Im trying to prepare a l4t 35.4.1 BSP + rootfs for massflash via
export NVIDIA_FLASH_BOARDID=3701 NVIDIA_FLASH_BOARDREV=A.0 NVIDIA_FLASH_FAB=TS4 NVIDIA_FLASH_BOARDSKU=0004
./tools/kernel_flash/l4t_initrd_flash.sh --uefi-keys uefi_keys/uefi_keys.conf -i ./ekb.key --no-flash --network usb0 --massflash 5 jetson-agx-orin-devkit internal
But when running the command, we get an error:
flash.sh --no-flash --sign -i "./ekb.key" --uefi-keys "uefi_keys/uefi_keys.conf" jetson-agx-orin-devkit internal
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0239 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0248 ] File rcm_state open failed
[ 0.0248 ] ERROR: failed to read rcm_state
[ 0.0248 ]
[ 0.0304 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0305 ] Assuming zero filled SBK key
[ 0.0251 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[ 0.0300 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[ 0.0366 ] Parsing partition layout
[ 0.0375 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0388 ] Kernel DTB used: None
[ 0.0388 ] WARNING: dce base dtb is not provided
[ 0.0388 ] Parsing partition layout
[ 0.0396 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0405 ] Creating list of images to be signed
[ 0.0413 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0421 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0428 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0430 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0464 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0471 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0518 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0520 ] adding BCH for mb2_t234_aligned.bin
[ 0.0549 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0668 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0670 ] adding BCH for mb2_t234_aligned.bin
[ 0.0787 ] Filling MB1 storage info
[ 0.0787 ] Parsing dev params for multi chains
[ 0.0840 ] Generating br-bct
[ 0.0850 ] Updating dev and MSS params in BR BCT
[ 0.0851 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0861 ] Updating bl info
[ 0.0870 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.0879 ] WARNING: boot chain is not completed. set to 0
[ 0.0885 ] Generating signatures
[ 0.0940 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0941 ] Assuming zero filled SBK key
[ 0.1075 ] Warning: pub_key.key is not found
[ 0.1022 ] Parsing dev params for multi chains
[ 0.1022 ] Generating br-bct
[ 0.1032 ] Updating dev and MSS params in BR BCT
[ 0.1032 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.1043 ] Updating bl info
[ 0.1051 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1059 ] WARNING: boot chain is not completed. set to 0
[ 0.1065 ] Get Signed section of bct
[ 0.1073 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.1081 ] Signing BCT
[ 0.1137 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1138 ] Assuming zero filled SBK key
[ 0.1161 ] Sha saved in br_bct_BR.sha
[ 0.1163 ] Warning: pub_key.key is not found
[ 0.1108 ] Updating BCT with signature
[ 0.1117 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.1124 ] Offset :4608 Len :3584
[ 0.1129 ] Generating SHA2 Hash
[ 0.1184 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.1185 ] Assuming zero filled SBK key
[ 0.1206 ] Sha saved in br_bct_BR.sha
[ 0.1153 ] Updating BCT with SHA2 Hash
[ 0.1161 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.1169 ] Offset :4608 Len :3584
[ 0.1171 ] Offset :68 Len :8124
[ 0.1172 ] Generating coldboot mb1-bct
[ 0.1179 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1186 ] MB1-BCT version: 0.10
[ 0.1187 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1190 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1191 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1192 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.1195 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.1196 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.1197 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.1198 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.1199 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.1201 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.1202 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.1203 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.1204 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.1204 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.1206 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1206 ] Added Platform Config 9 data with size :- 100
[ 0.1207 ] Updating mb1-bct with firmware information
[ 0.1214 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1231 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1245 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.1253 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1312 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1313 ] Assuming zero filled SBK key
[ 0.1324 ] Warning: pub_key.key is not found
[ 0.1277 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1287 ] Generating recovery mb1-bct
[ 0.1295 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1301 ] MB1-BCT version: 0.10
[ 0.1302 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1305 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1306 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1307 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.1310 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.1311 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.1312 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.1313 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.1314 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.1315 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.1317 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.1318 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.1319 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.1320 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.1323 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1323 ] Added Platform Config 9 data with size :- 100
[ 0.1324 ] Updating mb1-bct with firmware information
[ 0.1332 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1349 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.1364 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.1373 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.1432 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1433 ] Assuming zero filled SBK key
[ 0.1445 ] Warning: pub_key.key is not found
[ 0.1398 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1409 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.1409 ] Copying signatures
[ 0.1417 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1452 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1453 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1453 ] Boot Rom communication
[ 0.1462 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Error: Return value 8
Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Error: bootloader/signed/flash.idx is not found
Error: failed to relocate images to tools/kernel_flash/images
Cleaning up...
The log leads to the assumption that the offline-mode of l4t_initrd_flash_internal.sh doesn’t work. Any idea whats wrong here?
