It happens every time I boot up.
** WARNING: Test Key is used. **
L4TLauncher: Attempting Direct Boot
OpenAndReadUntrustedFileToBuffer: Failed to open \boot\initrd: Not Found
ExtLinuxBoot:sds Failed to Authenticate \boot\initrd (Not Found)
L4TLauncher: Unable to boot via extlinux: Not Found
L4TLauncher: Attempting Kernel Boot
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map…
?/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
I/TC: Secondary CPU 8 initializing
I/TC: Secondary CPU 8 switching to normal world boot
I/TC: Secondary CPU 9 initializing
I/TC: Secondary CPU 9 switching to normal world boot
I/TC: Secondary CPU 10 initializing
I/TC: Secondary CPU 10 switching to normal world boot
I/TC: Secondary CPU 11 initializing
I/TC: Secondary CPU 11 switching to normal world boot
? 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.104-tegra (buildbrain@mobile-u64-6348-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Tue Jan 24 15:09:44 PST 2023
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: Jetson AGX Orin
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x1008260518 SMBIOS=0xffff0000 SMBIOS 3.0=0x1006be0000 MEMATTR=0x1007609018 ESRT=0x1006bbb318 RNG=0x102a9fdd18 MEMRESERVE=0x1007612f18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000001006bbb318 to 0x0000001006bbb350.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000100a800000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000001037ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000001003ffffff]
[ 0.000000] node 0: [mem 0x0000001004000000-0x00000010061bffff]
[ 0.000000] node 0: [mem 0x00000010061c0000-0x000000100653dfff]
[ 0.000000] node 0: [mem 0x000000100653e000-0x00000010066d1fff]
[ 0.000000] node 0: [mem 0x00000010066d2000-0x0000001006bcffff]
[ 0.000000] node 0: [mem 0x0000001006bd0000-0x0000001006beffff]
[ 0.000000] node 0: [mem 0x0000001006bf0000-0x0000001006dfffff]
[ 0.000000] node 0: [mem 0x0000001006e00000-0x0000001006e4ffff]
[ 0.000000] node 0: [mem 0x0000001006e50000-0x000000100751ffff]
[ 0.000000] node 0: [mem 0x0000001007520000-0x000000100756ffff]
[ 0.000000] node 0: [mem 0x0000001007570000-0x00000010075dffff]
[ 0.000000] node 0: [mem 0x00000010075e0000-0x00000010075fffff]
[ 0.000000] node 0: [mem 0x0000001007600000-0x000000100761ffff]
[ 0.000000] node 0: [mem 0x0000001007620000-0x000000100763ffff]
[ 0.000000] node 0: [mem 0x0000001007640000-0x000000100775ffff]
[ 0.000000] node 0: [mem 0x0000001007760000-0x000000100793ffff]
[ 0.000000] node 0: [mem 0x0000001007940000-0x000000100798ffff]
[ 0.000000] node 0: [mem 0x0000001007990000-0x0000001007acffff]
[ 0.000000] node 0: [mem 0x0000001007ad0000-0x0000001007b9ffff]
[ 0.000000] node 0: [mem 0x0000001007ba0000-0x0000001007d7ffff]
[ 0.000000] node 0: [mem 0x0000001007d80000-0x0000001007d9ffff]
[ 0.000000] node 0: [mem 0x0000001007da0000-0x0000001007daffff]
[ 0.000000] node 0: [mem 0x0000001007db0000-0x000000100838ffff]
[ 0.000000] node 0: [mem 0x0000001008390000-0x000000100842ffff]
[ 0.000000] node 0: [mem 0x0000001008430000-0x000000100852ffff]
[ 0.000000] node 0: [mem 0x0000001008530000-0x00000010085cffff]
[ 0.000000] node 0: [mem 0x00000010085d0000-0x00000010086cffff]
[ 0.000000] node 0: [mem 0x00000010086d0000-0x000000100876ffff]
[ 0.000000] node 0: [mem 0x0000001008770000-0x000000100903ffff]
[ 0.000000] node 0: [mem 0x0000001009040000-0x000000100921ffff]
[ 0.000000] node 0: [mem 0x0000001009220000-0x000000102a9affff]
[ 0.000000] node 0: [mem 0x000000102a9b0000-0x000000102a9fffff]
[ 0.000000] node 0: [mem 0x000000102aa00000-0x000000102e7fffff]
[ 0.000000] node 0: [mem 0x000000102ea00000-0x000000102eefffff]
[ 0.000000] node 0: [mem 0x0000001036000000-0x0000001037ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000001037ffffff]
[ 0.000000] On node 0, zone Normal: 256 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90200 r8192 d32680 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16195328
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0
[ 0.000000] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[ 0.000000] Memory: 63767340K/65811456K available (18432K kernel code, 3168K rwdata, 7164K rodata, 3968K init, 1110K bss, 1519828K reserved, 524288K cma-reserved)
[ 0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000856] Console: colour dummy device 80x25
[ 0.001047] printk: console [tty0] enabled
[ 0.001097] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.001108] pid_max: default: 32768 minimum: 301
[ 0.001184] LSM: Security Framework initializing
[ 0.001208] Yama: becoming mindful.
