I have about 25 kernels that are each pretty long, each one is in its own .cu file. These kernels all need to reference the same texture.
Because of this, I just created a top level kernels.cu file that had the texture reference, functions to bind and unbind the textures, some device functions and then #included the other 25 kernels.
This structure worked well but I recently started receiving the following error message when compiling:
1>Compiling...
1>kernels.cu
1>tmpxft_00000c10_00000000-3_kernels.cudafe1.gpu
1>tmpxft_00000c10_00000000-8_kernels.cudafe2.gpu
1>Signal: caught in Global Optimization -- New PRE: Build initial occurrence lists phase.
1>(0): Error: Signal caught in phase Global Optimization -- New PRE: Build initial occurrence lists -- processing aborted
1>nvopencc ERROR: C:\CUDA\bin/../open64/lib//be.exe returned non-zero status 3
I believe this is due to the length of the file after all of the #includes have been expanded. I tried to compile each of the 25 kernels seperately but I am unsure how to do that while having them all reference the same texture and also have a single bind/unbind function.
I get this error when compiling for both Debug (No optimization) and Release. Windows XP 32 bit, CUDA 2.3 (190.38).
I would post a repro case if I could but I am unable to post any of my code at this time. Any advice would be appreciated.
