The question is about the Jetson AGX Orin Industrial and non-industrial modules, specifically the PRSNT0 and PRSNT1 pins. These pins are used to sense the presence of the module, with PRSNT0 connected to GND and PRSNT1 having a pull-up to 3.3V in the devkit.
The user wants to know if it’s permitted to use the opposite configuration, where one of the pins is connected to 3.3V directly and the other pin has a pull-down, resulting in an active high signal.
According to the documentation, there is no explicit mention of the maximum permitted current for the PRSNT pins. However, it’s generally recommended to keep the current low to avoid overheating or damaging the module.
In terms of the configuration, it’s possible to use the opposite configuration, but it’s essential to ensure that the voltage levels are compatible with the module’s specifications. The Jetson AGX Orin module has a maximum voltage rating of 3.3V for the PRSNT pins.
To achieve an active high signal, the user can connect one of the PRSNT pins to 3.3V directly and add a pull-down resistor to the other pin. The value of the pull-down resistor should be chosen to ensure that the voltage level is below the threshold for the module’s presence detection.
It’s also possible to add an indicator LED to the circuit, but it’s crucial to ensure that the LED’s current consumption is within the module’s specifications.
In comparison to the Jetson Xavier NX and Jetson Orin NX/Nano modules, the PRSNT pins are not explicitly mentioned in the documentation. However, the general principles of presence detection and voltage levels apply to all modules.
To summarize:
- The Jetson AGX Orin Industrial and non-industrial modules have PRSNT0 and PRSNT1 pins for presence detection.
- The user can use the opposite configuration, with one pin connected to 3.3V and the other pin having a pull-down, to achieve an active high signal.
- The maximum permitted current for the PRSNT pins is not explicitly mentioned, but it’s recommended to keep the current low.
- The user can add an indicator LED to the circuit, but it’s essential to ensure that the LED’s current consumption is within the module’s specifications.
It’s always recommended to consult the official documentation and seek guidance from NVIDIA support before making any modifications to the module’s configuration.
