Orin AGX disk filled and now not booting
I was running an app on the Orin AGX devkit and it ended up saving so much data that it filled the primary disk. I thought I had removed some files to free up space, but when I rebooted the system it runs through the L4T boot loader and then exits (not sure where the logs are too fast).
Is there a way for me to boot to something where I can simply remove some files on the main partition and allow (hopefully) the boot to continue?
-Tony
Not sure waht have been removed to cause the boot failed.
I will suggest to reflash your device again.
Thanks. I used the SDK manager to reflash.
