I have seen this sometimes when I open the Orin terminal on the host computer.
minicom -D /dev/ttyACM0 -8 -b 115200
I see this console, where, I can run a command but there is no output
> ls
> ls
> pwd
but after 1 or 2 minutes I get the normal console:
nvidia@tegra-nvidia:~$ ls
Desktop
Do you know why I get the first console?
Regards.
hello ManuelLeiva,
may I know what’s your steps in detail to reproduce the issue,
is there any background service occupied serial port?
Hello JerryChang,
I am using Jetapack 5.0.2, to create the rootfs I am using sample fs tool
sudo ./nv_build_samplefs.sh --abi aarch64 --distro ubuntu --flavor minimal --version focal
The rootfs created is copied into rootfs directory:
sudo tar xpf sample_fs.tbz2
Apply L4T binaries:
sudo ./apply_binaries.sh
And I am creating the default user using the script:
sudo ./l4t_create_default_user.sh -u $UBUNTU_USER -p $UBUNTU_PASS -n $UBUNTU_HOSTNAME --accept-license --autologin
After these steps I apply the normal flash command:
sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
Then when I open /dev/ttyACM0 sometimes I have this strange console.
Regards
Hi ManuelLeiva,
We don’t hit this issue on AGX Orin.
Are you only connect one Jetson device on your host?
