ORIN AGX - Dynamically Load Device Tree Overlays
May I request a tutorial about how to dynamically load device tree overlays at run time through user space? I will need this approach to develop my complex device tree without having to restart system.
I am using devkit for ORIN AGX with Jetson Linux 35.3.1 and JetPack 5.1.1 .
I enabled the following configs,
CONFIG_OF_CONFIGFS=y
CONFIG_OF_OVERLAY=y
and expecting the following path to be available to modify. But couldn`t successfull yet.
/sys/kernel/config/device-tree/overlays
Thanks in advance.
Hi fat,
Device tree and drivers are loaded during boot up?
May I know what’s your use case for “dynamically load device tree”?
Do you have different device tree configuration for any purpose?
The overlay dtb is also loaded during boot up. You could find following line in board config for details.
OVERLAY_DTB_FILE="L4TConfiguration.dtbo,tegra234-p3701-overlay.dtbo";
Hi Kevin,
Thank you for your prompt reply.
I am planning to develop a complex device tree blob for ser-des components that requires a bunch of configuration parameters and specific drivers for both ser-des and cameras.
Having to reboot after a set of modifications during development is totally time-consuming. I would like to be able to load/unload device-tree-overlays dynamically along with loadable-kernel-modules. So that I don`t have to wait for the ORIN to reboot, and I can develop my project faster in user space.
Eventually, I will modify DT and Kernel Module to be started during boot up once I am done.
Thanks in advance.
It seems you would like to load it at runtime for debug purpose.
Modifying the dtb in use (/boot/dtb/kernel_XXX.dtb) and reboot the board to load it could be an option for your use case.
Please share the result of the following command on your board.
$ zcat /proc/config.gz | grep -E "CONFIG_OF_CONFIGFS|CONFIG_OF_OVERLAY"
Correct.
zcat /proc/config.gz | grep -E “CONFIG_OF_CONFIGFS|CONFIG_OF_OVERLAY”
CONFIG_OF_OVERLAY=y
Seems like CONFIG_OF_CONFIGFS was not activated somehow. But the defconfig and tegra_defconfig (which is a symbolic link) has this value at the end:
# CONFIG_LOCALVERSION_AUTO is not set
CONFIG_SYSVIPC=y
CONFIG_POSIX_MQUEUE=y
CONFIG_WATCH_QUEUE=y
CONFIG_AUDIT=y
CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
CONFIG_PREEMPT=y
CONFIG_IRQ_TIME_ACCOUNTING=y
CONFIG_BSD_PROCESS_ACCT=y
CONFIG_BSD_PROCESS_ACCT_V3=y
CONFIG_TASK_XACCT=y
CONFIG_TASK_IO_ACCOUNTING=y
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
CONFIG_CGROUPS=y
CONFIG_MEMCG=y
CONFIG_BLK_CGROUP=y
CONFIG_CGROUP_SCHED=y
CONFIG_CFS_BANDWIDTH=y
CONFIG_RT_GROUP_SCHED=y
CONFIG_CGROUP_PIDS=y
CONFIG_CGROUP_FREEZER=y
CONFIG_CGROUP_HUGETLB=y
CONFIG_CPUSETS=y
CONFIG_CGROUP_DEVICE=y
CONFIG_CGROUP_CPUACCT=y
CONFIG_CGROUP_PERF=y
CONFIG_NAMESPACES=y
CONFIG_USER_NS=y
CONFIG_RELAY=y
CONFIG_BLK_DEV_INITRD=y
CONFIG_KALLSYMS_ALL=y
CONFIG_EMBEDDED=y
# CONFIG_COMPAT_BRK is not set
CONFIG_SLAB_FREELIST_RANDOM=y
CONFIG_SLAB_FREELIST_HARDENED=y
CONFIG_SHUFFLE_PAGE_ALLOCATOR=y
CONFIG_PROFILING=y
CONFIG_ARCH_TEGRA=y
CONFIG_ARM64_VA_BITS_48=y
CONFIG_SCHED_MC=y
CONFIG_SCHED_SMT=y
CONFIG_PARAVIRT=y
CONFIG_KEXEC=y
CONFIG_KEXEC_FILE=y
CONFIG_CRASH_DUMP=y
# CONFIG_RODATA_FULL_DEFAULT_ENABLED is not set
CONFIG_ARM64_SW_TTBR0_PAN=y
CONFIG_COMPAT=y
CONFIG_ARMV8_DEPRECATED=y
CONFIG_SWP_EMULATION=y
CONFIG_CP15_BARRIER_EMULATION=y
CONFIG_SETEND_EMULATION=y
# CONFIG_ARM64_HW_AFDBM is not set
CONFIG_RANDOMIZE_BASE=y
CONFIG_PM_AUTOSLEEP=y
CONFIG_PM_WAKELOCKS=y
CONFIG_WQ_POWER_EFFICIENT_DEFAULT=y
CONFIG_ENERGY_MODEL=y
CONFIG_ARM_CPUIDLE=y
CONFIG_ARM_PSCI_CPUIDLE=y
CONFIG_CPU_IDLE_TEGRA_AUTO=y
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_STAT=y
CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=y
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y
CONFIG_CPUFREQ_DT=y
CONFIG_ACPI_CPPC_CPUFREQ=m
CONFIG_ARM_TEGRA186_CPUFREQ=y
CONFIG_ARM_SCPI_PROTOCOL=m
CONFIG_DMI_SYSFS=y
# CONFIG_EFI_VARS_PSTORE is not set
CONFIG_EFI_CAPSULE_LOADER=y
CONFIG_EFI_TEST=m
CONFIG_FB_EFI=y
CONFIG_ACPI=y
CONFIG_ACPI_APEI=y
CONFIG_ACPI_APEI_GHES=y
CONFIG_ACPI_APEI_MEMORY_FAILURE=y
CONFIG_ACPI_APEI_EINJ=y
CONFIG_KVM=y
CONFIG_TEGRA_DTC_SUPPRESS_WARNINGS=y
CONFIG_ARM64_CRYPTO=y
CONFIG_CRYPTO_SHA1_ARM64_CE=m
CONFIG_CRYPTO_SHA2_ARM64_CE=m
CONFIG_CRYPTO_SHA512_ARM64_CE=m
CONFIG_CRYPTO_SHA3_ARM64=m
CONFIG_CRYPTO_SM3_ARM64_CE=m
CONFIG_CRYPTO_GHASH_ARM64_CE=m
CONFIG_CRYPTO_AES_ARM64_CE_CCM=m
CONFIG_CRYPTO_AES_ARM64_CE_BLK=m
CONFIG_CRYPTO_AES_ARM64_NEON_BLK=m
CONFIG_ARCH_TEGRA_23x_SOC=y
CONFIG_ARCH_TEGRA_239_SOC=y
CONFIG_JUMP_LABEL=y
CONFIG_MODULES=y