[ 0.001229] SELinux: Initializing.
[ 0.001365] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.001455] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.003822] rcu: Hierarchical SRCU implementation.
[ 0.003937] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.004661] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0000-p3737-0000.dts
[ 0.004673] DTB Build time: Jan 24 2023 15:26:09
[ 0.006241] Tegra Revision: A01 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.006365] Remapping and enabling EFI services.
[ 0.007594] smp: Bringing up secondary CPUs …
[ 0.036382] Detected PIPT I-cache on CPU1
[ 0.036422] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.036472] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.065136] Detected PIPT I-cache on CPU2
[ 0.065146] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.065160] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.093760] Detected PIPT I-cache on CPU3
[ 0.093769] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.093784] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.124448] Detected PIPT I-cache on CPU4
[ 0.124470] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.124497] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.153151] Detected PIPT I-cache on CPU5
[ 0.153160] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.153176] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.181800] Detected PIPT I-cache on CPU6
[ 0.181810] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.181825] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.210453] Detected PIPT I-cache on CPU7
[ 0.210463] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.210478] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.241145] Detected PIPT I-cache on CPU8
[ 0.241167] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[ 0.241195] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.269848] Detected PIPT I-cache on CPU9
[ 0.269858] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[ 0.269874] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.299114] Detected PIPT I-cache on CPU10
[ 0.299125] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[ 0.299139] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.328377] Detected PIPT I-cache on CPU11
[ 0.328388] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.328403] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.328459] smp: Brought up 1 node, 12 CPUs
[ 0.328543] SMP: Total of 12 processors activated.
[ 0.328548] CPU features: detected: Privileged Access Never
[ 0.328552] CPU features: detected: LSE atomic instructions
[ 0.328554] CPU features: detected: User Access Override
[ 0.328558] CPU features: detected: 32-bit EL0 Support
[ 0.328562] CPU features: detected: Common not Private translations
[ 0.328565] CPU features: detected: RAS Extension Support
[ 0.328568] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.328571] CPU features: detected: CRC32 instructions
[ 0.328573] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.366609] CPU: All CPU(s) started at EL2
[ 0.370054] devtmpfs: initialized
[ 0.388071] Registered cp15_barrier emulation handler
[ 0.388087] Registered setend emulation handler
[ 0.388092] KASLR enabled
[ 0.388227] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.388243] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.391281] pinctrl core: initialized pinctrl subsystem
[ 0.391837] SMBIOS 3.0.0 present.
[ 0.391847] DMI: Unknown Jetson AGX Orin/Jetson AGX Orin, BIOS 2.1-32413640 01/24/2023
[ 0.392148] NET: Registered protocol family 16
[ 0.393003] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.393206] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.393405] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.393436] audit: initializing netlink subsys (disabled)
[ 0.393527] audit: type=2000 audit(0.392:1): state=initialized audit_enabled=0 res=1
[ 0.393712] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.393714] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.393719] thermal_sys: Registered thermal governor ‘pid_thermal_gov’
[ 0.396094] cpuidle: using governor menu
[ 0.396203] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.396332] ASID allocator initialised with 32768 entries
[ 0.396433] Serial: AMBA PL011 UART driver
[ 0.398318] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.398344] Tegra reboot handler registered.
