I am trying to denoiser to my project, it said 'OptiX Error: ‘Unknown error (Details: Function
“_rtCommandListFinalize” caught exception: Could not load denoiser library.)’ when finalize, anyone knows why, thanks.
RTX 2080 isn’t supported by OptiX yet. There is a similar post not that far back about the denoiser failing on a 2080. Personally I can’t even get the ray tracing working on my 2080.
As I suspected, it does seem to have been a simple case of not linking my libraries correctly. I added lib64 to LD_LIBRARY_PATH in my .bashrc file so that it reads:
I gather the second error is when I try and hand the failed denoiser buffer to render buffer.
I also get the same -40 error when I try to run the optixDenoiser example.
I’ve yet to have a dig around for what this error code refers to, so perhaps this is the 2080 error you were talking about papaboo? I haven’t had any trouble running some of the other examples with my 2080.
Please have a look into the OptiX 5.1.1 release notes:
[i]Known Issues
Please note that the OptiX 5.1.1 SDK does not support Denoising on Turing.[/i]
The OptiX 5.1.0 version supported it, but with a comparably slow fallback because the cuDNN version used was not containing the required features for the fast path on Turing and the one in OptiX 5.1.1 does neither. The next major OptiX version will address this.
