It looks like that ‘solution of choice’ for tearing is to enable ‘ForceFullCompositionPipeline’.
But it is a per screen setting that is not enabled by default. The problem is that when screen configuration changes this setting gets ‘forgotten’ and needs to be manually set again.
Would NVIDIA developers be so kind and add a way to specify that ‘ForceFullCompositionPipeline’ should be enabled by default on all screens? It seems like it should be possible to an option for xorg.conf to enable this setting on all screens.