[ 0.417127] mc: mapped MMIO address: 0xffff8000111f0000 → 0x2c10000
[ 0.417144] mc: mapped MMIO address: 0xffff800011210000 → 0x2c20000
[ 0.417152] mc: mapped MMIO address: 0xffff800011230000 → 0x2c30000
[ 0.417160] mc: mapped MMIO address: 0xffff800011250000 → 0x2c40000
[ 0.417168] mc: mapped MMIO address: 0xffff800011270000 → 0x2c50000
[ 0.417174] mc: mapped MMIO address: 0xffff800011290000 → 0x2b80000
[ 0.417181] mc: mapped MMIO address: 0xffff8000112b0000 → 0x2b90000
[ 0.417189] mc: mapped MMIO address: 0xffff8000112d0000 → 0x2ba0000
[ 0.417197] mc: mapped MMIO address: 0xffff8000112f0000 → 0x2bb0000
[ 0.417204] mc: mapped MMIO address: 0xffff800011310000 → 0x1700000
[ 0.417211] mc: mapped MMIO address: 0xffff800011330000 → 0x1710000
[ 0.417218] mc: mapped MMIO address: 0xffff800011350000 → 0x1720000
[ 0.417224] mc: mapped MMIO address: 0xffff800011370000 → 0x1730000
[ 0.417232] mc: mapped MMIO address: 0xffff800011390000 → 0x1740000
[ 0.417238] mc: mapped MMIO address: 0xffff8000113b0000 → 0x1750000
[ 0.417245] mc: mapped MMIO address: 0xffff8000113d0000 → 0x1760000
[ 0.417253] mc: mapped MMIO address: 0xffff8000113f0000 → 0x1770000
[ 0.417262] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.417296] mc-err: mcerr ops are set to t23x
[ 0.417988] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 67, base_baud = 0) is a SBSA
[ 1.676253] printk: console [ttyAMA0] enabled
[ 1.684850] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.691559] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.698259] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.704958] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.713530] ACPI: Interpreter disabled.
[ 1.718641] vdd-av1v1-hub: supplied by vdd-5v-sys
[ 1.723515] vbusA-cvb: supplied by vdd-5v-sys
[ 1.728001] vbusB-cvb: supplied by vdd-5v-sys
[ 1.732485] vdd-usbc1-vbus: supplied by vdd-5v-sys
[ 1.737391] vdd-usbc2-vbus: supplied by vdd-5v-sys
[ 1.742477] iommu: Default domain type: Translated
[ 1.747404] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.753679] SCSI subsystem initialized
[ 1.757496] usbcore: registered new interface driver usbfs
[ 1.763003] usbcore: registered new interface driver hub
[ 1.768327] usbcore: registered new device driver usb
[ 1.773557] mc: Linux media interface: v0.10
[ 1.777836] videodev: Linux video capture interface: v2.00
[ 1.783465] pps_core: LinuxPPS API ver. 1 registered
[ 1.788429] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.797568] PTP clock support registered
[ 1.801690] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.808858] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 1.816523] Registered efivars operations
[ 1.821109] FPGA manager framework
[ 1.824555] Advanced Linux Sound Architecture Driver Initialized.
[ 1.830915] Bluetooth: Core ver 2.22
[ 1.834499] NET: Registered protocol family 31
[ 1.838942] Bluetooth: HCI device and connection manager initialized
[ 1.845303] Bluetooth: HCI socket layer initialized
[ 1.850184] Bluetooth: L2CAP socket layer initialized
[ 1.855243] Bluetooth: SCO socket layer initialized
[ 1.860631] camchar: rtcpu character device driver loaded
[ 1.866265] clocksource: Switched to clocksource arch_sys_counter
[ 2.025087] VFS: Disk quotas dquot_6.6.0
[ 2.029064] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.036095] pnp: PnP ACPI: disabled
[ 2.041529] la/ptsa driver initialized.
[ 2.045418] NET: Registered protocol family 2
[ 2.049974] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 2.059696] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 2.068470] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 2.077076] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 2.084985] TCP: Hash tables configured (established 524288 bind 65536)
[ 2.091721] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 2.098789] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 2.106404] NET: Registered protocol family 1
[ 2.111056] RPC: Registered named UNIX socket transport module.
