Using a webcam with new Orin system. Upon plugging in camera shows up in /dev/video
orin@orin1:~$ ls /dev/vid*
/dev/video0 /dev/video1
orin@orin1:~$ lsusb
Bus 001 Device 009: ID 0c45:6366 Microdia USB 2.0 Camera
However, within the jetson-inference containter (the Hello World AI example at https://github.com/dusty-nv/jetson-inference/blob/master/docs/aux-docker.md ) it does not show up:
root@orin1:/jetson-inference/build/aarch64/bin# video-viewer v4l2:///dev/video0
[gstreamer] initialized gstreamer, version 1.16.2.0
[gstreamer] gstCamera – attempting to create device v4l2:///dev/video0
[gstreamer] gstCamera – didn’t discover any v4l2 devices
[gstreamer] gstCamera – device discovery and auto-negotiation failed
[gstreamer] gstCamera – failed to create device v4l2:///dev/video0
video-viewer: failed to create input stream
root@orin1:/jetson-inference/build/aarch64/bin# ls /dev/vid*
ls: cannot access ‘/dev/vid*’: No such file or directory
Hi @randy.goebbert ! I moved this post over to the Orin part of the forum - you’d posted it in the DGX area, and not sure it’d get the best eyes on it over there.
ScottE
Hi @randy.goebbert , can you try running video-viewer with /dev/video1 instead?
same results within the container… neither /dev/video0 or /dev/video1 works:
oot@orin1:/jetson-inference/build/aarch64/bin# video-viewer v4l2:///dev/video1
[gstreamer] gstCamera – attempting to create device v4l2:///dev/video1
[gstreamer] gstCamera – failed to create device v4l2:///dev/video1
this started working when I restarted the container with the camera plugged in… not sure why, but /dev/video0 is now showing up… OK to close this
OK, glad you got it working! Yes, you must start the container after the camera gets plugged in.
system
Closed
June 29, 2022, 3:46am
10