CONFIG_MODULE_UNLOAD=y
CONFIG_MODVERSIONS=y
CONFIG_MODULE_SIG=y
CONFIG_MODULE_SIG_SHA512=y
CONFIG_BLK_DEV_THROTTLING=y
CONFIG_PARTITION_ADVANCED=y
# CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
CONFIG_BINFMT_MISC=m
CONFIG_KSM=y
CONFIG_DEFAULT_MMAP_MIN_ADDR=32768
CONFIG_MEMORY_FAILURE=y
CONFIG_TRANSPARENT_HUGEPAGE=y
CONFIG_CMA=y
CONFIG_ZSMALLOC=y
CONFIG_NET=y
CONFIG_PACKET=y
CONFIG_UNIX=y
CONFIG_XFRM_USER=y
CONFIG_NET_KEY=y
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
CONFIG_IP_ADVANCED_ROUTER=y
CONFIG_IP_MULTIPLE_TABLES=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
CONFIG_NET_IPGRE_DEMUX=m
CONFIG_SYN_COOKIES=y
CONFIG_INET_ESP=m
CONFIG_INET_DIAG=m
CONFIG_IPV6_ROUTER_PREF=y
CONFIG_IPV6_ROUTE_INFO=y
CONFIG_IPV6_OPTIMISTIC_DAD=y
CONFIG_INET6_AH=m
CONFIG_INET6_ESP=m
CONFIG_INET6_IPCOMP=m
CONFIG_IPV6_MIP6=m
CONFIG_IPV6_SIT=m
CONFIG_IPV6_TUNNEL=m
CONFIG_IPV6_MULTIPLE_TABLES=y
CONFIG_NETFILTER=y
CONFIG_BRIDGE_NETFILTER=m
CONFIG_NETFILTER_NETLINK_ACCT=m
CONFIG_NETFILTER_NETLINK_QUEUE=m
CONFIG_NETFILTER_NETLINK_LOG=m
CONFIG_NF_CONNTRACK=m
CONFIG_NF_CONNTRACK_EVENTS=y
CONFIG_NF_CONNTRACK_AMANDA=m
CONFIG_NF_CONNTRACK_FTP=m
CONFIG_NF_CONNTRACK_H323=m
CONFIG_NF_CONNTRACK_IRC=m
CONFIG_NF_CONNTRACK_NETBIOS_NS=m
CONFIG_NF_CONNTRACK_PPTP=m
CONFIG_NF_CONNTRACK_SANE=m
CONFIG_NF_CONNTRACK_SIP=m
CONFIG_NF_CONNTRACK_TFTP=m
CONFIG_NF_CT_NETLINK=m
CONFIG_NETFILTER_XT_TARGET_CHECKSUM=m
CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m
CONFIG_NETFILTER_XT_TARGET_CONNMARK=m
CONFIG_NETFILTER_XT_TARGET_IDLETIMER=m
CONFIG_NETFILTER_XT_TARGET_LOG=m
CONFIG_NETFILTER_XT_TARGET_MARK=m
CONFIG_NETFILTER_XT_TARGET_TEE=m
CONFIG_NETFILTER_XT_TARGET_TPROXY=m
CONFIG_NETFILTER_XT_TARGET_TRACE=m
CONFIG_NETFILTER_XT_TARGET_TCPMSS=m
CONFIG_NETFILTER_XT_MATCH_ADDRTYPE=m
CONFIG_NETFILTER_XT_MATCH_COMMENT=m
CONFIG_NETFILTER_XT_MATCH_CONNBYTES=m
CONFIG_NETFILTER_XT_MATCH_CONNLIMIT=m
CONFIG_NETFILTER_XT_MATCH_CONNMARK=m
CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m
CONFIG_NETFILTER_XT_MATCH_HASHLIMIT=m
CONFIG_NETFILTER_XT_MATCH_HELPER=m
CONFIG_NETFILTER_XT_MATCH_IPRANGE=m
CONFIG_NETFILTER_XT_MATCH_IPVS=m
CONFIG_NETFILTER_XT_MATCH_LENGTH=m
CONFIG_NETFILTER_XT_MATCH_LIMIT=m
CONFIG_NETFILTER_XT_MATCH_MAC=m
CONFIG_NETFILTER_XT_MATCH_MARK=m
CONFIG_NETFILTER_XT_MATCH_MULTIPORT=m
CONFIG_NETFILTER_XT_MATCH_OWNER=m
CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m
CONFIG_NETFILTER_XT_MATCH_QUOTA=m
CONFIG_NETFILTER_XT_MATCH_RECENT=m
CONFIG_NETFILTER_XT_MATCH_SOCKET=m
CONFIG_NETFILTER_XT_MATCH_STATE=m
CONFIG_NETFILTER_XT_MATCH_STATISTIC=m
CONFIG_NETFILTER_XT_MATCH_STRING=m
CONFIG_NETFILTER_XT_MATCH_TIME=m
CONFIG_NETFILTER_XT_MATCH_U32=m
CONFIG_IP_VS=m
CONFIG_IP_VS_PROTO_TCP=y
CONFIG_IP_VS_PROTO_UDP=y
CONFIG_IP_VS_RR=m
CONFIG_IP_VS_NFCT=y
CONFIG_IP_NF_IPTABLES=m
CONFIG_IP_NF_MATCH_AH=m
CONFIG_IP_NF_MATCH_ECN=m
CONFIG_IP_NF_MATCH_RPFILTER=m
CONFIG_IP_NF_MATCH_TTL=m
CONFIG_IP_NF_FILTER=m
CONFIG_IP_NF_TARGET_REJECT=m
CONFIG_IP_NF_NAT=m
CONFIG_IP_NF_TARGET_MASQUERADE=m
CONFIG_IP_NF_TARGET_NETMAP=m
CONFIG_IP_NF_TARGET_REDIRECT=m
CONFIG_IP_NF_MANGLE=m
CONFIG_IP_NF_RAW=m
CONFIG_IP_NF_SECURITY=m
CONFIG_IP_NF_ARPTABLES=m
CONFIG_IP_NF_ARPFILTER=m
CONFIG_IP_NF_ARP_MANGLE=m
CONFIG_IP6_NF_IPTABLES=m
CONFIG_IP6_NF_FILTER=m
CONFIG_IP6_NF_TARGET_REJECT=m
CONFIG_IP6_NF_MANGLE=m
CONFIG_IP6_NF_RAW=m
CONFIG_IP6_NF_NAT=m
CONFIG_IP6_NF_TARGET_MASQUERADE=m
CONFIG_BRIDGE=y
CONFIG_BRIDGE_VLAN_FILTERING=y
CONFIG_NET_DSA=m
CONFIG_NET_DSA_TAG_OCELOT=m
CONFIG_VLAN_8021Q=m
CONFIG_VLAN_8021Q_GVRP=y
CONFIG_VLAN_8021Q_MVRP=y
CONFIG_NET_SCHED=y
CONFIG_NET_SCH_HTB=y
CONFIG_NET_SCH_CBS=y
CONFIG_NET_SCH_ETF=m
CONFIG_NET_SCH_TAPRIO=m
CONFIG_NET_SCH_MQPRIO=m
CONFIG_NET_SCH_INGRESS=m
CONFIG_NET_CLS_BASIC=m
CONFIG_NET_CLS_U32=y
CONFIG_NET_CLS_CGROUP=y
CONFIG_NET_CLS_FLOWER=m
CONFIG_NET_EMATCH=y
CONFIG_NET_EMATCH_U32=y
CONFIG_NET_CLS_ACT=y
CONFIG_NET_ACT_POLICE=m
CONFIG_NET_ACT_GACT=m
CONFIG_NET_ACT_MIRRED=m
CONFIG_NET_ACT_GATE=m
CONFIG_CGROUP_NET_PRIO=y
CONFIG_BPF_JIT=y
CONFIG_CAN=m
CONFIG_CAN_VCAN=m
CONFIG_CAN_SLCAN=m
CONFIG_CAN_C_CAN=m
CONFIG_CAN_CC770=m
CONFIG_CAN_CC770_ISA=m
CONFIG_CAN_CC770_PLATFORM=m
CONFIG_CAN_M_CAN=m
CONFIG_CAN_SJA1000=m
CONFIG_CAN_EMS_PCI=m
CONFIG_CAN_KVASER_PCI=m
CONFIG_CAN_PLX_PCI=m
CONFIG_CAN_SJA1000_ISA=m
CONFIG_CAN_SJA1000_PLATFORM=m
CONFIG_CAN_SOFTING=m
CONFIG_CAN_MCP251X=m
CONFIG_CAN_8DEV_USB=m
CONFIG_CAN_EMS_USB=m
CONFIG_CAN_ESD_USB2=m
CONFIG_CAN_GS_USB=m
CONFIG_CAN_KVASER_USB=m
CONFIG_CAN_PEAK_USB=m
CONFIG_MTTCAN=m
CONFIG_TEGRA_HV_SECCAN=m
CONFIG_BT=y
CONFIG_BT_RFCOMM=y
CONFIG_BT_BNEP=m
CONFIG_BT_HIDP=y