[ 2.116994] RPC: Registered udp transport module.
[ 2.121696] RPC: Registered tcp transport module.
[ 2.126395] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.132848] PCI: CLS 0 bytes, default 64
[ 2.136902] Trying to unpack rootfs image as initramfs…
[ 2.253492] Freeing initrd memory: 8208K
[ 2.259809] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.267805] kvm [1]: IPA Size Limit: 48 bits
[ 2.272251] kvm [1]: VHE mode initialized successfully
[ 2.278142] Initialise system trusted keyrings
[ 2.282670] workingset: timestamp_bits=46 max_order=24 bucket_order=0
[ 2.291320] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.297435] NFS: Registering the id_resolver key type
[ 2.302502] Key type id_resolver registered
[ 2.306684] Key type id_legacy registered
[ 2.310724] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 2.317430] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 2.324835] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.340788] NET: Registered protocol family 38
[ 2.345235] Key type asymmetric registered
[ 2.349332] Asymmetric key parser ‘x509’ registered
[ 2.354225] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 2.361679] io scheduler mq-deadline registered
[ 2.366211] io scheduler kyber registered
[ 2.374170] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.379799] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.385389] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.390975] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 2.399042] tegra_dc_assign_hw_data: no matching compatible node
[ 2.405060] tegradccommon module_init failed
[ 2.409330] tegradc module_init failed
[ 2.413329] EINJ: ACPI disabled.
[ 2.418073] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 2.424955] tegra-pmc: ### PMC reset source: MAINSWRST
[ 2.430095] tegra-pmc: ### PMC reset level: L1
[ 2.434537] tegra-pmc: ### PMC reset status reg: 0x2d
[ 2.440815] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.462300] random: fast init done
[ 2.464839] printk: console [ttyTCU0] enabled
[ 4.099248] arm-smmu 12000000.iommu: probing hardware configuration…
[ 4.107249] arm-smmu 12000000.iommu: SMMUv2 with:
[ 4.112084] arm-smmu 12000000.iommu: stage 1 translation
[ 4.117630] arm-smmu 12000000.iommu: stage 2 translation
[ 4.123160] arm-smmu 12000000.iommu: nested translation
[ 4.128613] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 4.136027] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 4.144959] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 4.151656] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 4.158346] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 4.165860] arm-smmu 10000000.iommu: probing hardware configuration…
[ 4.172558] arm-smmu 10000000.iommu: SMMUv2 with:
[ 4.177383] arm-smmu 10000000.iommu: stage 1 translation
[ 4.182913] arm-smmu 10000000.iommu: stage 2 translation
[ 4.188447] arm-smmu 10000000.iommu: nested translation
[ 4.193900] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 4.201301] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 4.210181] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 4.216864] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 4.223556] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 4.230665] arm-smmu 8000000.iommu: probing hardware configuration…
[ 4.237267] arm-smmu 8000000.iommu: SMMUv2 with:
[ 4.242004] arm-smmu 8000000.iommu: stage 1 translation
[ 4.247454] arm-smmu 8000000.iommu: stage 2 translation
[ 4.252894] arm-smmu 8000000.iommu: nested translation
[ 4.258242] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 4.265559] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 4.274341] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 4.280942] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 4.287548] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 4.294830] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 4.305385] tegra_profiler: version: 1.150, samples/io: 50/29
[ 4.311353] tegra_profiler: auth: init
[ 4.315492] nvsciipc: loaded module
[ 4.320652] tun: Universal TUN/TAP device driver, 1.6
[ 4.326290] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 4.333698] hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.339173] e1000e: Intel(R) PRO/1000 Network Driver
[ 4.344257] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.350344] igb: Intel(R) Gigabit Ethernet Network Driver
[ 4.355882] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.361734] PPP generic driver version 2.4.2
[ 4.366161] PPP BSD Compression module registered
[ 4.370993] PPP Deflate Compression module registered
[ 4.376189] PPP MPPE Compression module registered
[ 4.381122] usbcore: registered new interface driver r8152
[ 4.386759] usbcore: registered new interface driver asix
[ 4.392302] usbcore: registered new interface driver ax88179_178a
[ 4.398563] usbcore: registered new interface driver cdc_ether
[ 4.404546] usbcore: registered new interface driver net1080
[ 4.410352] usbcore: registered new interface driver cdc_subset
[ 4.416429] usbcore: registered new interface driver zaurus
[ 4.422150] usbcore: registered new interface driver cdc_ncm
[ 4.427968] usbcore: registered new interface driver aqc111
[ 4.433794] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 4.440140] ohci-pci: OHCI PCI platform driver
[ 4.444708] ohci-platform: OHCI generic platform driver
[ 4.450355] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 4.456791] usbcore: registered new interface driver uas
[ 4.462281] usbcore: registered new interface driver usb-storage
