I followed a tutorial to use the OptixDenoiser to get soft shadows, of which I implemented two variants without denoising before. The tutorial required me to change the image buffer from uint32_t
(simply 8 bits for RGBA each) to float4
. However, this butchered my frame rate from about 100 frames per second to merely 10 frames per second, which is basically caused by buffer operations (resizing, drawing to, etc.) on the float4
datatype. I measured about 50 ms only to resize the 1920x1080 framebuffer, whenever needed.
I tried to use the OptiXDenoiser with the previous uint32_t
format. For this, I specified in the input and output layers OPTIX_PIXEL_FORMAT_UCHAR4
as format. As it turned out, unsigned char
is unsupported, as I could find in a post from OptiX Version 7.0.
So now I’m basically left with the choice of using float4
as framebuffer format at 10 frames per second or using uint32_t
and increasing the samples, which end up at about 20 frames per second without any notable noise.
Therefore, I wanted to ask if there are any plans to add support for unsigned char
format to the OptixDenoiser and, if there is a timeline for when to expect that feature. I also considered half, but that would still cause a lot of wasted space.
Kind regards and thank you
Markus
