For posterity, to add on to Honey’s help, the detect method doesn’t extract descriptions like the detector method did in the Nvidia tutorial (why can’t you guys at Nvidia update this??). I found I needed to combine it with the extractor method. Here’s the code that should get you working
#include <opencv2/imgproc/imgproc.hpp>
#include <opencv2/highgui/highgui.hpp>
#include <opencv2/features2d/features2d.hpp>
#include <opencv2/calib3d/calib3d.hpp>
int main()
cv::VideoCapture input("/home/nvidia/5-cv-features/bird.mp4");
cv::Mat img, img_gray; // to track img
cv::Mat img_desc;
std::vector<cv::KeyPoint> img_keypoints, h20fall_keypoints; //vec to store features
cv::Ptr<cv::ORB> detector = cv::ORB::create(5000);
cv::Ptr<cv::ORB> extractor = cv::ORB::create();
// detect on 1st frame to track in loop
input.read(img);
cv::Mat h20fall;
cv::Mat h20fall_desc;
//grab section of image
img(cv::Rect(715, 500, 150, 150)).copyTo(h20fall);
// call detector object method (input, keypoints vec)
detector->detect(h20fall, h20fall_keypoints);
extractor->compute(h20fall, h20fall_keypoints, h20fall_desc);
drawKeypoints(h20fall, h20fall_keypoints, h20fall);
for (;;)
if (!input.read(img))
break;
detector->detect(img, img_keypoints);
extractor->compute(img, img_keypoints, img_desc);
drawKeypoints(img, img_keypoints, img);
// each column in feature desc mat contains descriptions
// brute force matcher - compare all descs and choose best matches
// result stored in vec of matches struct
cv::BFMatcher matcher;
std::vector<cv::DMatch> matches;
matcher.match(h20fall_desc, img_desc, matches);
// split matches into 2 vectors
std::vector<cv::Point2f> h20fall_points, img_points;
for (int i = 0; i < matches.size(); i++)
h20fall_points.push_back(h20fall_keypoints[matches[i].queryIdx].pt);
img_points.push_back(img_keypoints[matches[i].trainIdx].pt);
// find homographic transform between images (3x3) and filter out outliers w ransac
cv::Matx33f H = cv::findHomography(h20fall_points, img_points, CV_RANSAC);
// create 2 vectors to hold corner pts of bounding boxes and fill 1 w/ known image
std::vector<cv::Point> h20fall_border, img_border;
h20fall_border.push_back(cv::Point(0, 0));
h20fall_border.push_back(cv::Point(0, h20fall.rows));
h20fall_border.push_back(cv::Point(h20fall.cols, h20fall.rows));
h20fall_border.push_back(cv::Point(h20fall.cols, 0));
// mult by homography matrix
for (size_t i = 0; i < h20fall_border.size(); i++)
cv::Vec3f p = H * cv::Vec3f(h20fall_border[i].x, h20fall_border[i].y, 1);
// push onto img
img_border.push_back(cv::Point(p[0] / p[2], p[1] / p[2]));
// draw enclosed shape
cv::polylines(img, img_border, true, CV_RGB(0, 255, 0));
//draw match - return matches vector of combined images
cv::Mat img_matches;
cv::drawMatches(h20fall, h20fall_keypoints, img, img_keypoints, matches, img_matches);
cv:imshow("img_matches", img_matches);
//cv::imshow("h20fall", h20fall);
//cv::imshow("img", img);
char c = cv::waitKey(); // play frame on any key
if (c == 27) // escape acii
break;
Note that if your regions don’t have enough points matched to begin with, you may experience odd error complaints. Should probably put conditions in there, but anyways…