[ 4.468579] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 4.474689] mousedev: PS/2 mouse device common for all mice
[ 4.480424] usbcore: registered new interface driver xpad
[ 4.487818] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.493293] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:29 UTC (29)
[ 4.501533] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.507956] i2c /dev entries driver
[ 4.511696] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 4.517600] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 4.523291] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 4.528971] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 4.534649] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 4.540312] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 4.545981] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 4.551668] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 4.559513] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 4.568097] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 4.577580] device-mapper: uevent: version 1.0.3
[ 4.582414] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: -003c: NVVRS PSEQ probe successful
?ebugfs initialized
? 5.895895] hid: raw HID events driver (C) Jiri Kosina
[ 5.901668] usbcore: registered new interface driver usbhid
[ 5.907413] usbhid: USB HID core driver
[ 5.912091] tegra-dce d800000.dce: Adding to iommu group 5
[ 5.919225] dce: dce_ipc_channel_init:314 Invalid Channel State [0x0] for ch_type [2]
[ 5.928354] tegra234-aon c000000.aon: Adding to iommu group 6
[ 5.934788] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 5.939428] c000000.aon:hsp: probed
[ 5.943748] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [0]. Ignored…
[ 5.943759] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [0]. Ignored…
[ 5.956256] tegra234-aon c000000.aon: init done
[ 5.956674] tegra23x-psc e860000.psc: Adding to iommu group 7
[ 5.965047] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 5.970112] tegra23x-psc e860000.psc: ext_cfg base:(ptrval)
[ 5.976104] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 5.982550] tegra23x-psc e860000.psc: init done
[ 5.989006] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] …
[ 5.989008] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored…
[ 5.989022] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored…
[ 5.998108] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 8
[ 6.002611] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [2]
[ 6.003004] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 6.012017] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 6.019839] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] …
[ 6.019840] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored…
[ 6.019850] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored…
[ 6.086240] dce: dce_start_boot_flow:173 DCE_BOOT_DONE
[ 6.088523] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 6.100813] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 6.112448] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 6.123862] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 6.135606] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 6.148202] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 6.161055] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 6.173078] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (117)
[ 6.179893] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 6.188256] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=10150ec03f8849d1537396903b70d4a48a255aba
[ 6.201612] t19x_cache tegra-cache: probed
[ 6.206038] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 6.220910] optee: probing for conduit method.
[ 6.225503] optee: revision 3.19 (18d0f61b)
[ 6.226176] optee: dynamic shared memory is enabled
[ 6.235616] optee: initialized driver
[ 6.252492] nvpmodel: initialized successfully
[ 6.257201] tegra_hv: get_hvd: not initialized yet
[ 6.262168] user_ivc_mempool: hypervisor not present
[ 6.267956] usbcore: registered new interface driver snd-usb-audio
[ 6.274920] u32 classifier
[ 6.277726] input device check on
[ 6.281510] Actions configured
[ 6.285184] Initializing XFRM netlink socket
[ 6.290041] NET: Registered protocol family 10
[ 6.295675] Segment Routing with IPv6
[ 6.299499] NET: Registered protocol family 17
[ 6.304097] NET: Registered protocol family 15
[ 6.308736] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 6.323150] Bluetooth: RFCOMM socket layer initialized
[ 6.328502] Bluetooth: RFCOMM ver 1.11
[ 6.332393] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.338505] Bluetooth: HIDP socket layer initialized
[ 6.344532] 9pnet: Installing 9P2000 support
[ 6.349029] Key type dns_resolver registered
[ 6.354391] registered taskstats version 1
[ 6.358631] Loading compiled-in X.509 certificates
[ 6.368371] Loaded X.509 cert ‘Build time autogenerated kernel key: d2e6b29ce3ba3f3d31103e414d71889f8474be7b’
[ 6.378938] tegra194-pcie 14100000.pcie: Adding to iommu group 9
[ 6.391938] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 6.399107] tegra194-pcie 14160000.pcie: Adding to iommu group 10
[ 6.411673] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.418584] tegra194-pcie 141a0000.pcie: Adding to iommu group 11
[ 6.431096] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 6.464208] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[ 6.474817] host1x 13e40000.host1x: Adding to iommu group 13
[ 7.492877] t23x_init_gating_regs: Timed out waiting for syncpt ram init!
