I have a Dell E6520 with Optimus. I’m using the docking station with 2 external monitors and laptop lvds screen. I’m running Fedora 20 with the 331.104 drivers.
Bottom it works great except for some reason the monitor driven by the Nvidia card always starts off panning. I can eventually get it to stop by running the below script multiple times, but have no idea why it stops.
The way that I’m using it is using RandR to setup the additional monitors. The only setup in my xorg.conf file is the nvidia screen. I’m not sure if this is a RandR issue or something else.
Here the script I use:
output="$(xrandr --listproviders)"
src=$(echo “$output” | grep " Source" | head -n1 | awk '{print NF}' | cut -d: -f2) sink=(echo -e “$output” | grep " Sink" | head -n1 | awk ‘{print $NF}’ | cut -d: -f2)
Pass provider or sink and source
xrandr --setprovideroutputsource “$sink” “$src”
Make sure xrandr sees all the outputs
xrandr --auto
Do not move up. Only now xrandr shows the outputs
each one of these settings is determined by what connection is
enabled. use xrandr |grep -i " connected" to see what connectors are set
lvds=$(xrandr | grep -i “lvds” |grep -i " connected" | awk '{ print 1 }') dp=(xrandr | grep -i “dp” |grep -i " connected" | awk '{ print 1 }') vga=(xrandr | grep -i “vga” |grep -i " connected" | awk ‘{ print $1 }’)
xrandr --output “$lvds” --off --output “$vga” --off --output $dp --off
#xrandr --output “$lvds” --auto
#xrandr --output “$vga” --auto
#may need this first before the second one. Not sure.
#xrandr --fb 5760x1080 --output $dp --mode 1920x1080 --panning 5780x1080+0+0 --primary
xrandr --fb 1920x1080
#xrandr --fb 5760x1080 --output $dp --mode 1920x1080 --primary --output $lvds --mode 1920x1080 --right-of $dp --output $vga --mode 1920x1080 --right-of $lvds
xrandr --output $lvds --mode 1920x1080 --right-of $dp --output $vga --mode 1920x1080 --right-of $lvds
xrandr --output $lvds --mode 1920x1080 --output $vga --mode 1920x1080 --right-of $lvds --output$dp --mode 1920x1080 right-of $vga
#xrandr --output $lvds --mode 1920x1080 --right-of $dp --output $vga --mode 1920x1080 --right-of $lvds --output $dp --mode 1920x1080 --primary
xrandr --output $dp --mode 1920x1080 --primary --output $lvds --mode 1920x1080 --right-of $dp --output $vga --mode 1920x1080 --right-of $lvds
#Sometimes the $dp screen is scrolling. For some reason this prevents
it
Not needing this anymore
Here is my xorg.conf
Section “Device”
Identifier “nvidia”
Driver “nvidia”
Option “NoLogo” “true”
Option “DPI” “96 x 96”
VendorName “NVIDIA Corporation”
BoardName “NVS 4200M”
# Specify Nvidia PCI device
BusID “PCI:1:0:0”
# Make sure X starts also when no outputs are connected to the Nvidia chip
Option “AllowEmptyInitialConfiguration”
Option “ConstrainACursor” “0”
Option “PanAllDisplays” “0”
Option “nvidiaXineramaInfoOverride” “1920x1080+1280+0, 1920x1080+3840, 1920x1080+5760”
EndSection
Slave device
Section “Device”
Identifier “intel”
# Simple output, no full Intel driver
Driver “modesetting”
# BusID “PCI:0:2:0”
EndSection
Section “Screen”
Identifier “intel”
Device “intel”
EndSection
Section “Screen”
Identifier “nvidia”
Device “nvidia”
EndSection
Make sure the Nvidia device is the first in the server
Section “ServerLayout”
Identifier “layout”
Screen 0 “nvidia”
Inactive “intel”