# CONFIG_BT_LE is not set
CONFIG_BT_LEDS=y
# CONFIG_BT_DEBUGFS is not set
CONFIG_BT_HCIBTUSB=m
CONFIG_BT_HCIUART=m
CONFIG_BT_HCIUART_BCSP=y
CONFIG_BT_HCIUART_ATH3K=y
CONFIG_BT_HCIUART_LL=y
CONFIG_BT_HCIUART_INTEL=y
CONFIG_BT_HCIUART_BCM=y
CONFIG_BT_HCIUART_QCA=y
CONFIG_BT_HCIBCM203X=m
CONFIG_BT_HCIBPA10X=m
CONFIG_BT_HCIBFUSB=m
CONFIG_BT_HCIVHCI=m
CONFIG_BT_MRVL=m
CONFIG_BT_MRVL_SDIO=m
CONFIG_BT_ATH3K=m
CONFIG_AF_RXRPC=m
CONFIG_AF_KCM=m
CONFIG_CFG80211=m
CONFIG_CFG80211_CERTIFICATION_ONUS=y
# CONFIG_CFG80211_REQUIRE_SIGNED_REGDB is not set
CONFIG_MAC80211=m
CONFIG_RFKILL=y
CONFIG_NET_9P=y
CONFIG_NFC=m
CONFIG_NFC_NCI=m
CONFIG_NFC_S3FWRN5_I2C=m
CONFIG_PCI=y
CONFIG_PCIEPORTBUS=y
CONFIG_PCIEAER=y
CONFIG_PCIE_ECRC=y
CONFIG_PCIEASPM_POWER_SUPERSAVE=y
CONFIG_PCI_STUB=m
CONFIG_PCI_IOV=y
CONFIG_PCIE_BUS_SAFE=y
CONFIG_PCI_TEGRA=y
CONFIG_PCIE_TEGRA194_EP=y
CONFIG_PCIE_LAYERSCAPE_GEN4=y
CONFIG_PCIE_TEGRA_VF=y
CONFIG_PCI_ENDPOINT=y
CONFIG_PCI_ENDPOINT_CONFIGFS=y
CONFIG_PCI_EPF_TEST=y
CONFIG_PCIE_EPF_NV_TEST=y
CONFIG_PCIE_EPF_TEGRA_VNET=y
CONFIG_PCI_SERIAL_CH384=m
CONFIG_UEVENT_HELPER=y
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_FW_LOADER_USER_HELPER=y
CONFIG_FW_LOADER_USER_HELPER_FALLBACK=y
CONFIG_BRCMSTB_GISB_ARB=y
CONFIG_SIMPLE_PM_BUS=y
CONFIG_TEGRA_ACONNECT=y
CONFIG_VEXPRESS_CONFIG=y
CONFIG_MTD=m
CONFIG_MTD_CMDLINE_PARTS=m
CONFIG_MTD_BLOCK=m
CONFIG_MTD_QSPI_FLASH=m
CONFIG_MTD_TEGRA_VIRT=m
CONFIG_MTD_RAW_NAND=m
CONFIG_MTD_SPI_NOR=m
CONFIG_MTD_UBI=m
# CONFIG_PNP_DEBUG_MESSAGES is not set
CONFIG_ZRAM=m
CONFIG_BLK_DEV_LOOP=m
CONFIG_BLK_DEV_NBD=m
CONFIG_BLK_DEV_RAM=m
CONFIG_BLK_DEV_RAM_SIZE=8192
CONFIG_VIRTIO_BLK=y
CONFIG_TEGRA_HV_BLKDEV=y
CONFIG_TEGRA_HV_BLKDEV_OOPS=y
CONFIG_BLK_DEV_NVME=y
CONFIG_NVME_RDMA=m
CONFIG_NVME_FC=m
CONFIG_TIFM_CORE=m
CONFIG_SRAM=y
CONFIG_PCI_ENDPOINT_TEST=m
CONFIG_EEPROM_AT24=m
CONFIG_EEPROM_AT25=m
CONFIG_CB710_CORE=m
CONFIG_MODS=m
CONFIG_SENSORS_F75308=m
CONFIG_SENSORS_NCT1008=m
CONFIG_SENSORS_PEX9749=y
CONFIG_FAN_THERM_EST=y
CONFIG_EQOS_APE_HWDEP=m
CONFIG_TEGRA_ACSL=m
CONFIG_TEGRA_PCIE_EP_MEM=y
CONFIG_NVS_LIGHT=m
CONFIG_NVS_PROXIMITY=y
CONFIG_NVS_GTE=m
CONFIG_TEGRA_PROFILER=y
CONFIG_NVSCIC2C_PCIE=m
CONFIG_NVSCIIPC=y
CONFIG_BLUEDROID_PM=m
CONFIG_SCSI=y
CONFIG_BLK_DEV_SD=y
CONFIG_SCSI_SAS_ATA=y
CONFIG_SCSI_HISI_SAS=m
CONFIG_SCSI_HISI_SAS_PCI=m
CONFIG_SCSI_MPT3SAS=m
CONFIG_SCSI_UFSHCD=y
CONFIG_SCSI_UFSHCD_PLATFORM=y
CONFIG_SCSI_UFSHCD_TEGRA=y
CONFIG_ATA=m
# CONFIG_ATA_ACPI is not set
CONFIG_SATA_AHCI=m
CONFIG_SATA_AHCI_PLATFORM=m
CONFIG_MD=y
CONFIG_BLK_DEV_DM=y
CONFIG_DM_CRYPT=y
CONFIG_DM_UEVENT=y
CONFIG_DM_VERITY=y
CONFIG_DM_VERITY_VERIFY_ROOTHASH_SIG=y
CONFIG_NETDEVICES=y
CONFIG_DUMMY=y
CONFIG_MACVLAN=m
CONFIG_MACVTAP=m
CONFIG_IPVLAN=m
CONFIG_VXLAN=y
CONFIG_TUN=y
CONFIG_VETH=m
CONFIG_VIRTIO_NET=y
CONFIG_TYPHOON=m
CONFIG_ET131X=m
CONFIG_SLICOSS=m
CONFIG_ACENIC=m
CONFIG_ALTERA_TSE=m
CONFIG_AQTION=m
CONFIG_ATL2=m
CONFIG_ATL1=m
CONFIG_ATL1E=m
CONFIG_ATL1C=m
CONFIG_ALX=m
# CONFIG_NET_VENDOR_AURORA is not set
CONFIG_B44=m
CONFIG_CNIC=m
CONFIG_TIGON3=y
CONFIG_BNX2X=m
CONFIG_BNXT=m
CONFIG_BNA=m
CONFIG_MACB=y
CONFIG_THUNDER_NIC_PF=m
CONFIG_THUNDER_NIC_VF=m
# CONFIG_CAVIUM_PTP is not set
CONFIG_LIQUIDIO=m
CONFIG_LIQUIDIO_VF=m
CONFIG_CHELSIO_T1=m
CONFIG_CHELSIO_T1_1G=y
CONFIG_CHELSIO_T3=m
CONFIG_CHELSIO_T4=m
CONFIG_CHELSIO_T4VF=m
CONFIG_ENIC=m
CONFIG_DL2K=m
CONFIG_BE2NET=m
CONFIG_HNS_DSAF=y
CONFIG_HNS_ENET=y
CONFIG_HNS3=y
# CONFIG_HNS3_HCLGE is not set
CONFIG_HNS3_ENET=y
CONFIG_HINIC=m
CONFIG_E100=m
CONFIG_E1000=m
CONFIG_E1000E=y
CONFIG_IGB=y
CONFIG_IGBVF=m
CONFIG_IXGB=m
CONFIG_IXGBE=m
# CONFIG_IXGBE_HWMON is not set
CONFIG_IXGBEVF=m
CONFIG_I40E=m
CONFIG_I40EVF=m
CONFIG_ICE=m
CONFIG_FM10K=m
CONFIG_IGC=m
CONFIG_JME=m
CONFIG_SKGE=m
CONFIG_SKY2=m
CONFIG_SKY2_DEBUG=y
CONFIG_OAK=m
CONFIG_MLX4_EN=m
CONFIG_MLX5_CORE=m
CONFIG_MLX5_CORE_EN=y
CONFIG_MLX5_CORE_IPOIB=y
CONFIG_MLX5_CORE_THERMAL=y
CONFIG_MLXSW_CORE=y
CONFIG_MLX_MFT=m
CONFIG_LAN743X=m
CONFIG_NATSEMI=m
CONFIG_NS83820=m
CONFIG_S2IO=m
CONFIG_VXGE=m
CONFIG_NFP=m
CONFIG_NFP_DEBUG=y
CONFIG_NI_XGE_MANAGEMENT_ENET=m
CONFIG_NE2K_PCI=m
CONFIG_FORCEDETH=y
CONFIG_PCIE_TEGRA_VNET=y
CONFIG_HAMACHI=m
CONFIG_YELLOWFIN=m
CONFIG_IONIC=m
CONFIG_QLA3XXX=m
CONFIG_QLCNIC=m
CONFIG_NETXEN_NIC=m
CONFIG_QCA7000_SPI=m
CONFIG_QCOM_EMAC=m
CONFIG_8139CP=m
CONFIG_8139TOO=m
CONFIG_R8169=m
CONFIG_R8168=m
CONFIG_SXGBE_ETH=m
CONFIG_SFC=m
CONFIG_SMC91X=y
CONFIG_SMSC911X=y
# CONFIG_NET_VENDOR_SOCIONEXT is not set
CONFIG_STMMAC_ETH=m
# CONFIG_NET_VENDOR_XILINX is not set
CONFIG_NVETHERNET=y
CONFIG_NVETHERNET_SELFTESTS=y
CONFIG_AQUANTIA_PHY=y
CONFIG_BROADCOM_PHY=y
