Orin AGX's display doesn't work after flashing with JetPack 5.1.2
After flashing the Orin AGX with JetPack 5.1.2, display via DP doesn’t working anymore. I’ve checked the boot log via serial debug port and the target got booted successfully. It seems that the display frequency is not compatible with monitors which support 1920x1080 60Hz. With JetPack 5.1.1, display works perfectly with the same monitor.
Could you try more monitors and see if this happens to specific one?
Hi Wayne,
yes, I’ve tried many monitors (but all 60Hz) and the result it the same: JetPack 5.1.1 works, JetPack 5.1.2 not.
We are not able to reproduce yorur issue. Could you share the /var/log/Xorg.0.log to us?
Is this still an issue to support? Any log can be shared? Thanks
