[OptiX 7] Possibilities for self-intersection with the built-in algorithm ?
the speedup I got switching from our own Polygon-intersection routines to the build-in Triangle-intersection routine is really great. It seems to be that it also fixed the initial single-precision related errors we got.
Yet, realizing there is a new problem.
We launch rays from a starting polygon. Without a large enough scene epsilon there are many self-intersections with the origin of the ray. Previously I caught these with an ID check of the primitive. Scene epsilon has the problem, that some rays just pass through other polygons/triangles which are very close to the rays origin, yet still of interest.
Taking Strange intersection issue into account I’d assume, that the best option – to keep making use of RTX features with the builtin algorithm – is to use an any-hit routine to filter out self-intersections.
Are there any other possibilities or could a self-intersection check via PrimitiveIDs be part as a feature for an upcoming OptiX version?
First, anyhit programs will call back to the streaming multiprocessors, which makes traversal slower.
In OptiX 7 you have access to the primitive ID, the instance index and the instance ID inside device code.
See “Get” functions here: https://raytracing-docs.nvidia.com/optix7/guide/index.html#device_side_functions#device-side-functions
The Raytracing Gems Part 2 Chapter 6 discusses available methods and their problems and describes a more robust solution:
https://www.realtimerendering.com/raytracinggems/