CONFIG_MARVELL_PHY=y
CONFIG_MARVELL_10G_PHY=m
CONFIG_MICREL_PHY=m
CONFIG_MDIO_BITBANG=y
CONFIG_PPP=y
CONFIG_PPP_BSDCOMP=y
CONFIG_PPP_DEFLATE=y
CONFIG_PPP_FILTER=y
CONFIG_PPP_MPPE=y
CONFIG_PPP_ASYNC=y
CONFIG_PPP_SYNC_TTY=y
CONFIG_USB_CATC=m
CONFIG_USB_KAWETH=m
CONFIG_USB_PEGASUS=m
CONFIG_USB_RTL8150=m
CONFIG_USB_RTL8152=y
CONFIG_USB_LAN78XX=m
CONFIG_USB_USBNET=y
CONFIG_USB_NET_CDC_EEM=m
CONFIG_USB_NET_CDC_MBIM=m
CONFIG_USB_NET_DM9601=m
CONFIG_USB_NET_SR9700=m
CONFIG_USB_NET_SR9800=m
CONFIG_USB_NET_SMSC75XX=m
CONFIG_USB_NET_SMSC95XX=m
CONFIG_USB_NET_GL620A=m
CONFIG_USB_NET_PLUSB=m
CONFIG_USB_NET_MCS7830=m
CONFIG_USB_NET_RNDIS_HOST=m
CONFIG_USB_ALI_M5632=y
CONFIG_USB_AN2720=y
CONFIG_USB_KC2190=y
CONFIG_USB_NET_CX82310_ETH=m
CONFIG_USB_NET_AQC111=y
CONFIG_ATH9K=m
CONFIG_ATH9K_DEBUGFS=y
CONFIG_ATH9K_STATION_STATISTICS=y
CONFIG_ATH9K_WOW=y
CONFIG_ATH9K_HTC=m
CONFIG_ATH9K_HTC_DEBUGFS=y
CONFIG_CARL9170=m
CONFIG_CARL9170_DEBUGFS=y
CONFIG_ATH6KL=m
CONFIG_ATH6KL_SDIO=m
CONFIG_ATH6KL_USB=m
CONFIG_AR5523=m
CONFIG_WIL6210=m
CONFIG_ATH10K=m
CONFIG_ATH10K_PCI=m
CONFIG_ATH10K_AHB=y
CONFIG_ATH10K_SDIO=m
CONFIG_ATH10K_USB=m
CONFIG_ATH10K_DEBUGFS=y
CONFIG_WCN36XX=m
CONFIG_WCN36XX_DEBUGFS=y
CONFIG_ATMEL=m
CONFIG_AT76C50X_USB=m
CONFIG_B43=m
CONFIG_B43_SDIO=y
CONFIG_B43LEGACY=m
CONFIG_BRCMFMAC=m
# CONFIG_BRCMFMAC_SDIO is not set
CONFIG_BRCMFMAC_PCIE=y
CONFIG_IPW2100=m
CONFIG_IPW2200=m
CONFIG_IWL3945=m
CONFIG_IWLWIFI=m
CONFIG_IWLDVM=m
CONFIG_IWLMVM=m
CONFIG_IWLWIFI_BCAST_FILTERING=y
CONFIG_IWLWIFI_DEBUG=y
CONFIG_IWLWIFI_DEBUGFS=y
CONFIG_HERMES=m
CONFIG_HERMES_PRISM=y
CONFIG_PLX_HERMES=m
CONFIG_TMD_HERMES=m
CONFIG_NORTEL_HERMES=m
CONFIG_ORINOCO_USB=m
CONFIG_P54_COMMON=m
CONFIG_P54_USB=m
CONFIG_P54_PCI=m
CONFIG_P54_SPI=m
CONFIG_LIBERTAS=m
CONFIG_LIBERTAS_THINFIRM=m
CONFIG_MWIFIEX=m
CONFIG_MWIFIEX_SDIO=m
CONFIG_MWIFIEX_PCIE=m
CONFIG_MWIFIEX_USB=m
CONFIG_MWL8K=m
CONFIG_MT7601U=m
CONFIG_MT76x0U=m
CONFIG_MT76x0E=m
CONFIG_MT76x2E=m
CONFIG_MT76x2U=m
CONFIG_MT7603E=m
CONFIG_MT7615E=m
CONFIG_MT7663U=m
CONFIG_MT7915E=m
# CONFIG_WLAN_VENDOR_MICROCHIP is not set
CONFIG_RT2X00=m
CONFIG_RT2800PCI=m
CONFIG_RT2500USB=m
CONFIG_RT73USB=m
CONFIG_RT2800USB=m
CONFIG_RT2800USB_RT3573=y
CONFIG_RT2800USB_RT53XX=y
CONFIG_RT2800USB_RT55XX=y
CONFIG_RT2800USB_UNKNOWN=y
CONFIG_RT2X00_LIB_DEBUGFS=y
CONFIG_RTL8187=m
CONFIG_RTL8192CE=m
CONFIG_RTL8192SE=m
CONFIG_RTL8192DE=m
CONFIG_RTL8723AE=m
CONFIG_RTL8723BE=m
CONFIG_RTL8188EE=m
CONFIG_RTL8192EE=m
CONFIG_RTL8821AE=m
CONFIG_RTL8192CU=m
CONFIG_RTL8XXXU=m
CONFIG_RTL8XXXU_UNTESTED=y
CONFIG_RSI_91X=m
# CONFIG_RSI_COEX is not set
CONFIG_CW1200=m
CONFIG_CW1200_WLAN_SDIO=m
CONFIG_WL1251=m
CONFIG_WL1251_SDIO=m
CONFIG_WL12XX=m
CONFIG_WL18XX=m
CONFIG_WLCORE_SDIO=m
CONFIG_USB_ZD1201=m
CONFIG_ZD1211RW=m
CONFIG_BCMDHD=m
CONFIG_BCM4354=y
CONFIG_BCMDHD_HW_OOB=y
CONFIG_DHD_USE_SCHED_SCAN=y
CONFIG_BCMDHD_DISABLE_MCC=y
CONFIG_RTL8822CE=m
CONFIG_TEGRA_HV_NET=y
CONFIG_INPUT_LEDS=m
CONFIG_INPUT_POLLDEV=m
CONFIG_INPUT_MOUSEDEV=y
CONFIG_INPUT_JOYDEV=y
CONFIG_INPUT_EVDEV=y
CONFIG_KEYBOARD_ADP5588=m
CONFIG_KEYBOARD_ADP5589=m
CONFIG_KEYBOARD_ATKBD=m
CONFIG_KEYBOARD_QT1070=m
CONFIG_KEYBOARD_QT2160=m
CONFIG_KEYBOARD_LKKBD=m
CONFIG_KEYBOARD_GPIO=y
CONFIG_KEYBOARD_GPIO_POLLED=m
CONFIG_KEYBOARD_TCA6416=m
CONFIG_KEYBOARD_TCA8418=m
CONFIG_KEYBOARD_MATRIX=m
CONFIG_KEYBOARD_LM8323=m
CONFIG_KEYBOARD_LM8333=m
CONFIG_KEYBOARD_MAX7359=m
CONFIG_KEYBOARD_MCS=m
CONFIG_KEYBOARD_MPR121=m
CONFIG_KEYBOARD_NEWTON=m
CONFIG_KEYBOARD_TEGRA=m
CONFIG_KEYBOARD_OPENCORES=m
CONFIG_KEYBOARD_SAMSUNG=m
CONFIG_KEYBOARD_STOWAWAY=m
CONFIG_KEYBOARD_OMAP4=m
CONFIG_KEYBOARD_XTKBD=m
CONFIG_KEYBOARD_CAP11XX=m
CONFIG_KEYBOARD_BCM=m
CONFIG_MOUSE_PS2=m
CONFIG_MOUSE_SERIAL=m
CONFIG_MOUSE_APPLETOUCH=m
CONFIG_MOUSE_BCM5974=m
CONFIG_MOUSE_CYAPA=m
CONFIG_MOUSE_VSXXXAA=m
CONFIG_MOUSE_GPIO=m
CONFIG_MOUSE_SYNAPTICS_I2C=m
CONFIG_MOUSE_SYNAPTICS_USB=m
CONFIG_INPUT_JOYSTICK=y
CONFIG_JOYSTICK_XPAD=y
CONFIG_INPUT_TABLET=y
CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_ATMEL_MXT=m
CONFIG_INPUT_MISC=y
CONFIG_INPUT_UINPUT=y
CONFIG_SERIO_SERPORT=m
CONFIG_SERIO_AMBAKMI=m
CONFIG_LEGACY_PTY_COUNT=16
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_EXTENDED=y
CONFIG_SERIAL_8250_SHARE_IRQ=y
CONFIG_SERIAL_8250_DW=m
CONFIG_SERIAL_OF_PLATFORM=y
CONFIG_SERIAL_AMBA_PL011=y
CONFIG_SERIAL_AMBA_PL011_CONSOLE=y
CONFIG_SERIAL_TEGRA=y
CONFIG_SERIAL_TEGRA_TCU=y
CONFIG_SERIAL_XILINX_PS_UART=y
CONFIG_SERIAL_FSL_LPUART=y
CONFIG_TEGRA_COMBINED_UART_EARLY=y
CONFIG_SERIAL_DEV_BUS=y
CONFIG_VIRTIO_CONSOLE=y
CONFIG_I2C_CHARDEV=y
CONFIG_I2C_MUX=y
CONFIG_I2C_MUX_GPIO=y
CONFIG_I2C_MUX_PCA954x=y
