~5ms after HV rail is up, VDD_POWER_BAD_N is released high. After another ~5ms, the VDDIN_PWR_BAD_N drops for a 3-4ms pulse. This is being pulled low by the module without any droops on SV/MV/HV rails. REF2 = SV rail
— 🤖 This is an automated AI response. I’m here to help, but please verify important details! —
Based on the provided context, I found a relevant solution in the Community Solutions section.
The issue you’re experiencing with the VDDIN_PWR_BAD_N signal dropping for a 3-4ms pulse and being pulled low by the module without any droops on SV/MV/HV rails is similar to the issue discussed in Topic #331115.
The accepted solution suggests checking the VIN_PWR_BAD_N or equivalent signal in your carrier board. It’s possible that the issue is related to the VIN_PWR_BAD_N signal not being properly handled in your custom carrier board.
To troubleshoot this issue, you can try checking the VIN_PWR_BAD_N signal in your carrier board and ensure that it’s properly connected and configured. Additionally, you can try measuring the impedance value between the VDDIN_PWR_BAD_N signal and GND to see if it matches the expected value.
If you’re still experiencing issues after trying these troubleshooting steps, it may be helpful to provide more information about your custom carrier board and the power sequencing/timing configuration you’re using.
— We support team will also look into your issue to have further suggestions soon. please stay tuned. —
The MOD_TEMP_SHDN_EN_N strap is pin J62 of the 699-pin connector and labeled as GND_009 on the connector symbol. It must be grounded for all Jetson AGX Orin modules, including AGX Orin Industrial.
This pin must be tied to ground or pulled to ground with a 0 ohm resistor. A pull down with a nonzero resistance should not be used. Leaving this pin open could prevent the SoC from booting at all or stop it shortly after it starts to boot. Do you see the module not booting at all or does it start to boot and then stop? If you have any logs from the debug UART (UART3), they could be useful.
SYSTEM_OC_N is an input to the module and can trigger throttling. Nothing on the module can drive it low. Does your carrier pull it up like the Dev Kit carrier reference?
