Does the Jetson Orin XFI interface support 802.1AS-2020?
Unfortunately, the provided context does not contain any information about the Jetson Orin XFI interface supporting 802.1AS-2020. The context primarily focuses on various Linux distributions, platforms, and tools related to NVIDIA Jetson devices, but it does not mention the specific feature or standard you are asking about.
However, I can suggest some possible sources where you might find the information you are looking for:
- NVIDIA’s official documentation: You can check NVIDIA’s official documentation for the Jetson AGX Orin module to see if it mentions support for 802.1AS-2020.
- Jetson AGX Orin datasheet: The datasheet for the Jetson AGX Orin module might provide information about its interfaces and supported standards, including 802.1AS-2020.
- NVIDIA’s developer forums: You can search NVIDIA’s developer forums to see if anyone has asked or discussed the topic of 802.1AS-2020 support on the Jetson Orin XFI interface.
If you have any more specific information or context about the Jetson Orin XFI interface or 802.1AS-2020, I might be able to help you better.
As stated in above comment, this is not supported on Jetpack 5 and 6 releases.
Is there a plan to implement this in any version?
As of now there’s no plan for this.
