This is what the image of my original data set looks like.
It is smaller than the KITTI image.
■label data like this
fish 0.00 0 0.0 62.00 12.00 256.00 156.00 0.0 0.0 0.0 0.0 0.0 0.0 0.0
fish 0.00 0 0.0 199.00 192.00 293.00 289.00 0.0 0.0 0.0 0.0 0.0 0.0 0.0
fish 0.00 0 0.0 300.00 272.00 399.00 352.00 0.0 0.0 0.0 0.0 0.0 0.0 0.0
fish 0.00 0 0.0 266.00 125.00 320.00 204.00 0.0 0.0 0.0 0.0 0.0 0.0 0.0
fish 0.00 0 0.0 30.00 260.00 49.00 291.00 0.0 0.0 0.0 0.0 0.0 0.0 0.0
fish 0.00 0 0.0 153.00 251.00 176.00 278.00 0.0 0.0 0.0 0.0 0.0 0.0 0.0
fish 0.00 0 0.0 101.00 245.00 130.00 271.00 0.0 0.0 0.0 0.0 0.0 0.0 0.0
fish 0.00 0 0.0 1.00 295.00 28.00 318.00 0.0 0.0 0.0 0.0 0.0 0.0 0.0
fish 0.00 0 0.0 182.00 266.00 211.00 288.00 0.0 0.0 0.0 0.0 0.0 0.0 0.0
fish 0.00 0 0.0 109.00 274.00 146.00 295.00 0.0 0.0 0.0 0.0 0.0 0.0 0.0
fish 0.00 0 0.0 53.00 272.00 88.00 287.00 0.0 0.0 0.0 0.0 0.0 0.0 0.0
fish 0.00 0 0.0 124.00 248.00 147.00 263.00 0.0 0.0 0.0 0.0 0.0 0.0 0.0
fish 0.00 0 0.0 19.00 277.00 60.00 292.00 0.0 0.0 0.0 0.0 0.0 0.0 0.0
fish 0.00 0 0.0 1.00 300.00 36.00 315.00 0.0 0.0 0.0 0.0 0.0 0.0 0.0
■detectnet_v2_train_resnet18_kitti.txt
random_seed: 42
dataset_config {
data_sources {
tfrecords_path: "/home/ubuntu/development/workspace/aquarium/dataDownloadDir/tfrecords/kitti_trainval/*"
image_directory_path: "/home/ubuntu/development/workspace/aquarium/dataDownloadDir/training"
image_extension: "jpg"
target_class_mapping {
key: "fish"
value: "fish"
key: "jellyfish"
value: "jellyfish"
key: "penguin"
value: "penguin"
key: "puffin"
value: "puffin"
key: "shark"
value: "shark"
validation_fold: 0
augmentation_config {
preprocessing {
output_image_width: 1248
output_image_height: 384
min_bbox_width: 1.0
min_bbox_height: 1.0
output_image_channel: 3
spatial_augmentation {
hflip_probability: 0.5
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
hue_rotation_max: 25.0
saturation_shift_max: 0.20000000298
contrast_scale_max: 0.10000000149
contrast_center: 0.5
postprocessing_config {
target_class_config {
key: "fish"
value {
clustering_config {
clustering_algorithm: DBSCAN
dbscan_confidence_threshold: 0.9
coverage_threshold: 0.00499999988824
dbscan_eps: 0.20000000298
dbscan_min_samples: 0.0500000007451
minimum_bounding_box_height: 20
key: "jellyfish"
value {
clustering_config {
dbscan_eps: 0.15000000596
key: "penguin"
value {
clustering_config {
coverage_threshold: 0.00749999983236
dbscan_eps: 0.230000004172
model_config {
pretrained_model_file: "/home/ubuntu/development/workspace/aquarium/localProjectDir/detectnet_v2/pretrained_resnet18/pretrained_detectnet_v2_vresnet18/resnet18.hdf5"
num_layers: 18
use_batch_norm: true
objective_set {
bbox {
scale: 35.0
offset: 0.5
cov {
arch: "resnet"
evaluation_config {
validation_period_during_training: 10
first_validation_epoch: 30
minimum_detection_ground_truth_overlap {
key: "fish"
value: 0.699999988079
key: "jellyfish"
value: 0.5
key: "penguin"
value: 0.5
evaluation_box_config {
key: "fish"
value {
minimum_height: 20
maximum_height: 9999
minimum_width: 10
maximum_width: 9999
key: "jellyfish"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "penguin"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
average_precision_mode: INTEGRATE
cost_function_config {
target_classes {
class_weight: 1.0
coverage_foreground_weight: 0.0500000007451
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
initial_weight: 10.0
weight_target: 10.0
target_classes {
class_weight: 8.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 1.0
target_classes {
class_weight: 4.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
enable_autoweighting: true
max_objective_weight: 0.999899983406
min_objective_weight: 9.99999974738e-05
training_config {
batch_size_per_gpu: 1
num_epochs: 120
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-06
max_learning_rate: 5e-04
soft_start: 0.10000000149
annealing: 0.699999988079
regularizer {
type: L1
weight: 3.00000002618e-09
optimizer {
adam {
epsilon: 9.99999993923e-09
beta1: 0.899999976158
beta2: 0.999000012875
cost_scaling {
initial_exponent: 20.0
increment: 0.005
decrement: 1.0
checkpoint_interval: 10
bbox_rasterizer_config {
key: "fish"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 0.40000000596
cov_radius_y: 0.40000000596
bbox_min_radius: 1.0
key: "jellyfish"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "penguin"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
deadzone_radius: 0.400000154972
now, this error occur.