CONFIG_I2C_ALI1535=m
CONFIG_I2C_ALI1563=m
CONFIG_I2C_ALI15X3=m
CONFIG_I2C_AMD756=m
CONFIG_I2C_AMD8111=m
CONFIG_I2C_I801=m
CONFIG_I2C_ISCH=m
CONFIG_I2C_PIIX4=m
CONFIG_I2C_NFORCE2=m
CONFIG_I2C_SIS630=m
CONFIG_I2C_VIAPRO=m
CONFIG_I2C_CADENCE=m
CONFIG_I2C_CBUS_GPIO=m
CONFIG_I2C_DESIGNWARE_PLATFORM=m
CONFIG_I2C_DESIGNWARE_PCI=m
CONFIG_I2C_EMEV2=m
CONFIG_I2C_GPIO=m
CONFIG_I2C_NOMADIK=m
CONFIG_I2C_OCORES=m
CONFIG_I2C_PCA_PLATFORM=m
CONFIG_I2C_RK3X=m
CONFIG_I2C_SIMTEC=m
CONFIG_I2C_TEGRA=y
CONFIG_I2C_DIOLAN_U2C=m
CONFIG_I2C_NVVRS11=m
CONFIG_I2C_TEGRA_CAMRTC=y
CONFIG_I2C_TEGRA_SLAVE=m
CONFIG_I2C_TEGRA194_SLAVE=m
CONFIG_I2C_STUB=m
CONFIG_I2C_SLAVE_EEPROM=m
CONFIG_SPI=y
CONFIG_SPI_CADENCE=m
CONFIG_SPI_CADENCE_QUADSPI=y
CONFIG_SPI_NXP_FLEXSPI=y
CONFIG_SPI_PXA2XX=m
CONFIG_SPI_SC18IS602=m
CONFIG_SPI_TEGRA114=m
CONFIG_SPI_TEGRA124_SLAVE=y
CONFIG_SPI_TEGRA194_SLAVE=y
CONFIG_QSPI_TEGRA23x=y
CONFIG_QSPI_TEGRA210=m
CONFIG_SPI_XCOMM=m
CONFIG_SPI_ZYNQMP_GQSPI=m
CONFIG_SPI_SPIDEV=m
CONFIG_SPI_TLE62X0=m
CONFIG_SPMI=m
CONFIG_PPS_DEBUG=y
CONFIG_PPS_CLIENT_GPIO=y
CONFIG_PINCTRL_TEGRA186_DPAUX=y
CONFIG_PINCTRL_TEGRA234_DPAUX=y
CONFIG_PINCTRL_SINGLE=y
CONFIG_PINCTRL_MAX77620=y
CONFIG_GPIO_SYSFS=y
CONFIG_GPIO_MB86S7X=y
CONFIG_GPIO_PCA953X=y
CONFIG_GPIO_PCA953X_IRQ=y
CONFIG_GPIO_BD9571MWV=m
CONFIG_GPIO_MAX77620=y
CONFIG_GPIO_TMPM32X_I2C=y
CONFIG_POWER_RESET_MAX77620=y
CONFIG_BATTERY_SBS=m
CONFIG_BATTERY_BQ27XXX=y
CONFIG_SENSORS_PWM_FAN=m
CONFIG_SENSORS_INA2XX=m
CONFIG_SENSORS_INA3221=m
CONFIG_GPIO_TACHOMETER=y
CONFIG_THERMAL_WRITABLE_TRIPS=y
CONFIG_THERMAL_GOV_POWER_ALLOCATOR=y
CONFIG_CPU_THERMAL=y
CONFIG_DEVFREQ_THERMAL=y
CONFIG_THERMAL_EMULATION=y
CONFIG_MAX77620_THERMAL=m
CONFIG_TEGRA_SOCTHERM=y
CONFIG_TEGRA_BPMP_THERMAL=m
CONFIG_TEGRA_AOTAG=y
CONFIG_TEGRA_TJ_THERMAL=y
CONFIG_TEGRA_CORE_CAPS=y
CONFIG_TEGRA_DFLL_CAPS=y
CONFIG_THERMAL_GOV_PID=y
CONFIG_USERSPACE_THERM_ALERT=m
CONFIG_TEGRA23X_OC_EVENT=y
CONFIG_TEGRA19X_OC_EVENT=y
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_NOWAYOUT=y
CONFIG_MAX77620_WATCHDOG=y
CONFIG_ARM_SMC_WATCHDOG=y
CONFIG_TEGRA21X_WATCHDOG=y
CONFIG_TEGRA18X_WATCHDOG=y
CONFIG_TEGRA_HV_WATCHDOG=y
CONFIG_MFD_BD9571MWV=y
CONFIG_MFD_HI6421_PMIC=y
CONFIG_MFD_MAX77620=y
CONFIG_MFD_RK808=y
CONFIG_MFD_SEC_CORE=y
CONFIG_MFD_ROHM_BD718XX=y
CONFIG_MFD_NVVRS_PSEQ=y
CONFIG_NVVRS_PSEQ_RTC=y
CONFIG_REGULATOR=y
CONFIG_REGULATOR_FIXED_VOLTAGE=y
CONFIG_REGULATOR_GPIO=y
CONFIG_REGULATOR_MAX77620=y
CONFIG_REGULATOR_PWM=y
CONFIG_REGULATOR_TPS65132=y
CONFIG_REGULATOR_PMIC_OTP=y
CONFIG_REGULATOR_NCP81599=y
CONFIG_RC_CORE=y
CONFIG_MEDIA_SUPPORT=y
CONFIG_MEDIA_SUPPORT_FILTER=y
# CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set
CONFIG_MEDIA_CAMERA_SUPPORT=y
CONFIG_MEDIA_DIGITAL_TV_SUPPORT=y
CONFIG_MEDIA_PLATFORM_SUPPORT=y
CONFIG_MEDIA_TEST_SUPPORT=y
CONFIG_VIDEO_V4L2_SUBDEV_API=y
# CONFIG_DVB_DYNAMIC_MINORS is not set
CONFIG_MEDIA_USB_SUPPORT=y
CONFIG_USB_VIDEO_CLASS=m
CONFIG_USB_M5602=m
CONFIG_USB_STV06XX=m
CONFIG_USB_GL860=m
CONFIG_USB_GSPCA_BENQ=m
CONFIG_USB_GSPCA_CONEX=m
CONFIG_USB_GSPCA_CPIA1=m
CONFIG_USB_GSPCA_DTCS033=m
CONFIG_USB_GSPCA_ETOMS=m
CONFIG_USB_GSPCA_FINEPIX=m
CONFIG_USB_GSPCA_JEILINJ=m
CONFIG_USB_GSPCA_JL2005BCD=m
CONFIG_USB_GSPCA_KINECT=m
CONFIG_USB_GSPCA_KONICA=m
CONFIG_USB_GSPCA_MARS=m
CONFIG_USB_GSPCA_MR97310A=m
CONFIG_USB_GSPCA_NW80X=m
CONFIG_USB_GSPCA_OV519=m
CONFIG_USB_GSPCA_OV534=m
CONFIG_USB_GSPCA_OV534_9=m
CONFIG_USB_GSPCA_PAC207=m
CONFIG_USB_GSPCA_PAC7302=m
CONFIG_USB_GSPCA_PAC7311=m
CONFIG_USB_GSPCA_SE401=m
CONFIG_USB_GSPCA_SN9C2028=m
CONFIG_USB_GSPCA_SN9C20X=m
CONFIG_USB_GSPCA_SONIXB=m
CONFIG_USB_GSPCA_SONIXJ=m
CONFIG_USB_GSPCA_SPCA500=m
CONFIG_USB_GSPCA_SPCA501=m
CONFIG_USB_GSPCA_SPCA505=m
CONFIG_USB_GSPCA_SPCA506=m
CONFIG_USB_GSPCA_SPCA508=m
CONFIG_USB_GSPCA_SPCA561=m
CONFIG_USB_GSPCA_SPCA1528=m
CONFIG_USB_GSPCA_SQ905=m
CONFIG_USB_GSPCA_SQ905C=m
CONFIG_USB_GSPCA_SQ930X=m
CONFIG_USB_GSPCA_STK014=m
CONFIG_USB_GSPCA_STK1135=m
CONFIG_USB_GSPCA_STV0680=m
CONFIG_USB_GSPCA_SUNPLUS=m
CONFIG_USB_GSPCA_T613=m
CONFIG_USB_GSPCA_TOPRO=m
CONFIG_USB_GSPCA_TOUPTEK=m
CONFIG_USB_GSPCA_TV8532=m
CONFIG_USB_GSPCA_VC032X=m
CONFIG_USB_GSPCA_VICAM=m
CONFIG_USB_GSPCA_XIRLINK_CIT=m
CONFIG_USB_GSPCA_ZC3XX=m
CONFIG_USB_PWC=m
CONFIG_VIDEO_CPIA2=m
CONFIG_USB_ZR364XX=m
CONFIG_USB_STKWEBCAM=m
CONFIG_USB_S2255=m
CONFIG_VIDEO_USBTV=m
CONFIG_V4L_PLATFORM_DRIVERS=y
CONFIG_VIDEO_CAMERA=y
CONFIG_VIDEO_ISC=m
CONFIG_VIDEO_CDI=m
CONFIG_V4L_TEST_DRIVERS=y
CONFIG_VIDEO_ECAM=m
CONFIG_NV_VIDEO_IMX185=m
CONFIG_NV_VIDEO_IMX219=m
CONFIG_NV_VIDEO_IMX477=m
CONFIG_NV_VIDEO_IMX268=m
CONFIG_NV_VIDEO_IMX274=m
CONFIG_NV_VIDEO_IMX318=m
