I capture images from MIPI camera.
I have access to the .raw pointer. I want to save images in .raw as fast as possible.
The resolution of one image is 4224*3008.
I cope with two difficulties. Below an example to explain my problem :
#include <stdio.h>
int main ()
FILE * pFile;
pFile = fopen ("file.raw", "wb");
unsigned short* buffer = new unsigned short[3008*4224];
for (int i=0 ; i<600 ; i++)
for(int j=0 ; j<3008*4224 ; j++ ){buffer[j] = i ;}
fwrite (buffer , sizeof(unsigned short), 3008*4224, pFile);
fclose (pFile);
return 0;
This sample I wrote illustrates perfectly my issues.
I expect .raw with a size of 15.2GB, and a time to write in .raw more or less constant.
I can write only 4.3GB, then the code “skip” the function fwrite(…). Anyone has already encounter this problem ?
The function is really, really slow. At the beginning, the average time is around 250ms to write one image, and after some iterations, this time is around 2200ms. Does someone has an idea ?
It is probably not the most efficient solution to write images in .raw, but I didn’t other solutions. I tested to write with openCV in .tif, it is faster than .raw but I am pretty sure that it is because I have a problem in my code.
If someone has tips, it would be great !
I am working on jetson TX2 board, which runs L4T (linux for tegra).
The file system of my sd card is ext3/Ext4:
nvidia@nvidia-desktop:~$ df -Th
Filesystem Type Size Used Avail Use% Mounted on
/dev/mmcblk0p1 ext4 28G 12G 15G 44% /
none devtmpfs 3,8G 0 3,8G 0% /dev
tmpfs tmpfs 3,9G 4,0K 3,9G 1% /dev/shm
tmpfs tmpfs 3,9G 21M 3,9G 1% /run
tmpfs tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs tmpfs 3,9G 0 3,9G 0% /sys/fs/cgroup
tmpfs tmpfs 785M 124K 785M 1% /run/user/1000
/dev/sda1 fuseblk 58G 18G 40G 32% /media/nvidia/Ubuntu
/dev/mmcblk2p1 ext4 15G 5,2G 8,7G 38% /media/nvidia/sdCard
tmpfs tmpfs 785M 0 785M 0% /run/user/0
I use nvcc compiler. I use -03 as well as -use_fast_math.
Thank you !
