I wanted to kick off a thread documenting my journey using OpenClaw to optimize my home AI setup, with the a single DGX Spark serving as the local compute backbone. This is a constantly moving target, models, inference stacks, quantization formats, so I figured having a dedicated spot to post notes and gather community feedback would be useful for anyone else going down a similar path.
A bit of context: I’m running OpenClaw connected to a Telegram interface, with inference served via vLLM on the DGX. The goal is a responsive, locally-hosted home assistant that doesn’t depend on cloud APIs for day-to-day use.
So far I’ve tested two models with notably different results. I’ll post more detailed notes on each as follow-up replies to this thread, covering:
I have enjoyed minimax 2.7 (although it can get slow with larger contexts and ANY concurrency) - my probably keep for a while is qwen3.6 35b… it just keeps going and while it has limitations and the looping issue comes up from time to time (i built a little watchdog daemon to monitor hermes for loop and timeouts), it still is pound for pound a really solid little day to day model that can do like 75% of what i want to accomplish.
It took a bit of environment figuring. Currently in the debugging stage with this one, consistently getting around 16 T/s. The model is overly verbose regularly passing in its thought process to whatever task I am giving it. It seems capable so far but will update as I try to integrate it with more services and tools
I think this one is my next stop! Do you have any advice on quantization both weights and KV? I’ve seen some opinions that this model can work the NVFP4 but you need to keep the KV BF16 for these longer context tasks
Very interesting to me. Is there anything different between the RedHatAI/ and nvidia/ versions?
I did do a custom build of VLLM to play with CUDA 13.2 and gxx11 right before the 0.22.rc1 branch occurred, check it out here. My vllm execution process
I’m not sure, but on their page they had a specific DGX setup, unfortunately I am running into some crashing issues with the nemotron-3-super. This was caused by some of the recommended backends and KV FP8 caching it seems. Works until I run moderately long contexts. Im not going over the token limits but something is crashing during the calculations