■error log
2022-06-11 09:42:51,199 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/common/graph/initializers.py:16: The name tf.get_collection is deprecated. Please use tf.compat.v1.get_collection instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/utils.py:61: The name tf.train.LoggingTensorHook is deprecated. Please use tf.estimator.LoggingTensorHook instead.
2022-06-11 09:42:51,201 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/utils.py:61: The name tf.train.LoggingTensorHook is deprecated. Please use tf.estimator.LoggingTensorHook instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/utils.py:62: The name tf.train.StopAtStepHook is deprecated. Please use tf.estimator.StopAtStepHook instead.
2022-06-11 09:42:51,202 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/utils.py:62: The name tf.train.StopAtStepHook is deprecated. Please use tf.estimator.StopAtStepHook instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/utils.py:75: The name tf.train.StepCounterHook is deprecated. Please use tf.estimator.StepCounterHook instead.
2022-06-11 09:42:51,202 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/utils.py:75: The name tf.train.StepCounterHook is deprecated. Please use tf.estimator.StepCounterHook instead.
INFO:tensorflow:Create CheckpointSaverHook.
2022-06-11 09:42:51,202 [INFO] tensorflow: Create CheckpointSaverHook.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/utils.py:104: The name tf.train.SummarySaverHook is deprecated. Please use tf.estimator.SummarySaverHook instead.
2022-06-11 09:42:51,202 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/utils.py:104: The name tf.train.SummarySaverHook is deprecated. Please use tf.estimator.SummarySaverHook instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/training/utilities.py:140: The name tf.train.SingularMonitoredSession is deprecated. Please use tf.compat.v1.train.SingularMonitoredSession instead.
2022-06-11 09:42:51,203 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/training/utilities.py:140: The name tf.train.SingularMonitoredSession is deprecated. Please use tf.compat.v1.train.SingularMonitoredSession instead.
INFO:tensorflow:Graph was finalized.
2022-06-11 09:42:54,583 [INFO] tensorflow: Graph was finalized.
INFO:tensorflow:Running local_init_op.
2022-06-11 09:42:56,232 [INFO] tensorflow: Running local_init_op.
INFO:tensorflow:Done running local_init_op.
2022-06-11 09:42:57,035 [INFO] tensorflow: Done running local_init_op.
2022-06-11 09:43:06,360 [INFO] root: Saving trained model.
2022-06-11 09:43:06,395 [INFO] root: Saving trained model.
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1365, in _do_call
return fn(*args)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1350, in _run_fn
target_list, run_metadata)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1443, in _call_tf_sessionrun
run_metadata)
tensorflow.python.framework.errors_impl.InvalidArgumentError: 2 root error(s) found.
(0) Invalid argument: bboxes class ID out of range [0, 3[, got-1
[[{{node BboxRasterizer/RasterizeBbox}}]]
[[resnet18_nopool_bn_detectnet_v2/block_2a_bn_1/AssignMovingAvg/_4451]]
(1) Invalid argument: bboxes class ID out of range [0, 3[, got-1
0 successful operations.
0 derived errors ignored.
During handling of the above exception, another exception occurred:
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 917, in <module>
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 906, in <module>
File "<decorator-gen-2>", line 2, in main
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/utilities/timer.py", line 46, in wrapped_fn
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 893, in main
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 757, in run_experiment
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 693, in train_gridbox
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 195, in run_training_loop
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 754, in run
run_metadata=run_metadata)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1360, in run
raise six.reraise(*original_exc_info)
File "/usr/local/lib/python3.6/dist-packages/six.py", line 696, in reraise
raise value
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1345, in run
return self._sess.run(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1418, in run
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1176, in run
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 956, in run
run_metadata_ptr)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1180, in _run
feed_dict_tensor, options, run_metadata)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1359, in _do_run
run_metadata)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1384, in _do_call
raise type(e)(node_def, op, message)
[[node BboxRasterizer/RasterizeBbox (defined at /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py:1748) ]]
Original stack trace for 'BboxRasterizer/RasterizeBbox':
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 668, in train_gridbox
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 507, in build_training_graph
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 397, in rasterize_tensors
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/model/detectnet_model.py", line 665, in generate_ground_truth_tensors
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/objectives/objective_set.py", line 278, in generate_ground_truth_tensors
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/rasterizers/bbox_rasterizer.py", line 473, in rasterize_labels
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/processors/processors.py", line 235, in __call__
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/processors/bbox_rasterizer.py", line 234, in call
File "<string>", line 161, in rasterize_bbox
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/op_def_library.py", line 794, in _apply_op_helper
op_def=op_def)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/util/deprecation.py", line 513, in new_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 3357, in create_op
attrs, op_def, compute_device)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 3426, in _create_op_internal
op_def=op_def)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 1748, in __init__
self._traceback = tf_stack.extract_stack()
2022-06-11 09:43:06,561 [INFO] root: Saving trained model.