CONFIG_NV_VIDEO_LC898212=m
CONFIG_NV_VIDEO_OV5693=m
CONFIG_NV_VIDEO_OV9281=m
CONFIG_NV_VIDEO_OV10823=m
CONFIG_NV_VIDEO_OV23850=m
CONFIG_I2C_IOEXPANDER_PCA9570=m
CONFIG_VIDEO_TC358840=m
CONFIG_VIDEO_LT6911UXC=m
CONFIG_I2C_IOEXPANDER_SER_MAX9295=y
CONFIG_I2C_IOEXPANDER_DESER_MAX9296=y
CONFIG_NV_VIDEO_IMX390=y
CONFIG_NV_DESER_MAX96712=m
CONFIG_NV_VIDEO_AR0234=m
CONFIG_NV_VIDEO_HAWK_OWL=m
# CONFIG_CXD2880_SPI_DRV is not set
CONFIG_MEDIA_TUNER_SIMPLE=y
# CONFIG_MEDIA_TUNER_TDA18250 is not set
CONFIG_MEDIA_TUNER_TDA8290=y
# CONFIG_MEDIA_TUNER_TDA18272 is not set
CONFIG_MEDIA_TUNER_MT20XX=y
CONFIG_MEDIA_TUNER_XC2028=y
CONFIG_MEDIA_TUNER_XC5000=y
CONFIG_MEDIA_TUNER_XC4000=y
CONFIG_MEDIA_TUNER_MC44S803=y
# CONFIG_MEDIA_TUNER_FC2580 is not set
# CONFIG_MEDIA_TUNER_M88RS6000T is not set
# CONFIG_MEDIA_TUNER_TUA9001 is not set
# CONFIG_MEDIA_TUNER_SI2157 is not set
# CONFIG_MEDIA_TUNER_IT913X is not set
# CONFIG_MEDIA_TUNER_R820T is not set
# CONFIG_MEDIA_TUNER_MXL301RF is not set
# CONFIG_MEDIA_TUNER_QM1D1C0042 is not set
# CONFIG_MEDIA_TUNER_QM1D1B0004 is not set
# CONFIG_DVB_CXD2880 is not set
# CONFIG_DVB_MN88443X is not set
# CONFIG_DVB_LNBH29 is not set
# CONFIG_DVB_CXD2099 is not set
# CONFIG_VGA_ARB is not set
CONFIG_DRM=y
CONFIG_DRM_I2C_NXP_TDA998X=m
CONFIG_DRM_RCAR_DW_HDMI=m
CONFIG_DRM_RCAR_LVDS=m
CONFIG_DRM_PANEL_LVDS=m
CONFIG_DRM_PANEL_SIMPLE=m
CONFIG_DRM_SII902X=m
CONFIG_DRM_HISI_HIBMC=m
CONFIG_DRM_HISI_KIRIN=m
CONFIG_DRM_TEGRA_UDRM=m
CONFIG_FB_MODE_PIXCLOCK_HZ=y
CONFIG_LCD_CLASS_DEVICE=m
CONFIG_BACKLIGHT_PWM=y
CONFIG_BACKLIGHT_LP855X=y
CONFIG_TEGRA_GRHOST=y
CONFIG_TEGRA_GRHOST_NVCSI=y
CONFIG_TEGRA_GR_VIRTUALIZATION=y
CONFIG_TEGRA_DC=y
CONFIG_TEGRA_DC_SCREEN_CAPTURE=y
CONFIG_TEGRA_DSI=y
CONFIG_MAXIM_GMSL_DP_SERIALIZER=y
CONFIG_TEGRA_HDMI2_0=y
CONFIG_TEGRA_HDMIHDCP=y
CONFIG_TEGRA_DPHDCP=y
CONFIG_TEGRA_CEC_SUPPORT=y
CONFIG_TEGRA_GRHOST_SLVSEC=y
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_LOGO=y
# CONFIG_LOGO_LINUX_MONO is not set
# CONFIG_LOGO_LINUX_VGA16 is not set
# CONFIG_LOGO_LINUX_CLUT224 is not set
CONFIG_SOUND=y
CONFIG_SND=y
CONFIG_SND_ALOOP=m
CONFIG_SND_HDA_TEGRA=m
CONFIG_SND_HDA_CODEC_HDMI=m
CONFIG_SND_HDA_POWER_SAVE_DEFAULT=1
CONFIG_SND_USB_AUDIO=y
CONFIG_SND_SOC=y
CONFIG_SND_SOC_TEGRA=m
CONFIG_SND_SOC_TEGRA210_AHUB=m
CONFIG_SND_SOC_TEGRA210_DMIC=m
CONFIG_SND_SOC_TEGRA210_I2S=m
CONFIG_SND_SOC_TEGRA186_DSPK=m
CONFIG_SND_SOC_TEGRA210_ADMAIF=m
CONFIG_SND_SOC_TEGRA186_ARAD=m
CONFIG_SND_SOC_TEGRA186_ASRC=m
CONFIG_SND_SOC_TEGRA210_AMX=m
CONFIG_SND_SOC_TEGRA210_ADX=m
CONFIG_SND_SOC_TEGRA210_MIXER=m
CONFIG_SND_SOC_TEGRA210_SFC=m
CONFIG_SND_SOC_TEGRA210_MVC=m
CONFIG_SND_SOC_TEGRA210_AFC=m
CONFIG_SND_SOC_TEGRA210_IQC=m
CONFIG_SND_SOC_TEGRA210_OPE=m
CONFIG_SND_SOC_TEGRA210_ADSP=m
CONFIG_SND_SOC_TEGRA210_AUDIO=m
CONFIG_SND_SOC_TEGRA_AUDIO_GRAPH_CARD=m
CONFIG_SND_SOC_AK4613=m
CONFIG_SND_SOC_ES7134=m
CONFIG_SND_SOC_MAX98927=m
CONFIG_SND_SOC_PCM3168A_I2C=m
CONFIG_SND_SOC_RT5640=m
CONFIG_SND_SOC_SPDIF=m
CONFIG_SND_SOC_TAS571X=m
CONFIG_SND_SIMPLE_CARD=m
CONFIG_SND_AUDIO_GRAPH_CARD=m
CONFIG_SND_SOC_TEGRA210_ADSP_VIRT_ALT=m
CONFIG_SND_SOC_TEGRA_VIRT_T210REF_PCM=m
CONFIG_HIDRAW=y
CONFIG_UHID=y
CONFIG_HID_A4TECH=m
CONFIG_HID_ACRUX=y
CONFIG_HID_ACRUX_FF=y
CONFIG_HID_APPLE=y
CONFIG_HID_APPLEIR=m
CONFIG_HID_ASUS=m
CONFIG_HID_AUREAL=m
CONFIG_HID_BELKIN=m
CONFIG_HID_BETOP_FF=m
CONFIG_HID_CHERRY=m
CONFIG_HID_CHICONY=m
CONFIG_HID_CORSAIR=m
CONFIG_HID_PRODIKEYS=m
CONFIG_HID_CMEDIA=m
CONFIG_HID_CYPRESS=m
CONFIG_HID_DRAGONRISE=y
CONFIG_DRAGONRISE_FF=y
CONFIG_HID_EMS_FF=m
CONFIG_HID_ELECOM=m
CONFIG_HID_ELO=m
CONFIG_HID_EZKEY=m
CONFIG_HID_GEMBIRD=m
CONFIG_HID_GFRM=m
CONFIG_HID_HOLTEK=y
CONFIG_HID_GT683R=m
CONFIG_HID_KEYTOUCH=y
CONFIG_HID_KYE=y
CONFIG_HID_UCLOGIC=y
CONFIG_HID_WALTOP=y
CONFIG_HID_GYRATION=y
CONFIG_HID_ICADE=m
CONFIG_HID_ITE=m
CONFIG_HID_TWINHAN=y
CONFIG_HID_KENSINGTON=m
CONFIG_HID_LCPOWER=y
CONFIG_HID_LENOVO=m
CONFIG_HID_LOGITECH=m
CONFIG_HID_LOGITECH_DJ=m
CONFIG_HID_MAGICMOUSE=y
CONFIG_HID_MICROSOFT=m
CONFIG_HID_MONTEREY=m
CONFIG_HID_MULTITOUCH=y
CONFIG_HID_NTI=m
CONFIG_HID_NTRIG=y
CONFIG_HID_ORTEK=y
CONFIG_HID_PANTHERLORD=y
CONFIG_PANTHERLORD_FF=y
CONFIG_HID_PENMOUNT=m
CONFIG_HID_PETALYNX=m
CONFIG_HID_PICOLCD=m
CONFIG_HID_PICOLCD_FB=y
CONFIG_HID_PICOLCD_BACKLIGHT=y
CONFIG_HID_PLANTRONICS=m
CONFIG_HID_PRIMAX=m
CONFIG_HID_RETRODE=m
CONFIG_HID_ROCCAT=m
CONFIG_HID_SAITEK=m
CONFIG_HID_SAMSUNG=m
CONFIG_HID_SONY=m
CONFIG_HID_SPEEDLINK=m
CONFIG_HID_STEELSERIES=m
CONFIG_HID_SUNPLUS=m
CONFIG_HID_RMI=m
CONFIG_HID_GREENASIA=m
CONFIG_GREENASIA_FF=y
CONFIG_HID_SMARTJOYPLUS=m
CONFIG_SMARTJOYPLUS_FF=y
