while trying to animate a height field with dynamic update to GAS, got:
Caught exception: CUDA call (cudaFree((void*)d_temp_buffer_gas) ) failed with error: 'an illegal memory access was encountered' (C:\Users\liqiu\work\xuni-ocean\Ocean\Mesh.cpp:171)
The code works properly while rotating a single triangle. However, when the number of triangles increases (to 18), optixAccelBuild returned successfully, but any subsequent cuda calls failed.
void Mesh::buildAccelerationStructure(OptixDeviceContext context)
OptixAccelBuildOptions accel_options = {};
accel_options.buildFlags = OPTIX_BUILD_FLAG_PREFER_FAST_BUILD | OPTIX_BUILD_FLAG_ALLOW_UPDATE;
accel_options.operation = OPTIX_BUILD_OPERATION_BUILD;
const uint32_t triangle_input_flags[1] = { OPTIX_GEOMETRY_FLAG_NONE };
OptixBuildInput triangle_input = {};
triangle_input.type = OPTIX_BUILD_INPUT_TYPE_TRIANGLES;
triangle_input.triangleArray.vertexFormat = OPTIX_VERTEX_FORMAT_FLOAT3;
triangle_input.triangleArray.numVertices = mVerticesSize;
triangle_input.triangleArray.vertexStrideInBytes = sizeof(Vertex);
triangle_input.triangleArray.vertexBuffers = &mdVertices;
triangle_input.triangleArray.indexFormat = OPTIX_INDICES_FORMAT_UNSIGNED_INT3;
triangle_input.triangleArray.indexStrideInBytes = 12;
triangle_input.triangleArray.numIndexTriplets = mIndicesSize / 3;
triangle_input.triangleArray.indexBuffer = mdIndices;
triangle_input.triangleArray.flags = triangle_input_flags;
triangle_input.triangleArray.numSbtRecords = 1;
OptixAccelBufferSizes gas_buffer_sizes;
OPTIX_CHECK(optixAccelComputeMemoryUsage(context, &accel_options, &triangle_input,
1, // Number of build input
&gas_buffer_sizes));
CUdeviceptr d_temp_buffer_gas;
CUDA_CHECK(cudaMalloc(reinterpret_cast<void**>(&d_temp_buffer_gas), gas_buffer_sizes.tempSizeInBytes));
// non-compacted output
CUdeviceptr d_buffer_output_gas;
&d_buffer_output_gas),
gas_buffer_sizes.outputSizeInBytes
OPTIX_CHECK(optixAccelBuild(
context,
0, // CUDA stream
&accel_options,
&triangle_input,
1, // num build inputs
d_temp_buffer_gas,
gas_buffer_sizes.tempSizeInBytes,
d_buffer_output_gas,
gas_buffer_sizes.outputSizeInBytes,
&mGasHandle,
nullptr, // emitted property list
0 // num emitted properties
CUDA_CHECK(cudaFree((void*)d_temp_buffer_gas));
mdGasOutputBuffer = d_buffer_output_gas;
void Mesh::updateAccelerationStructure(OptixDeviceContext context)
accel_options.operation = OPTIX_BUILD_OPERATION_UPDATE;
CUDA_CHECK(cudaMalloc(reinterpret_cast<void**>(&d_temp_buffer_gas), gas_buffer_sizes.tempUpdateSizeInBytes));
context,
0, // CUDA stream
&accel_options,
&triangle_input,
d_temp_buffer_gas,
gas_buffer_sizes.tempUpdateSizeInBytes,
mdGasOutputBuffer,
&mGasHandle,
