Orin AGX power on issue
I have a power issue with one of my orin AGX developer kits. When I plug in the power source, the carrier board light flashes on for a second then off and the orin does not start up. It has been running no problem for a while.
I have tried inputting the power through both the USB C port and DC barrel connecter, both having the same result. I cant see any visible signs of shorts/damage on the board and there is no apparent break in the heat sync connection.
Is there any ideas on why it may not be starting up?
Is there a quick fix or could it be an internal issue?
Any help would be appreciated, urgently trying to get it back up and running.
did you get anything from UART after trying to power on the device?