CONFIG_HID_TIVO=m
CONFIG_HID_TOPSEED=m
CONFIG_HID_THINGM=m
CONFIG_HID_THRUSTMASTER=m
CONFIG_HID_UDRAW_PS3=m
CONFIG_HID_WACOM=m
CONFIG_HID_WIIMOTE=m
CONFIG_HID_XINMO=m
CONFIG_HID_ZEROPLUS=m
CONFIG_HID_ZYDACRON=m
CONFIG_HID_SENSOR_HUB=m
CONFIG_HID_SENSOR_CUSTOM_SENSOR=m
CONFIG_HID_ALPS=m
CONFIG_USB_HIDDEV=y
CONFIG_HID_SHIELD_REMOTE=m
CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
CONFIG_USB_OTG=y
CONFIG_USB_MON=m
CONFIG_USB_XHCI_HCD=y
CONFIG_USB_XHCI_TEGRA=y
CONFIG_USB_OHCI_HCD=y
CONFIG_USB_OHCI_HCD_PLATFORM=y
CONFIG_USB_ACM=m
CONFIG_USB_PRINTER=m
CONFIG_USB_STORAGE=y
CONFIG_USB_STORAGE_REALTEK=m
CONFIG_USB_STORAGE_DATAFAB=m
CONFIG_USB_STORAGE_FREECOM=m
CONFIG_USB_STORAGE_ISD200=m
CONFIG_USB_STORAGE_USBAT=m
CONFIG_USB_STORAGE_SDDR09=m
CONFIG_USB_STORAGE_SDDR55=m
CONFIG_USB_STORAGE_JUMPSHOT=m
CONFIG_USB_STORAGE_ALAUDA=m
CONFIG_USB_STORAGE_ONETOUCH=m
CONFIG_USB_STORAGE_KARMA=m
CONFIG_USB_STORAGE_CYPRESS_ATACB=m
CONFIG_USB_STORAGE_ENE_UB6250=m
CONFIG_USB_UAS=y
CONFIG_USB_MDC800=m
CONFIG_USB_CHIPIDEA=m
CONFIG_USB_SERIAL=m
CONFIG_USB_SERIAL_CH341=m
CONFIG_USB_SERIAL_CP210X=m
CONFIG_USB_SERIAL_FTDI_SIO=m
CONFIG_USB_SERIAL_GARMIN=m
CONFIG_USB_SERIAL_KEYSPAN=m
CONFIG_USB_SERIAL_PL2303=m
CONFIG_USB_SERIAL_OPTION=m
CONFIG_USB_SERIAL_XSENS_MT=m
CONFIG_USB_EMI62=m
CONFIG_USB_EMI26=m
CONFIG_USB_SEVSEG=m
CONFIG_USB_LCD=m
CONFIG_USB_CYPRESS_CY7C63=m
CONFIG_USB_CYTHERM=m
CONFIG_USB_IDMOUSE=m
CONFIG_USB_APPLEDISPLAY=m
CONFIG_USB_LD=m
CONFIG_USB_TEST=m
CONFIG_USB_EHSET_TEST_FIXTURE=m
CONFIG_USB_YUREX=m
CONFIG_USB_HSIC_USB4604=m
CONFIG_USB_GADGET=y
CONFIG_USB_TEGRA_XUDC=y
CONFIG_USB_CONFIGFS=y
CONFIG_USB_CONFIGFS_ACM=y
CONFIG_USB_CONFIGFS_NCM=y
CONFIG_USB_CONFIGFS_ECM=y
CONFIG_USB_CONFIGFS_RNDIS=y
CONFIG_USB_CONFIGFS_MASS_STORAGE=y
CONFIG_USB_CONFIGFS_F_LB_SS=y
CONFIG_USB_CONFIGFS_F_FS=y
CONFIG_USB_CONFIGFS_F_ACC=y
CONFIG_TYPEC=m
CONFIG_TYPEC_FUSB301=m
CONFIG_TYPEC_UCSI=m
CONFIG_UCSI_CCG=m
CONFIG_TYPEC_STUSB160X=m
CONFIG_MMC=y
CONFIG_MMC_BLOCK_MINORS=32
CONFIG_MMC_TEST=m
CONFIG_MMC_ARMMMCI=y
# CONFIG_MMC_STM32_SDMMC is not set
CONFIG_MMC_SDHCI=y
CONFIG_MMC_SDHCI_PLTFM=y
CONFIG_MMC_SDHCI_TEGRA=y
CONFIG_MMC_SPI=m
CONFIG_MMC_DW=y
CONFIG_MMC_SDHCI_XENON=y
CONFIG_LEDS_CLASS=y
CONFIG_LEDS_GPIO=m
CONFIG_LEDS_PWM=m
CONFIG_LEDS_BD2802=m
CONFIG_LEDS_IS31FL319X=m
CONFIG_INFINIBAND=m
CONFIG_INFINIBAND_USER_MAD=m
CONFIG_INFINIBAND_USER_ACCESS=m
CONFIG_INFINIBAND_MTHCA=m
CONFIG_MLX4_INFINIBAND=m
CONFIG_MLX5_INFINIBAND=m
CONFIG_INFINIBAND_IPOIB=m
CONFIG_INFINIBAND_IPOIB_CM=y
CONFIG_INFINIBAND_SRP=m
CONFIG_RTC_CLASS=y
CONFIG_RTC_HCTOSYS_DEVICE="rtc1"
# CONFIG_RTC_NVMEM is not set
CONFIG_RTC_DRV_MAX77686=y
CONFIG_RTC_DRV_RX8025=m
CONFIG_DMADEVICES=y
CONFIG_TEGRA20_APB_DMA=y
CONFIG_TEGRA210_ADMA=m
CONFIG_TEGRA_GPC_DMA=y
CONFIG_DMATEST=y
CONFIG_DMABUF_HEAPS=y
CONFIG_DMABUF_HEAPS_SYSTEM=y
CONFIG_DMABUF_HEAPS_CMA=y
CONFIG_VFIO=m
CONFIG_VFIO_PCI=m
CONFIG_VIRT_DRIVERS=y
CONFIG_VIRTIO_PCI=m
CONFIG_VIRTIO_BALLOON=m
CONFIG_VIRTIO_MMIO=m
CONFIG_PRISM2_USB=m
CONFIG_RTL8192U=m
CONFIG_RTLLIB=m
CONFIG_RTL8192E=m
CONFIG_R8712U=m
CONFIG_R8188EU=m
CONFIG_QLGE=m
CONFIG_TEGRA_HTS_GTE=y
CONFIG_DENVER_CPU=y
CONFIG_TEGRA_AON=y
CONFIG_TEGRA_BWMGR=y
CONFIG_TEGRA_CAMERA_RTCPU=y
CONFIG_TEGRA_CAMERA_HSP_MBOX_CLIENT=y
CONFIG_TEGRA_FSICOM=y
CONFIG_TEGRA_EPL=y
CONFIG_TEGRA_DCE=y
CONFIG_TEGRA_ISOMGR=y
CONFIG_TEGRA_ISOMGR_SYSFS=y
CONFIG_TEGRA_SPE=y
CONFIG_TEGRA_SPE_HSP_MBOX_CLIENT=y
CONFIG_TEGRA_CENTRAL_ACTMON=y
CONFIG_TEGRA_BOOTLOADER_DEBUG=m
CONFIG_TEGRA_CLOCKS_CONFIGURE=y
CONFIG_TEGRA_USS_IO_PROXY=y
CONFIG_TEGRA_SAFETY=y
CONFIG_TEGRA_NVADSP=m
CONFIG_TEGRA_NVADSP_ON_SMMU=y
CONFIG_TEGRA_ADSP_FILEIO=y
CONFIG_TEGRA_ADSP_LPTHREAD=y
CONFIG_TEGRA_VIRT_AUDIO_IVC=y
CONFIG_COMMON_CLK_FREQ_STATS_ACCOUNTING=y
CONFIG_CLK_SRC_TEGRA18_TIMER=y
CONFIG_ARM_MHU=m
CONFIG_TEGRA_IOMMU_SMMU=y
CONFIG_ARM_SMMU=y
CONFIG_ARM_SMMU_DEBUG=y
CONFIG_ARM_SMMU_V3=y
CONFIG_SOUNDWIRE=m
CONFIG_ARCH_TEGRA_210_SOC=y
CONFIG_ARCH_TEGRA_186_SOC=y
CONFIG_ARCH_TEGRA_194_SOC=y
CONFIG_ARCH_TEGRA_234_SOC=y
CONFIG_TEGRA_KFUSE=y
CONFIG_TEGRA_FUSE_BURN=y
CONFIG_TEGRA_210_DVFS=y
CONFIG_DEVFREQ_GOV_PERFORMANCE=y
CONFIG_DEVFREQ_GOV_USERSPACE=y
CONFIG_DEVFREQ_GOV_POD_SCALING_V2=y
CONFIG_DEVFREQ_GOV_WMARK_ACTIVE=y
CONFIG_EXTCON_GPIO=y
CONFIG_EXTCON_USB_GPIO=y
CONFIG_MEMORY=y
CONFIG_IIO=y
CONFIG_HID_SENSOR_ACCEL_3D=m
CONFIG_QCOM_SPMI_ADC5=m
CONFIG_DS4424=m
CONFIG_HID_SENSOR_GYRO_3D=m
CONFIG_BMI088_IIO=m
CONFIG_NTB=m
CONFIG_NTB_SWITCHTEC=m
CONFIG_NTB_PINGPONG=m
CONFIG_NTB_TOOL=m
CONFIG_NTB_PERF=m
CONFIG_NTB_TRANSPORT=m
CONFIG_PWM=y
CONFIG_PWM_TEGRA=y
CONFIG_PWM_TEGRA_PMC_BLINK=m