2022-06-11 09:43:06,578 [INFO] root: Saving trained model.
2022-06-11 09:43:06,648 [INFO] root: Saving trained model.
return fn(*args)
run_metadata)
raise value
run_metadata_ptr)
run_metadata)
op_def=op_def)
op_def=op_def)
2022-06-11 09:43:06,655 [INFO] root: Saving trained model.
INFO:tensorflow:Saving checkpoints for step-0.
2022-06-11 09:43:06,656 [INFO] tensorflow: Saving checkpoints for step-0.
2022-06-11 09:43:06,738 [INFO] root: Saving trained model.
return fn(*args)
run_metadata)
tensorflow.python.framework.errors_impl.UnknownError: Horovod has been shut down. This was caused by an exception on one of the ranks or an attempt to allreduce, allgather or broadcast a tensor after one of the ranks finished execution. If the shutdown was caused by an exception, you should see the exception in the log before the first shutdown message.
[[{{node DistributedAdamOptimizer_Allreduce/cond_1/HorovodAllreduce_gradients_AddN_58_0}}]]
raise value
run_metadata_ptr)
run_metadata)
[[node DistributedAdamOptimizer_Allreduce/cond_1/HorovodAllreduce_gradients_AddN_58_0 (defined at /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py:1748) ]]
Original stack trace for 'DistributedAdamOptimizer_Allreduce/cond_1/HorovodAllreduce_gradients_AddN_58_0':
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 523, in build_training_graph
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/model/detectnet_model.py", line 602, in build_training_graph
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/training/train_op_generator.py", line 59, in get_train_op
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/training/train_op_generator.py", line 74, in _get_train_op_without_cost_scaling
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/optimizer.py", line 419, in minimize
grad_loss=grad_loss)
File "/usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py", line 501, in compute_gradients
avg_grads = self._allreduce_grads(grads, vars)
File "/usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py", line 422, in allreduce_grads
for grad in grads]
File "/usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py", line 422, in <listcomp>
for grad in grads]
File "/usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py", line 258, in _allreduce_cond
allreduce_fn, id_fn)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/ops/control_flow_ops.py", line 1224, in cond
orig_res_t, res_t = context_t.BuildCondBranch(true_fn)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/ops/control_flow_ops.py", line 1061, in BuildCondBranch
original_result = fn()
File "/usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py", line 248, in allreduce_fn
return allreduce(tensor, *args, process_set=process_set, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py", line 128, in allreduce
name=name, process_set=process_set)
File "/usr/local/lib/python3.6/dist-packages/horovod/tensorflow/mpi_ops.py", line 131, in _allreduce
process_set_id=process_set.process_set_id)
File "<string>", line 108, in horovod_allreduce
op_def=op_def)
op_def=op_def)
return fn(*args)
run_metadata)
raise value
run_metadata_ptr)
run_metadata)
op_def=op_def)
op_def=op_def)
return fn(*args)
run_metadata)
[[{{node DistributedAdamOptimizer_Allreduce/cond_44/HorovodAllreduce_gradients_AddN_32_0}}]]
raise value
run_metadata_ptr)
run_metadata)
[[node DistributedAdamOptimizer_Allreduce/cond_44/HorovodAllreduce_gradients_AddN_32_0 (defined at /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py:1748) ]]
Original stack trace for 'DistributedAdamOptimizer_Allreduce/cond_44/HorovodAllreduce_gradients_AddN_32_0':
for grad in grads]
for grad in grads]
op_def=op_def)
op_def=op_def)
return fn(*args)
run_metadata)
raise value
run_metadata_ptr)
run_metadata)
for grad in grads]
for grad in grads]
op_def=op_def)
op_def=op_def)
return fn(*args)
run_metadata)
[[{{node DistributedAdamOptimizer_Allreduce/cond_86/HorovodAllreduce_gradients_AddN_8_0}}]]
raise value
run_metadata_ptr)
run_metadata)
[[node DistributedAdamOptimizer_Allreduce/cond_86/HorovodAllreduce_gradients_AddN_8_0 (defined at /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py:1748) ]]
Original stack trace for 'DistributedAdamOptimizer_Allreduce/cond_86/HorovodAllreduce_gradients_AddN_8_0':
for grad in grads]
for grad in grads]
op_def=op_def)
op_def=op_def)
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun.real detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[9212,1],1]
Exit code: 1
2022-06-11 09:43:10,361 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
