I am placing grasp poses predicted by GraspNet into Isaac Sim.
The grasps were generated from the left camera view.
To avoid any authored transforms on camera prims, I created a neutral container at
/World/targets and I place my grasp prim under it.
My translation matches perfectly.
My orientation is wrong.
Scene setup
Three standard Isaac cameras under a Realsense group
left, right, color -
All three camera meshes show red forward along minus Z and Y to the left and X up in the viewport gizmo
I created
/World/targets/left_targetas a plain Xform and aligned it so that its axes match the left camera axes in the viewport -
The grasp prim lives at
/World/targets/grasp
Data
Intrinsics for the left camera:
fx = 634.09
fy = 566.49
cx = 640.00
cy = 360.00
f = 1.93
ax = 3.896
ay = 2.453
width = 1280
height = 720
Left and right camera translations in world:
left [0.2 0.0475 1.4]
right [0.2 -0.0475 1.4]
A sample detection output from graspnet looks like (from left camera as origin):
“index”: 1,
“cost”: 0.07800227635649198,
“trans_error_m”: 0.043542315417918656,
“rot_error_rad”: 1.1486653646191107,
“rot_error_deg”: 65.81367746553089,
“score”: 0.5542612671852112,
“width”: 0.09086745232343674,
“translation”: [
-0.0032448123674839735,
-0.08126597106456757,
0.2571863532066345
“rotation”: [
0.15586048364639282,
0.9777116179466248,
-0.1406681090593338
-0.7258150577545166,
0.20995239913463593,
0.6550667881965637
0.6700000166893005,
0.0,
0.7423611283302307
GraspNet rotations are provided in the camera optical frame
X right, Y down, Z forward
What I tried
- Placing the grasp directly under
/World/targetsafter rotatingtargetsto match OpenCV optical axes
I get translation correct at the right place in isaac sim as visualized in open3d ground truth cloud file, but orientation wrong
After that did not work out, so I tried to change the targets prim to isaac sim convention (towards -z, x top and y left)
- Using a pure change of basis matrix C for my camera axes
target camera convention in my scene is Z back, Y left, X up
this mapping from OpenCV optical is
x new equals minus y old
y new equals minus x old
z new equals minus z old
so
C = [[ 0, -1, 0],
[-1, 0, 0],
[ 0, 0, -1]]
then
t_local = C @ t_cv R_local = C @ R_cv @ C.T
still see a mismatch in orientation in the viewport
What I observe
Translation is exactly where I expect
Orientation is off by a fixed rotation that I cannot reconcile
it is not plus minus ninety about a principal axis and not a simple transpose issue
Questions for the community
Is my C matrix correct for mapping OpenCV optical to a camera that looks down minus Z with Y left and X up
C as written maps ex to up, ey to left, ez to forward minus Z -
Does SingleXFormPrim set_local_pose compose with any authored xformOps inside the referenced
frame_prim.usdmesh that could explain a fixed extra rotation
if so, should I set the pose on the container Xform instead of the child -
For GraspNet JSON, are rotations typically stored as grasp in camera or camera to grasp
if there is a standard, I can lock R or R transpose accordingly -
Is there any known difference between column major interpretation of rotation matrices in Isaac Python helpers and the usual robotics convention where columns are basis vectors of the child expressed in the parent
Any gotcha with transform order on Xforms that I should double check
for example an unexpected rotate then translate ordering
Ground truth from graspnet (open3d visualization):
Isaac sim transformed point:
Object of interest removed for better visualization:
You can see the realsense sensor right on top of the bin:
The entire prim structure of camera:
/World/Realsense/RSD455/Camera_Pseudo_Depth focal=1.9299999475479126 horiz_ap=3.8959999084472656 vert_ap=2.0545310974121094
/World/Realsense/RSD455/Camera_OmniVision_OV9782_Color focal=1.9299999475479126 horiz_ap=3.9000000953674316 vert_ap=2.453000068664551
/World/Realsense/RSD455/Camera_OmniVision_OV9782_Left focal=1.9299999475479126 horiz_ap=3.8959999084472656 vert_ap=2.453000068664551
/World/Realsense/RSD455/Camera_OmniVision_OV9782_Right focal=1.9299999475479126 horiz_ap=3.8959999084472656 vert_ap=2.453000068664551
The entire prim structure of targets (where I placed my grasp prim:
/World/targets type=Xform
/World/targets/grasp type=Xform /World/targets/grasp/Frame type=Xform /World/targets/grasp/Frame/X_line type=Cylinder material=/World/targets/grasp/Frame/Looks/visual_material /World/targets/grasp/Frame/X_tip type=Cone material=/World/targets/grasp/Frame/Looks/visual_material_1 /World/targets/grasp/Frame/Y_line type=Cylinder material=/World/targets/grasp/Frame/Looks/visual_material_2 /World/targets/grasp/Frame/Y_tip type=Cone material=/World/targets/grasp/Frame/Looks/visual_material_3 /World/targets/grasp/Frame/Z_line type=Cylinder material=/World/targets/grasp/Frame/Looks/visual_material_4 /World/targets/grasp/Frame/Z_tip type=Cone material=/World/targets/grasp/Frame/Looks/visual_material_5
Help me figure this out yall! After this, I need to change the orientation of the grasp frame as franka RMP flow needs z axis to be aligned with the ee. Will appreciate if you someone could give me idea to approach this orientation problem from OpenCV to Isaac sim then to RMPflow orientation. Let me know if you have any questions. I dont know if anyone wants to reproduce it, so i did not attach the USD files.
