Optimizing camera data publishing in python extension
Hello, i am currently developing a procedural outdoor environment for robot testing as a python extension. my scene is quite heavy and running a large amount of instances and such. My simulation was quite fine even with an OS1 lidar running in real-time.
However, after installing an RGB camera on my husky robot, my simulation became too slow. I’m currently using isaacsim.ros2.bridge with rep.writers.get(rv + “ROS2PublishImage”) to publish my camera data. I am aware that camera data is quite heavy and significantly slows down simulations.
does extracting the camera data and publishing it directly via python increase my performance by much compared to using rep.writers module and omnigraphs to do the job for me? does this also affect my performance if i were to run my simulation in headless mode?
Here is my current camera creation/publishing code for reference:
def Create_cam(self):
    from isaacsim.sensors.camera import Camera
    import numpy as np
    import isaacsim.core.utils.numpy.rotations as rot_utils
    width, height = 480,320
    camera_matrix = [[455.8, 0.0, 943.8], [0.0, 454.7, 602.3], [0.0, 0.0, 1.0]]
    distortion_coefficients = [0.05, 0.01, -0.003, -0.0005]
    pixel_size = 3  # microns
    f_stop = 1.8
    focus_distance = 0.6
    diagonal_fov = 235
    camera = Camera(
        prim_path="/World/Robot/base_link/camera",
        translation=(0, 0, 1),
        frequency=10,
        resolution=(width, height),
        orientation=rot_utils.euler_angles_to_quats(np.array([0, 90, 0]), degrees=True),
    camera.initialize()
    ((fx, _, cx), (_, fy, cy), _) = camera_matrix
    horizontal_aperture = pixel_size * 1e-3 * width
    vertical_aperture = pixel_size * 1e-3 * height
    focal_length_x = fx * pixel_size * 1e-3
    focal_length_y = fy * pixel_size * 1e-3
    focal_length = (focal_length_x + focal_length_y) / 2
    camera.set_focal_length(focal_length / 10.0)
    camera.set_focus_distance(focus_distance)
    camera.set_lens_aperture(f_stop * 100.0)
    camera.set_horizontal_aperture(horizontal_aperture / 10.0)
    camera.set_vertical_aperture(vertical_aperture / 10.0)
    camera.set_clipping_range(0.05, 1.0e5)
    camera.set_projection_type("fisheyePolynomial")
    camera.set_kannala_brandt_properties(width, height, cx, cy, diagonal_fov, distortion_coefficients)
    #Publishing to ros2
    import omni.syntheticdata._syntheticdata as sd
    import omni.graph.core as og
    render_product = camera.get_render_product_path()
    rv = omni.syntheticdata.SyntheticData.convert_sensor_type_to_rendervar(sd.SensorType.Rgb.name)
    writer = rep.writers.get(rv + "ROS2PublishImage")
    writer.initialize(
        frameId= "Base_link",
        nodeNamespace= "",
        queueSize= 1,
        topicName= "/camera/image_raw"
    writer.attach([render_product])
Any other simulation and optimization tips would be greatly appreciated
Thank you!
Hi @tleijiserge Please check out Isaac Sim Performance Optimization Handbook — Isaac Sim Documentation
