Orin AGX flashing optimization issue
Hello, I am using the scripts supplied by Nvidia to build and flash the kernel/OS on a developer orin agx.
I have a built the system and want to optimise the flashing and distribution going forward.
I first run this command, followed by same command with –flash-only
  sudo ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --reuse --keep --sparse --external-device nvme0n1p1 -p "-c ./bootloader/t186ref/cfg/flash_t234_qspi.xml" \
    -c $ROOT/flash_l4t_nvme.xml -S 1500GiB --showlogs --network usb0 jetson-agx-orin-devkit internal
after running this command it looks like everything worked and I get this
Success
Cleaning up...
Keeping working dir at /home/user/_git/jetsonorinos/Linux_for_Tegra/temp_initrdflash/bootloader0 and /tmp/tmp.XEXHsQf3O5
Finish generating flash package.
Put device in recovery mode, run with option --flash-only to flash device.
However there is nothing in these folders and the command with flash-only fails stating it can’t find these folders
Please remove these and share us the full log and failure log as attachments.
Thank you for the help, this resolved it for me
