# OptiX pipelines do not show up in Nsight Compute
**URL:** <https://forums.developer.nvidia.com/t/optix-pipelines-do-not-show-up-in-nsight-compute/254831>\
**Category:** OptiX\
**Created:** [May 29, 2023, 9:37pm UTC](https://forums.developer.nvidia.com/t/optix-pipelines-do-not-show-up-in-nsight-compute/254831 "2023-05-29T21:37:58Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![droettger](https://sea2.discourse-cdn.com/nvidia/user_avatar/forums.developer.nvidia.com/droettger/32/14043_2.png) [@droettger](https://forums.developer.nvidia.com/u/droettger)\
**Post date:** [May 30, 2023, 6:07am UTC](https://forums.developer.nvidia.com/t/optix-pipelines-do-not-show-up-in-nsight-compute/254831/2 "2023-05-30T06:07:25Z")
</div>
Depending on the display driver you’re using, you might need to set the environment variable `OPTIX_FORCE_DEPRECATED_LAUNCHER` to 1 to let the user defined OptiX device functions appear inside Nsight Compute. This is a temporary workaround and will be solved in the future.
Here also read especially the last bullet point about the line info and debugLevel setting which is important for profiling:
[https://raytracing-docs.nvidia.com/optix7/guide/index.html#program\_pipeline\_creation#7017](https://raytracing-docs.nvidia.com/optix7/guide/index.html#program_pipeline_creation#7017)
Related topic:
[https://forums.developer.nvidia.com/t/debugging-is-broken-after-updating-to-cuda-12-1/245616](https://forums.developer.nvidia.com/t/debugging-is-broken-after-updating-to-cuda-12-1/245616)
_[View the full topic](https://forums.developer.nvidia.com/t/optix-pipelines-do-not-show-up-in-nsight-compute/254831)._
