I found that optixModuleCreateFromPTX()
causes stack overflow (not related to any kernel execution) with some ptx.
I simplified the program and made a reproducer:
(Original program: OptiX_Utility/samples/deformation_blur at master · shocker-0x15/OptiX_Utility · GitHub)
Open samples/repro.sln and build/run. In my environment the program crashes with the stack overflow exception in nvrtum64.dll.
However, if I change the array size of the member variable GeometryData::curveVertexBuffers
from 16 to 8 (see deformation_blur_shared.h), it succeeds to create a module.
Other random notes:
- The program crashes both for Debug/Release.
- I don’t use debug info for ptx generation both for Debug/Release.
- I originally found the issue with the original program with CUDA 11.2 but with CUDA 11.1 (which OptiX 7.2.0 officially supports) it still happens.
Environment:
Windows 10 (20H2)
Visual Studio Community 2019 (16.8.3)
CUDA 11.1
OptiX 7.2.0
Core i9-9900K, 32GB
RTX 3080 10GB
NVIDIA Driver 461.09
Thanks,