[ 7.510936] host1x 13e40000.host1x: initialized
[ 7.515968] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[ 7.524110] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 7.536170] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[ 7.544290] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 7.556357] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[ 7.564498] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 7.576519] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[ 7.584615] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 7.596627] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[ 7.604750] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 7.616758] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[ 7.624876] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 7.636912] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[ 7.645022] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 7.657071] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[ 7.665168] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 7.677179] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[ 7.685290] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 7.697329] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[ 7.705428] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 7.717434] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[ 7.725544] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 7.737576] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[ 7.745707] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 7.757717] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[ 7.765847] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 7.777843] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[ 7.785948] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 7.797977] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[ 7.806082] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 7.818085] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[ 7.826166] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 7.838198] falcon 15340000.vic: Adding to iommu group 30
[ 7.849356] falcon 15340000.vic: initialized
[ 7.854049] falcon 15380000.nvjpg: Adding to iommu group 31
[ 7.863365] falcon 15380000.nvjpg: initialized
[ 7.868079] falcon 15540000.nvjpg1: Adding to iommu group 32
[ 7.877138] falcon 15540000.nvjpg1: initialized
[ 7.881964] falcon 154c0000.nvenc: Adding to iommu group 33
[ 7.893407] falcon 154c0000.nvenc: initialized
[ 7.898122] falcon 15a50000.ofa: Adding to iommu group 34
[ 7.907382] falcon 15a50000.ofa: initialized
[ 7.911933] nvdec 15480000.nvdec: Adding to iommu group 35
[ 7.924468] nvdec 15480000.nvdec: initialized
[ 7.929078] tsec 15500000.tsec: Adding to iommu group 36
[ 7.939752] tsec 15500000.tsec: initialized
[ 7.946933] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 7.963701] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 7.979318] gpio-394 (camera-control-output-low): hogged as output/low
[ 7.986065] gpio-397 (camera-control-output-low): hogged as output/low
[ 7.992827] gpio-487 (camera-control-output-low): hogged as output/low
[ 7.999574] gpio-486 (camera-control-output-low): hogged as output/low
[ 8.007296] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 8.014547] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 8.021536] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 8.028089] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 8.034584] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 8.040829] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 8.048894] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 8.057447] tegra194-isp5 14800000.isp: Adding to iommu group 37
[ 8.067041] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 8.076619] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 8.083184] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38
[ 8.091628] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39
[ 8.100017] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 8.109980] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 8.116801] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 8.126683] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 8.133485] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 8.143391] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 8.150224] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 40
[ 8.159007] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 8.170377] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 41
[ 8.179091] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 8.190463] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 42
[ 8.199237] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 8.210605] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 43
[ 8.219327] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=dev Coldplug all Devices…
[ 13.384302] systemd[1]: Started Journal Service.
[ 13.415917] systemd-journald[306]: Received client request to flush runtime journal.
Ubuntu 20.04.6 LTS san-desktop ttyTCU0
san-desktop login: ls -d ~/nvidia/nvidia_sdk/*
Password:
Login incorrect
san-desktop login: san
Password:
Welcome to Ubuntu 20.04.6 LTS (GNU/Linux 5.10.104-tegra aarch64)
This system has been minimized by removing packages and content that are
not required on a system that users do not log into.
To restore this content, you can run the ‘unminimize’ command.
Expanded Security Maintenance for Applications is not enabled.
0 updates can be applied immediately.
21 additional security updates can be applied with ESM Apps.
Learn more about enabling ESM Apps service at Ubuntu Expanded Security Maintenance | Security | Ubuntu
