Orin AGX mass flash
I am using Jetpack 5.0.2 and the script nvmassflashgen.sh is not available, but based on the document Linux_for_Tegra/tools/kernel_flash/README_initrd_flash.txt we can use the script l4t_initrd_flash.sh to apply a similar procedure to the previous mass flash script.
Can someone confirm if, Was the nvmassflashgen.sh removed and now the procedure should be done using l4t_initrd_flash tool?
Regards,
hello ManuelLeiva,
BTW, you should see-also [r35.1 release note]
3742857
Massfuse functionality is not currently supported in the 35.1 GA release. This functionality will be made available soon**