CONFIG_PWM_TEGRA_TACHOMETER=y
CONFIG_PWM_TEGRA_DFLL=y
CONFIG_PHY_FSL_IMX8MQ_USB=y
CONFIG_PHY_TEGRA_XUSB=y
CONFIG_ARM_SMMU_V3_PMU=m
CONFIG_ARM_DSU_PMU=y
CONFIG_ARM_SPE_PMU=y
CONFIG_DAX=y
CONFIG_FPGA=y
CONFIG_FPGA_BRIDGE=m
CONFIG_FPGA_REGION=m
CONFIG_OF_FPGA_REGION=m
CONFIG_TEE=y
CONFIG_OPTEE=y
CONFIG_INTERCONNECT=y
CONFIG_INTERCONNECT_TEGRA=y
CONFIG_RTK_BTUSB=m
CONFIG_NVPMODEL_EMC=y
CONFIG_TEGRA_RDMA=m
CONFIG_NVPPS=m
CONFIG_TEGRA_HV_PM_CTL=y
CONFIG_TEGRA_HV_MANAGER=y
CONFIG_TEGRA_VIRTUALIZATION=y
CONFIG_EXT3_FS=y
CONFIG_EXT4_FS_POSIX_ACL=y
CONFIG_EXT4_FS_SECURITY=y
CONFIG_BTRFS_FS=m
CONFIG_BTRFS_FS_POSIX_ACL=y
CONFIG_FANOTIFY=y
CONFIG_FANOTIFY_ACCESS_PERMISSIONS=y
CONFIG_QUOTA=y
CONFIG_QUOTA_NETLINK_INTERFACE=y
CONFIG_QFMT_V2=m
CONFIG_AUTOFS4_FS=y
CONFIG_FUSE_FS=m
CONFIG_CUSE=m
CONFIG_ISO9660_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_EXFAT_FS=y
CONFIG_NTFS_FS=y
CONFIG_NTFS_RW=y
CONFIG_TMPFS=y
CONFIG_TMPFS_POSIX_ACL=y
CONFIG_HUGETLBFS=y
CONFIG_EFIVAR_FS=y
CONFIG_SQUASHFS=y
CONFIG_SQUASHFS_XATTR=y
CONFIG_SQUASHFS_LZ4=y
CONFIG_SQUASHFS_LZO=y
CONFIG_SQUASHFS_XZ=y
CONFIG_PSTORE_CONSOLE=y
CONFIG_PSTORE_RAM=m
CONFIG_NFS_FS=y
CONFIG_NFS_V3_ACL=y
CONFIG_NFS_V4=y
CONFIG_NFS_V4_1=y
CONFIG_NFS_V4_2=y
CONFIG_ROOT_NFS=y
# CONFIG_NFS_DISABLE_UDP_SUPPORT is not set
CONFIG_NFSD=m
CONFIG_NFSD_V3=y
CONFIG_NFSD_V3_ACL=y
CONFIG_CIFS=m
CONFIG_9P_FS=m
CONFIG_NLS_CODEPAGE_437=y
CONFIG_NLS_ISO8859_1=y
CONFIG_NLS_UTF8=m
CONFIG_SECURITY_DMESG_RESTRICT=y
CONFIG_SECURITY=y
CONFIG_SECURITY_NETWORK=y
CONFIG_HARDENED_USERCOPY=y
CONFIG_FORTIFY_SOURCE=y
CONFIG_SECURITY_SELINUX=y
CONFIG_SECURITY_YAMA=y
CONFIG_LSM="lockdown,yama,loadpin,safesetid,integrity,selinux,bpf"
CONFIG_CRYPTO_TEST=m
CONFIG_CRYPTO_DH=y
CONFIG_CRYPTO_SEQIV=y
CONFIG_CRYPTO_ECHAINIV=y
CONFIG_CRYPTO_CTR=y
CONFIG_CRYPTO_GHASH=y
CONFIG_CRYPTO_ARC4=y
CONFIG_CRYPTO_DES=m
CONFIG_CRYPTO_TWOFISH=m
CONFIG_CRYPTO_ANSI_CPRNG=m
CONFIG_CRYPTO_USER_API_SKCIPHER=y
CONFIG_CRYPTO_USER_API_RNG=m
CONFIG_CRYPTO_DEV_CCREE=m
CONFIG_TEGRA_CRYPTO_DEV=y
CONFIG_CRYPTO_DEV_TEGRA_SE=y
CONFIG_CRYPTO_DEV_TEGRA_ELLIPTIC_SE=y
CONFIG_CRYPTO_DEV_TEGRA_SE_USE_HOST1X_INTERFACE=y
CONFIG_CRYPTO_DEV_TEGRA_VIRTUAL_SE_INTERFACE=y
CONFIG_CRYPTO_DEV_TEGRA_SE_NVRNG=y
CONFIG_CRYPTO_DEV_TEGRA_NVVSE=y
CONFIG_CRYPTO_DEV_TEGRA_FDE=m
# CONFIG_RAID6_PQ_BENCHMARK is not set
CONFIG_DMA_CMA=y
CONFIG_CMA_SIZE_MBYTES=64
CONFIG_CMA_ALIGNMENT=9
CONFIG_PRINTK_TIME=y
CONFIG_DYNAMIC_DEBUG_CORE=y
# CONFIG_SYMBOLIC_ERRNAME is not set
CONFIG_DEBUG_INFO=y
CONFIG_FRAME_WARN=4096
# CONFIG_SECTION_MISMATCH_WARN_ONLY is not set
CONFIG_MAGIC_SYSRQ=y
CONFIG_DEBUG_FS=y
# CONFIG_DEBUG_MISC is not set
CONFIG_PANIC_ON_OOPS=y
CONFIG_SOFTLOCKUP_DETECTOR=y
CONFIG_BOOTPARAM_SOFTLOCKUP_PANIC=y
CONFIG_WQ_WATCHDOG=y
CONFIG_SCHEDSTATS=y
# CONFIG_DEBUG_PREEMPT is not set
# CONFIG_DYNAMIC_FTRACE is not set
CONFIG_STACK_TRACER=y
# CONFIG_UPROBE_EVENTS is not set
CONFIG_PID_IN_CONTEXTIDR=y
# CONFIG_RUNTIME_TESTING_MENU is not set
CONFIG_USBIP_CORE=y
CONFIG_USBIP_HOST=y
CONFIG_USBIP_VUDC=y
CONFIG_USBIP_VHCI_HCD=y
CONFIG_I2C_ATR=y
CONFIG_VIDEO_ADV_DEBUG=y
CONFIG_NV_VIDEO_CAMERA=y
CONFIG_VIDEO_MAX96724=y
CONFIG_VIDEO_MAX9296A=y
CONFIG_VIDEO_MAX96717=y
CONFIG_VIDEO_MAXIM_AGGREGATOR=y
CONFIG_DYNAMIC_DEBUG=y
CONFIG_VIDEO_MYDEVICE=m
CONFIG_OVERLAY_FS=y
# CONFIG_OVERLAY_FS_REDIRECT_ALWAYS_FOLLOW is not set
CONFIG_OVERLAY_FS_REDIRECT_ALWAYS_FOLLOW=y
CONFIG_OF_OVERLAY=y
Yes, it seems CONFIG_OF_CONFIGFS no enabled as expected so that there’s no /sys/kernel/config/device-tree.
Is it in your .config?
How did you build and update kernel image?
Here is how I build the image:
Targets: tegra_defconfig Image dtbs
Options: -C . ARCH=arm64 LOCALVERSION=-tegra O=../../kernel_out CROSS_COMPILE=/home/user/l4t-gcc/bin/aarch64-buildroot-linux-gnu- -j8
build_kernel() {
	echo "Targets: ${TARGETS[@]}"
	echo "Options: ${O_OPT[@]}"
	make "${O_OPT[@]}" "${TARGETS[@]}"
	if [[ $? -ne 0 ]]; then
		exit
	fi
I then copy the Image from HOST to ORIN through SCP to temporary location. Then I use cp to copy the image to /boot on the ORIN while running default Image. I utilize extlinux.conf to switch between different Images.
I believe the process given above good because I can see the other CONFIG_ parameters are get activated as I modify.
Is there any other precondition for CONFIG_OF_CONFIGFS to be activated that I missed?
It seems CONFIG_OF_CONFIGFS not supported in L4T.
Please just decompile dtb(/boot/dtb/kernel_XXX.dtb) to dts and reboot the board to debug.
Does the team have any plan to enable it in the near future?
Sorry that we don’t have plan of this feature for the L4T.
