Hello there,
What is the optimum/minimum vcpu spec (CPU clock in MHz) and how many are required to cop with M6 or M60 4K streaming?
Thanks,
Syed
Hello there,
Thanks,
Syed
What remoting protocol are you using as they each have different CPU requirements.
for 4K I’d select the fastest clock speed possible as with the exception of Nice DCV and Mechdyne Telegraphix (which can use GPU Encode) the encoding is all done in CPU.
Hello Jason,
We are using VNC for VM access.
Thanks,
Syed
