Optix prime is not running on the stream I have been passing it via a CUDA interface I have set up. This interface sets up a mapping of threads to streams which automatically generates streams on request. ( Say: Thread 0 requests Stream 1 on the current device. ) That request will create a stream which will persist for the lifetime of the thread.
OptiX when passing this stream similar to the below:
NOTE: This is a handtyped relavent sample of my codebase and is not meant to be compilable. It is simply showing how I am using the library. The model and triangles are generated in code not provided here.
When using OptiX in the way I am using it, the library is creating a new stream and running all queries on that while not using the one I passed to it.
__host__ void CUDARayTracer::rayTrace( const Transducer & tx,
const Transducer & rx,
const float frequency )
// Sets the current device to an internal list of available devices which point to actual cuda device ids. ( This excludes devices attached to a screen for example or under compute < 3.0 )
// We have other functions that simply cycle through the list of available devices.
// TODO: Change to cycle gpus assigned to OptiX context
CudaSetDevice(0);
// Gets the first stream for current device, thread::id pair.
cudaStream_t stream = CudaGetStream(0);
DeviceArray<Hit> d_hits( m_numRaysX*m_numRaysY );
// Generates rays radiating from the source towards a receiver
DeviceArray<geometry::CUDARay3D> d_rays( generateRays( tx.getInertialPosition(),
rx.getInertialPosition(),
tx.getInertialDownUnitVector(),
stream ) );
optix::prime::Query query( initializeRayTraceQuery( d_hits, d_rays ) );
executeQueryAsync( query, stream );
finishQueryAsync( query );
// ... Use hits and ray buffers past this point...
__host__ optix::prime::Query CUDARayTracer::initializeRayTraceQuery( DeviceArray<Hit> & d_hits,
DeviceArray<geometry::CUDARay3D> & d_rays ) const
optix::prime::Context context( GetOptixPrimeContext() );
// Model and triangles are generated in other functions not provided here...
optix::prime::Query = m_model->createQuery( RTP_QUERY_TYPE_CLOSEST );
optix::prime::BufferDesc raysDesc = context->createBufferDesc( RTP_BUFFER_FORMAT_RAY_ORIGIN_TMIN_DIRECTION_TMAX,
RTP_BUFFER_TYPE_CUDA_LINEAR,
reinterpret_cast< void * >( d_rays.data() ) );
optix::prime::BufferDesc hitsDesc = context->createBufferDesc( RTP_BUFFER_FORMAT_HIT_T_TRIID_U_V,
reinterpret_cast< void * >( d_hits.data() ) );
raysDesc->setRange( 0, d_rays.getSizeElements() );
hitsDesc->setRange( 0, d_hits.getSizeElements() );
query->setHits( hitsDesc );
query->setRays( raysDesc );
return query;
__host__ void CUDARayTracer::executeQueryAsync( optix::prime::Query query,
cudaStream_t stream ) const
query->setCudaStream(stream);
query->execute( RTP_QUERY_HINT_ASYNC );
__host__ void CUDARayTracer::finishQueryAsync( optix::prime::Query query ) const
query->finish();
