / groupsize4;
int maxBlocksPerSM4 = 0;
cudaOccupancyMaxActiveBlocksPerMultiprocessor(
&maxBlocksPerSM4,
kernel4<numColumns, blocksize4, groupsize4>,
blocksize4,
0
dim3 block4(blocksize4);
dim3 grid4(std::min(size_t(maxBlocksPerSM4) * numSMs, (numRows + xPerBlock4 - 1) / xPerBlock4));
auto t3 = std::chrono::system_clock::now();
kernel4<numColumns, blocksize4, groupsize4><<<grid4, block4>>>(A, C2, numRows);
auto t4 = std::chrono::system_clock::now();
std::cout << "Timing 32 threads per x: " << std::chrono::duration<double>(t4 - t3).count() << "s\n";
printkernel<<<1,1>>>(C1, C2);
